NEW Interior LED Mod Thread
Old Jan 23, 2011 | 06:35 AM
  #641
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Yep, you are a busy boy!!!
I switched to those electronic cigerettes and I kicked real smoking with them. If you try and change too much too fast you'll fail at em all! Just keep being fat and happy huh?
Tim
PS PM me and stop polluting my Thread with your senseless babble!
Old Jan 23, 2011 | 06:39 AM
  #642
Gitusum's Avatar
Gitusum
Tim
the patch is workin for me so far and im tired of being fat and happy and i am not polluting it im keeping it up top so people can see it better!
oh and I love you TIM!
Old Jan 23, 2011 | 06:55 AM
  #643
tstar's Avatar
tstar
Love you too snookums....
Old Jan 23, 2011 | 08:43 AM
  #644
rdwiv's Avatar
rdwiv
Old Jan 25, 2011 | 08:02 AM
  #645
DarthMonolith's Avatar
DarthMonolith
I did the LED mod, and the dim display fix at the same time. Unfortunately when I plugged the unit into the car the LEDs stay lit with no power applied. I also screwed up the a/c, I think I scratched the board. It is a great mod, it took more time to remove from the car than to mod the box.
Old Jan 25, 2011 | 09:45 AM
  #646
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Originally Posted by Gitusum
Tim do you ever sleep? I miss you!
Nope and you know why...
Leave me alone... you.... stalker!!!!!
How have you been Rick?????
Tim
I thought it was cause you were afraid of the dark
it's ok, I am too
Old Jan 25, 2011 | 03:26 PM
  #647
tstar's Avatar
tstar
I know George... That's why we're into these Lighting mods!
OK OK Back to our regularly scheduled programing!
Old Jan 28, 2011 | 02:42 AM
  #648
rpm462's Avatar
rpm462
Ok, I've got a bit of a puzzle for you guys. I'm redoing an HVAC unit for a friend and tried using a 3-LED strip for "Passenger" lighting but for some reason it won't light up when the rest of the single LED's do.
If I apply power directly to the LED strip it works fine but then the rest of the LED's don't light up.
I've tried various ways of running jumpers to the LED's and LED strip and either the single LED's light up or the LED strip lights up but not both at the same time. I thought maybe I had the polarity wrong on the LED strip but I checked it and it's correct. If I put a single LED in that slot it works fine. Any ideas? Really hate to give up on this and use single LED's here.
Old Jan 28, 2011 | 05:12 AM
  #649
tstar's Avatar
tstar
Bruce you get into more sh*t!!!
Are you tapping the power for the LED strip off of the Auto button's LED? I don't even see an LED for the Auto button as a matter of fact! Or are you trying to use the strip for both areas??
Take the power off of the pass throughs that are for the Passenger script area and see how that works out. I know nascar57 uses the strips there with good results.
Make sure you test the button operations out before you call it done, it looks like some of those resistors will interfere with the buttons going all the way down...
Tim
Old Jan 28, 2011 | 08:35 AM
  #650
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Guys:
I'm still getting everything together to start this.
I was looking at the little "airbag" OFF light in the center console and I found out its burnt out (0.445Mohm across the bulb). Its the light beside the traction control button. I do detect 12v on the incoming line though so the circuit is good (when air bag switch in glove box is turned to OFF). I only turn off my airbags when my 6 yr old son drives with me. I just never noticed that the little light was out.
I was looking at the light, and it appears that there is no way to replace it. It looks likes its plastic welded to the entire plate.
Anyone have to replace this before ? What did you do ? I would want something that does not look "added on"... or an afterthought.
I was looking at the Radio shack site and found this possibility (5mm LED). I will likely have to drill the old one out, and insert this. Should be an easy install though.
Or maybe get an LED holder from Radio Shack like this to put in one of the LED's I already have....
Thoughts ?
Thanks !
Toque
Old Jan 28, 2011 | 12:36 PM
  #651
rpm462's Avatar
rpm462
Tim
Yes, I do have the LED strip going into where the Auto LED goes, thinks that's the problem? I was hoping to use the strip to light up the Auto and Pass LED areas. It fit perfectly when I originally stuck it down. It's normally lit up like all the rest though isn't it? I'll give the Pass area a try and if that doesn't work guess I'll go back to single LED's for those areas. Maybe try a 10mm for the Pass area.
Might be right about the buttons now that I look at it, might have to twist those resistors around a bit.
Old Jan 28, 2011 | 04:53 PM
  #652
nascar57's Avatar
nascar57
Thats pretty strange. I piggy back the 3 led strip off the auto button led and have never had any problems. make sure you have the positive at the top on the led strip and the led too. Good luck!
Old Jan 28, 2011 | 04:57 PM
  #653
rpm462's Avatar
rpm462
I was wrong....had the same problems when using single LED's also. Had to be something wrong with the circuit somewhere. Was able to solder the Auto LED and Pass LED positive leads to the positive lead on the blue LED next to the adjustment **** and got them to work.
It might not look like it because of the lighting but all the LED's are lit!
Old Jan 28, 2011 | 10:52 PM
  #654
nascar57's Avatar
nascar57
Make sure and post pictures of the green. I love the rich color of green leds but havent seen anyone do one in green.
Old Jan 28, 2011 | 11:36 PM
  #655
rpm462's Avatar
rpm462
Here's a couple pics of it sitting in my car, so bear with all the blue LED's. I need to figure out a way to power it up without having to pull my HVAC. Luckily need to replace a couple of LED's in mine anyway. The car it's going in is a dark bowling green metallic.
Old Jan 28, 2011 | 11:52 PM
  #656
nascar57's Avatar
nascar57
leds are tough to get good pictures of. I'm sure it looks much greener in person. Good work!
Old Jan 29, 2011 | 12:05 AM
  #657
_zebra's Avatar
_zebra
looks great. i'm wanting to do mine in a rich purple, but those LEDs are hard to come by
To NEW Interior LED Mod Thread
Old Jan 29, 2011 | 12:13 AM
  #658
rpm462's Avatar
rpm462
Definitely does, not to mention the small LED lights in the bottom buttons are actually a vivid red. Oh well, what can you do?
Old Jan 29, 2011 | 01:17 AM
  #659
Naranjas's Avatar
Naranjas
just went tru all pages lol alot of good ideas i might be using...
Old Jan 29, 2011 | 12:04 PM
  #660
rpm462's Avatar
rpm462
Try looking at Oznium.com and take a look at their UV colored LED's, in the pics they show they look pretty purple.
