My engine's on fire!!!
Old Mar 29, 2007 | 12:43 PM
  #61
corvettejimw's Avatar
corvettejimw
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '08
looks cool guys!!!
A couple of guys in our club did this, but bought two rear center lights out from a van at the junk yard and hooked them up with switch where the ash tray is. Cost a buck a light....
Old Mar 29, 2007 | 05:12 PM
  #62
slayer6x6's Avatar
slayer6x6
Whats the difference between a cold cathode and a neon?
I can only find 12" cold cathodes, would that be too long?
Old Mar 29, 2007 | 05:13 PM
  #63
B-rent's Avatar
B-rent
Old Mar 29, 2007 | 05:56 PM
  #64
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
12" are perfect for mounting on the inside of the fender (instead of the detachable plastic piece seen in the spdkilz website.
Originally Posted by B-rent
this is direct from oznium.com
What exactly is a cold cathode?
A cold cathode is a lamp very similar to a neon lamp. The light comes from a small round neon tube (2.6mm diameter) powered by a transformer. The transformer is designed to use 12 volts DC, and output approximately 650 volts AC that is needed to power the cold cathode.
What is the difference between cathodes and neon's?
The main difference is in the light output and cost. Cathodes are much brighter and less expensive than regular neon accent tubes. Cathodes are a better value.
Old Mar 29, 2007 | 09:00 PM
  #65
Mike04's Avatar
Mike04
I like it
Old Apr 1, 2007 | 12:13 AM
  #66
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
this is the best night pic i could get:
Old May 3, 2007 | 01:42 AM
  #67
AMRAAM's Avatar
AMRAAM
The night picture is cool!
I was just noticiing the reflection of the cathode on the fender. I wonder if you can place the cathode where you can get a good glow effect through the vent and still not see the cathode or the reflection?
I'll have to look undedr the fender to see.
Old May 3, 2007 | 02:22 AM
  #68
Jistari's Avatar
Jistari
Originally Posted by AMRAAM
Cool. i was wondering if two would be too much so let us know what you find
I was just thinking that it would be kinda cool to have it get brighter as RPMs increased. Anyone know how to do that?
AAMRAM, you're killing me :-)
I was hoping to keep this as "my own private little mod"
This was exactly what I wanted....sooooo...I fumbled through as follows:
(2) red side marker lights from autoparts, regular incandescents (due to the warm up/cool down time giving it that analog look we want)
(1) fuse tap (to get power from the block under the passenger footwell)
(1) "Beat Box" <== small electrical component to make the lights blink to the beat of the music. You can find them in the Ricer section of bigger autoparts stores.
Mount the marker lights in the coves, far enough back and high enough that you only see the glow out of the cove. Not meant to be as bright as the neons at the start of this post.
Run the wires through the flex connector that carries the door wiring into the car (this will take a while, but "gotta be neat" so its worth it).
Connect lights to "Beat Box", Beat Box to power, and mount under dash against frame somewhere that you can reach it to adjust the sensitivity and preferably towards the center console (so you pick up the resonance from the engine/exhaust rather than the bass from the speakers in the doors).
Fire up the engine and adjust the sensitivity until it barely flickers at idle, as rpms go up, it gets brighter
Old May 3, 2007 | 08:05 AM
  #69
istsme98's Avatar
istsme98
Old May 3, 2007 | 09:02 AM
  #70
JohnTheStigGalt's Avatar
JohnTheStigGalt
Originally Posted by EnglandGreen
Looks good
When I did mine 2 years ago - everyone told me I was The King of Rice
How time and opinions change
Steven, I don't think that was the only reason for your coronation...
Old May 3, 2007 | 09:13 AM
  #71
AMRAAM's Avatar
AMRAAM
I'm killin' ya? Maybe you just shouldn't be so selfish!!! lol. Just kidding.
Seriously, thanks for sharing this . Sounds easier than I expected to be. I have a few questions if you don't mind me asking.
Have you done this yet? Or is it still in the concept stage?
How bright would the bulbs be? I am looking foir more of a soft glow look. If they are too bright for what I want, is there any reason I couldn't wire the cathodes to the "beat box"?
I'm also thinking I'd like to have a switch to bypass the beat box so I have the option of having them on constantly. Do some beat boxes have a "constant on" setting? And lastly, I don't listen to really loud music, but if the radio was on, wouldn't the lights be flashing to it?
Thanks!
Old May 3, 2007 | 10:58 AM
  #72
Anthony01's Avatar
Anthony01
Originally Posted by JDs00PewterCoupe
Very cool. More details please.
Old May 3, 2007 | 11:01 AM
  #73
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I'm replacing the screens as soon as the new ones arrive in the mail. (tried to spray paint the regular ones and the paint job was crappy) I'm going to see if attaching a piece of frosted plexiglas will even out the light and reduce the reflection of the cathode itself. Stay tuned.
Old May 3, 2007 | 11:27 AM
  #74
DPG's Avatar
DPG
St. Jude Donor '06
Radio, it never ends does it. let us know how the plexi works out.
Also, I would assume that the red is legal because as someone else mentioned, the vettes side markers on the rear fenders are red. It only has to be amber in the front. You are not allowed to have red markers in the front of the vehicle.
Old May 3, 2007 | 12:50 PM
  #75
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Hi, my name is Radioflyer and i'm a plexi-holic. I use plexiglas more than duct tape and believe if acrylic is emplyed correctly it could cause world peace.
The official Ruling on the Red vs. Amber when last i checked is that Red must be facing the rear OR facing the side on the rear half of the vehicle. Amber must be facing the front or the side on the front half of the vehicle. The exceptions to this rule are clearence lights on trucks (i.e. the sierra denali edition and dully pickups)
Old May 3, 2007 | 12:52 PM
  #76
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Looks awesome George!
I think that's one of those feel good mods... when you see it, when you see the reactions of others... I just feels good
Old May 3, 2007 | 02:27 PM
  #77
AMRAAM's Avatar
AMRAAM
To My engine's on fire!!!
Old May 3, 2007 | 02:34 PM
  #78
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Old May 3, 2007 | 02:51 PM
  #79
5ltrEATER's Avatar
5ltrEATER
Very cool, cheap DIY mod!
Old May 3, 2007 | 04:52 PM
  #80
dark_phantom's Avatar
dark_phantom
From: Central Florida. Black Sheep Squadron Member. 465 rwhp & 477 rwtq
St. Jude Donor '07
That looks great.
