Any problems with your 2004s?
Old Nov 25, 2007 | 09:12 PM
dyeggy's Avatar
dyeggy
St. Jude Donor '10-'11-'12, '14-'17,'21, '25
Originally Posted by love my car
13,000 great miles of smiles......
30,000 miles here.
Unless you count flat tires. Since I changed from run flats. 5 in the last six months! Including replacing both rear tires due to side wall punctures
Old Nov 25, 2007 | 09:28 PM
vette3800's Avatar
vette3800
Early 04 models did have some left fuel tank and fuel tank transfer line issues. I started a post on this. See the Gas leaking ...????? post. A design change was made on early 04s and then corrected on later 04 models.
Baron138's Avatar
Baron138
Major Major problems covers by the dealer! Hood liner was coming apart, and the fuel cap ratchet was broken! Oh yeah, the under hood light was on all the time. Time to sell it huh!
Old Nov 25, 2007 | 09:32 PM
omahavet's Avatar
omahavet
No problems on mine (10K) except it keeps screaming for mods. I'm slooowly
giving in.
Mr. Couture's Avatar
Mr. Couture
only problem I've ever had with my 04 is the air-box keeps unclipping. Other than that, everything is in tip top shape
Old Nov 25, 2007 | 09:37 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
I have one of the first 04's produced. 17,000 miles and zero problems.
Old Nov 25, 2007 | 09:38 PM
PUREFUN's Avatar
PUREFUN
St. Jude Donor '07-'08
Passenger side headlight gear wore out and right front turn signal went out. All fixable thanks to the info here from the forum.
Old Nov 25, 2007 | 10:35 PM
TEXHAWK0's Avatar
TEXHAWK0
The only thing mechanical I have had to replace on my 04 Z06 is both window regulator assemblies, and tires..
I also replaced the corner lights on the front because the lenses were cracking on the rear corners.
Old Nov 25, 2007 | 10:56 PM
DocHorton's Avatar
DocHorton
No problems with mine...23000 miles, by the way love the white and red combo!!
Originally Posted by dooscoop32
I had to have a fog light replaced under warranty because it was so far out of adjustment it couldn't be fixed. The dealer had no idea how that could be and neither did I. That was done at 400 miles but other than that, there haven't been any problems at all. I'm still on the original battery, too, yet a friend of mine who has a 2003 50th Anniversary edition is on his third battery. I love my 2004 and don't plan to ever get rid of it.
Old Nov 25, 2007 | 11:08 PM
jrose7004's Avatar
jrose7004
The 04 is the best a C5 will ever be. It's C5 perfected.
Old Nov 25, 2007 | 11:12 PM
mbroadway's Avatar
mbroadway
Default Any inherent problems with 03s?
Considering an AE. Just wondered if they were prone to problems.
Old Nov 25, 2007 | 11:16 PM
TJ VETT's Avatar
TJ VETT
No visits to the service dept. yet.
Old Nov 25, 2007 | 11:39 PM
  #33
mag red vette's Avatar
mag red vette
Currently have 32,000 miles. Rear differential leak, column lock, column lock, column lock, column lock, front end steering recall, fuel tank filler hose replaced, hood liner delaminated, driver door control panel replaced, dash lights faded, radio replaced. I'd buy another in a minute!!!
Old Nov 26, 2007 | 12:04 AM
  #34
04C5comm's Avatar
04C5comm
29K mi and no issues to report
Old Nov 26, 2007 | 12:13 AM
  #35
z06Bigbird's Avatar
z06Bigbird
1. It goes too fast.
2. It is too reliable.
Old Nov 26, 2007 | 12:42 AM
  #36
lt1george's Avatar
lt1george
Mine has been perfect. Knock on wood. Save the Wave.>George
Old Nov 26, 2007 | 01:05 AM
  #37
z16kalel's Avatar
z16kalel
No problems here, the Z is still on the original battery
To Any problems with your 2004s?
Old Nov 26, 2007 | 05:04 AM
  #38
Gohard777's Avatar
Gohard777
Mine was too slow, had to fix it.....
Old Nov 26, 2007 | 05:44 AM
  #39
Black 'n Tan's Avatar
Black 'n Tan
St. Jude Donor '07
Let's see, (my '04): driver's seatbelt broke, targa seal replaced, turn signal lenses replaced (filled with water), battery replaced, door panels replaced, (vinyl delaminated) column lock, wind noise, drivers window, worked on 3 times, now the latest, my console finish is wearing off!. My car has an annoying rattle in the dash in cold weather, and that window still makes noise (I'm going to take the door apart myself this winter). I've owned the car just about one year, and I've got 42,000 miles on it.
Definitely the most warranty returned vehicle I've ever owned, the only other vehicle I had that came close was a '92 Pontiac, in my experience GM still doesn't know what Q-U-A-L-I-T-Y means.
But, it's a unique, and fun car to drive and I enjoy it. I'm just disappointed in the quality, it really shows up if you use the car on a regular basis.
John
Old Nov 26, 2007 | 06:05 AM
  #40
tlc0706's Avatar
tlc0706
Differential leak, window gaskets....covered by warranty.....Most fun car have ever owned
