I hydro locked my engine . . .
Good Luck with your NEW 402!! J.H.
I am interested in this b/c I have a Stinger, but have not cut the shroud as my car is a daily driver in SoFla. I try to avoid standing water if at all possible, but this story shows that **** happens.
Good luck.
I drove my car in water about 6" deep last summer, stock intake... Didn't accelerate hard though, just let her idle through.
No problems at all... I know you were getting on the freeway and had to accelerate and aside from that the water was 15" deep. But I'm certain that accelerating didn't help the situation any.
Hope your back on the road soon!
If VaraRams actually hydrolocked motors do you think they would still be in business?
I would not be surprised if other manufacturers started those rumors about VaraRam because it's intake kicks all other azzes in performance.
Maybe you can get you a 402 now
Derek
Holy ****!
Glenn, good buddy! Man, I m absolutely sorry to hear what had happened to your beautiful beast.
And, you have meticulously spent so much time and effort to bring her to the level of customization that has remained so inspiring to many here on the C5 Forum. Hang in there, my friend! Words of experience: Do your best to negotiate the best return from your insurance (AAA) as you can. Important: You will also better serve and position yourself (for the highest and most suitable return) by calling the best and biggest Chevrolet regional dealers for comparative pricing when settling your case. And, be firm.
Furthermore, consider the possible damage to any, and, all mechanical, any wiring, electrical, inner floor boards, as well as, sensors, etc., that many be undetected at this time in your pricing. Finally, as mentioned above, this unfortunate, incident, although a PITEA, may fortuitously open up a new door towards a custom engine platform that you have been dreaming of for your Black Beauty C5 Vert. And, do keep us posted, my friend. We are only a PM away!
That sucks. I would go with a forged bottom end if you can swing it just because the stock pistons and rods suck. Maybe you'll get enough insurance money and find a good deal on a used forged block.
Keep us posted on outcome with insurance and your motor plans.
Not true. When I hydrolocked my C3, it was still under the original factory warranty. The GM district rep would only authorize the replacement of the one bent connecting rod in the # 7 cylinder. Nothing more.
I tried taking my car there when I lived in Ft. Worth once. Even though I had the appointment a week in advance, they didn't even look at my car the day of the appointment. It must have been a bad day for them or something, but my service rep didn't even handle the situation well. I just picked up the car at the end of the day and ended up fixing the problem myself later, their loss.
Hope you have better luck.
Now, I hafta ask, based on your sig: A jayhawk is gonna put PURPLE in his interior???!!!!
The TRIC uses a 90 degree elbow passing thru the radiator shroud to position the filter down in the open air (or water
).You would have to get a lot of water in there to sieze the engine as the filter itself will absorb water before it even gets to the engine.
The Stinger is just an open air filter that resides in the stock filter location. It is not terribly prone to water ingestion.
The TRIC consisted of a tube connected to the MAF, that elbowed down, passed through the front radiator shroud (required a hole to be cut), and then the filter attached in the open cavity in front of the radiator at the lower front bumper area.. This was a great system for making power, but unfortunately, located the air filter just a few inches about ground surface:
This system hasn't been made in 5+ years, it was discontinued after several people hydrolocked their engines, in the same type of situation that happened to Glenn.
