NEW Interior LED Mod Thread
Old Oct 6, 2012 | 04:49 AM
  #921
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I meant the HUD/Dimmer switch on the left of the IPC not the HUD display, I don't think there is a viable way to change the color of the HUD projector... Wish there was though!!!! Anyway, the problem with the HUD switch is that the holes for the stock bulbs are much smaller then the other switches in the car and those PLCCs ain't going in those! Everything else should be fairly easy with the PLCCs (probably just jinxed myself!).
I know from playing around with the LEDs that just one Red and one Blue is too Blueish... How many Reds and Blues are in those Festoons of yours?
If you store your car for the winter, send me your stuff and I'll experiment on yours!
Tim
Old Oct 6, 2012 | 08:34 AM
  #922
SL1D3R's Avatar
SL1D3R
WA Events Coordinator
If I can find somebody in Washington to help me out, I'll buy everything from you. Actually, I might buy from you, anyway.
Old Oct 6, 2012 | 08:54 PM
  #923
_zebra's Avatar
_zebra
Tim
yeah, i was talking about the IPC switch, too. i just didn't know what was going on inside of it. if the actual HUD wasn't perma-green, that'd be sweet!
as for my festoons, it's two rows of three (row 1: red, blue, red; row 2: blue, red, blue). mathematically, it all depends on the output of each color more than the numbers. if you want to do 1:1 with yours, then you could try using increasingly stronger resistors on the blue to lessen the output until you get the color blend you want.
and i'm actually moving from TX to SD this Christmas/new year~ish time & then there's the potential for a deployment by this spring, so i'll keep that in mind
Old Oct 6, 2012 | 11:34 PM
  #924
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
ttt
Old Nov 18, 2012 | 12:04 AM
  #925
jfaxas's Avatar
jfaxas
Looks great. I'm looking to do the same for mine but I can't find a thread on how to get to the footwell light or the connector. Pardon the pun but can you shed a little light here for me?
thanks
Old Nov 18, 2012 | 03:03 AM
  #926
SilverC54me's Avatar
SilverC54me
The footwell lights do not have a connector. You have to cut the wires to the light holder. The orange wire is +12v and the black is ground.
Gary
Old Nov 18, 2012 | 12:41 PM
  #927
jfaxas's Avatar
jfaxas
I'll get cracking
N on this today
Old Nov 18, 2012 | 02:12 PM
  #928
TXGS507's Avatar
TXGS507
I would highly recommend Tim... But then again i am biast due to his awesome work!
Old Nov 19, 2012 | 05:20 AM
  #929
tstar's Avatar
tstar
THanks Matt!
That turned out really good! Is your passenger **** temp control in the HVAC changing color between Blue and Red pretty good?? I forgot to check... Some change really well while others just won't, luck of the draw I think.
Tim
Old Nov 19, 2012 | 08:17 AM
  #930
old stingray's Avatar
old stingray
Thanks for all the info. I may have to pull the trigger on this mod.
Old Nov 19, 2012 | 09:02 AM
  #931
TXGS507's Avatar
TXGS507
Everything is Perfect Sir! Thanks!
THanks Matt!
Tim
Old Nov 19, 2012 | 12:06 PM
  #932
MotoJB's Avatar
MotoJB
Looks sick Brotha! I'm in the process of doing the same but all blue.
Old Nov 19, 2012 | 03:00 PM
  #933
sonny557's Avatar
sonny557
Default Positive or negative HUD
Very nice instructions ! Does anyone have a diagram for the HUD switch, positive and negative. I'm kinda stumped as which leg is positive and negative. Doing the change out over thanksgiving week. Any help is appreciated! Do i solder to the board or use the little bulb holders?
Sonny
Old Nov 19, 2012 | 05:46 PM
  #934
tstar's Avatar
tstar
Hey Sonny,
On the first page of this Thread I have all the pin outs so you can benchtest eveything...
You can use the bulb holders for the Interior Dimming icon and the HUD up and down position rocker, the other two should be soldered in with the LED down in side of the switch aimed for the best effect. You really have to experiment with the location especially on the Page and HUD Dimmer slider. FYI the HUD switch is a real PITA!
Tim
Old Nov 19, 2012 | 06:59 PM
  #935
sonny557's Avatar
sonny557
Default Thanks
Thanks Tim, I overlooked that page. Have a Great Thanksgiving !!
sonny
Old Nov 19, 2012 | 07:01 PM
  #936
tbrent's Avatar
tbrent
2018 C5 of Year Winner
Mr. Tim! Still helping people achieve their aesthetic interior lighting dreams! Great guy-awesome work
Hope you are doing okay buddy! Get to sleep at a decent hour would'ya... Turkey Day cometh!
Old Nov 20, 2012 | 04:31 AM
  #937
tstar's Avatar
tstar
Sleep is for sissies and you young guys with hormone issues!
How have you been???
You have a great thanksgiving and be safe on the job! God knows enough of you firefighters have sacrificed too much!!!
Tim
To NEW Interior LED Mod Thread
Old Dec 24, 2012 | 02:05 PM
  #938
BACNBLK's Avatar
BACNBLK
That looks great!
Is that with just std replace led for stock bulbs or is that a led strip in the footwells?
Merry Christmas and thanks!
Old Dec 24, 2012 | 02:12 PM
  #939
Crossroads's Avatar
Crossroads
i think its LED strip, Im in the process of doing all mine to LED, waiting on a few more from Oznium, anyways mine are the white and shine like that at night
Old Dec 24, 2012 | 02:24 PM
  #940
BACNBLK's Avatar
BACNBLK
How any LEDs for that much light, six inch or 12 inch ?
