C5 vs ls2 GTO
Stock for stock, it's about even, with maybe a slight nod to the vette.
3300lbs/350hp=9.4lbs/hp for the vette
3800lbs/400hp=9.5lbs/hp for the GTO
Both have IRS, but the manual GTO is difficult to launch properly which is shown in GM's official numbers giving the auto a .1sec advantage. GTO has narrower tires that can easily light up.
Assuming driver skill, track and weather conditions are the same, its very close. In the end, they are very different cars, though. The GTO is more of a "touring" car, that should more appropriately be matched to a BMW or such, rather than a mustang. One thing where the corvette excels is at higher speeds. The lower drag means that it will be pulling harder at the trap.
I submitt that all 3 cars, C5 vette, camaro/TA, and ls2 GTO are all pretty equal in 1/4 performance. They fit different catagories. The GTO is a better touring car, my WS6 TA is just punch you in the face, raw fun. My C5 vette is better balanced, handles the best, etc.
There all GM, not rice
so that's a good thing. In the end, though, who cares which one is .0001sec faster.
it's a wash. Maybe aero comes into play, but not enough to matter.
but driver has alot to do with it. my gf shifts her TT at 4k and thinks she flying the redline is 6500 never even in full boost. driver driver driver. ken gushi ran down a new vette with a tank 350z.
However, this is the only instance I'm going to say f-body gets the nod. My Z06 will blow away my well-modified WS6 from anything other than a dead stop.
Seriously the 3.42 in C5s and fbody is bogg city! Us Goats have C5 Z06 trans ratios, much better all around.
So I'm hearing it will come down to a drivers race. Stock GTOs have been known to dip into the high 12s, good driver low 13s easy, average mid 13s. We are under-tired for sure. 245s in back.
We come in at ~3700 lbs, maybe 500 lbs heaver? Power to weight ratio is C5 - 9.14 lb/hp, ls2 GTO - 9.25 lb/hp. Pretty damn close!
I doubt its as great a difference as you think, besides, gears can be changed out. You can't change the GTO's body/frame.
judgement made!
