Pit-man \ Rev-Extreme Stroker update
Old Apr 27, 2008 | 08:51 PM
  #81
pit-man's Avatar
pit-man
Tracy,
We should see some difference in the 2 TB's...Pete Incaudo said that new TB is the Sh*t !!! Hope you get a chance to dyno with and without the TI's also.
Pit
Old Apr 27, 2008 | 10:16 PM
  #82
TLewis4095's Avatar
TLewis4095
Originally Posted by pit-man
Tracy,
Pit
ALready told John....should be interesting. On most cars I would say not much difference, and stock heads/cam would loose low-end power, but on your flowing beast I expect to see a gain.
Old Apr 28, 2008 | 11:22 AM
  #83
pit-man's Avatar
pit-man
Default Rev-x Dyno results
Today is the dyno day...Lets post them up..
Pit
Old Apr 28, 2008 | 11:26 AM
  #84
peter pan's Avatar
peter pan
Life Time NCM #2196
Sweet finally hitting the rollers
Old Apr 28, 2008 | 11:29 AM
  #85
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Sweet build dude!!
I noticed in one of your pictures that your fresh air line that went from your valve cover to the air intake was capped off? I have been reading that you are supposed to run a fresh air line when swapping to the fast. Any reason why you didnt??
Old Apr 28, 2008 | 12:54 PM
  #86
pit-man's Avatar
pit-man
Thanks....
That line was just recirculating the crank case air and releasing crank case pressure. They put a breather on the valve cover instead (hope they remember to plug the hole on the vararam)..haha.
I haven't heard of the fresh air to the Fast being necessary ?
Pit
Old Apr 28, 2008 | 01:33 PM
  #87
Corvette-Chris
St. Jude Donor '08
http://forums.corvetteforum.com/show....php?t=1657403
Old Apr 28, 2008 | 01:47 PM
  #88
TLewis4095's Avatar
TLewis4095
Thanks....
Pit
The FAST needs no other fresh air intake other than the snout it'self to feed the motor. Due to the build, the breather mod does several things...prevents any oil mist from back-flowing into the air bridge or throttle body, allows a freer flow of filtered fresh air into the crankcase to flush out the harmfull gasses, and it allows ventinting of excees crankcase pressure at high RPM's that would normally be pushed back into the air intake.
Old Apr 28, 2008 | 01:58 PM
  #89
pit-man's Avatar
pit-man
I did notice the TB having a slight film of oil on it...not a good thing to have build up inside the TB !!
Pit
Old Apr 28, 2008 | 02:36 PM
  #90
pit-man's Avatar
pit-man
Default Dyno numbers ?
Tracy, You can tell us before posting the paper..
Pit
Old Apr 29, 2008 | 06:31 AM
  #91
pit-man's Avatar
pit-man
Default dyno results
All right...early reports are about 3 rwhp lower than what I expected. About 13 lower than I had hoped for. Tracy is doing a little more tweaking today...lets see what he can squeeze out of it.
Anyone care to guess (383 stroker, AFR255's, med cam for street\strip) ?
Pit
Old Apr 29, 2008 | 10:05 AM
  #92
Corvette-Chris
St. Jude Donor '08
Pit
Im gonna guess 477 rwhp
Old Apr 29, 2008 | 10:47 AM
  #93
pit-man's Avatar
pit-man
Default Chris # 1
there is one guess..I will post up tonight. Anyone else feel brave ??
Pit
Old Apr 29, 2008 | 10:52 AM
  #94
Blu's Avatar
Blu
Pit
you mean AFR 225's right?
if the cam is in the 230's I guess 482rwhp
Old Apr 29, 2008 | 11:23 AM
  #95
pit-man's Avatar
pit-man
Default Blu # 2
Yes Blu, they are AFR 225's and good guess on the cam..right on it.
Anyone else ??? I will post tonight !!
Pit
Old Apr 29, 2008 | 11:35 AM
  #96
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Pit
Get more out of it! !
Old Apr 29, 2008 | 12:25 PM
  #97
peter pan's Avatar
peter pan
Life Time NCM #2196
You want 500 rwhp so 497 rwhp
To Pit-man \ Rev-Extreme Stroker update
Old Apr 29, 2008 | 12:30 PM
  #98
WKMCD's Avatar
WKMCD
I'm going to say 445/390 until you post a graph.
Old Apr 29, 2008 | 02:10 PM
  #99
pit-man's Avatar
pit-man
Ok WKMCD,
I had 433 rwhp and 400 tq with the same heads and a 224 reverse split cam an the stock bottom end. Now Add a little for the extra cubes and a little for the cam....and guess a new one.
Pit
Old Apr 29, 2008 | 06:12 PM
  #100
TLewis4095's Avatar
TLewis4095
479 rwhp & 450 some tq? On a safe tune w/the RevXtreme TB over the LS2.... (just a guess...)
