NEW Interior LED Mod Thread
Old May 19, 2012 | 03:10 PM
  #881
02z06dave's Avatar
02z06dave
Originally Posted by SilverC54me
When the engine is on all of the LED's will light up. With it off only the middle rows will light up. This is due to the voltage required by each white (or blue) LED to turn on. Each LED needs 3.5v to turn on.
With just the battery voltage you have approximately 12.6 to 12.8v to power up the LED circuits. With the engine on you have around 14v.
The mix of green and yellow LEDs used by GM in the mirror require a bit less voltage to turn on that is why they were used.
So in the end you have installed them correctly.
Gary
I checked with the car running. Only the middle rows light up.
Any other ideas?
Old May 20, 2012 | 07:28 PM
  #882
02z06dave's Avatar
02z06dave
Ttt
Old May 20, 2012 | 08:38 PM
  #883
SilverC54me's Avatar
SilverC54me
Originally Posted by 02z06dave
I modified the little circuit board as instructed by tim like this...
The result, however, did not change. I still only have the middle two lights lit up with the car on or off.
Did I perform that mod correctly? Does anyone perhaps have any other suggestions?
Thanks,
Dave
Looking at the first photo it looks like you have some damaged circuit traces where the LED's are soldered in. And they all don't look clean. You may need to scrape some of the coating from the circuit traces to get a spot to solder to for the damaged ones. All of the contacts on the left side of the module look damaged.
I would carefully re-solder the connections. Also do you have the same result with both left and right modules?
Gary
Old May 20, 2012 | 09:03 PM
  #884
02z06dave's Avatar
02z06dave
Gary
Yes, both left and right have the same result.
Old May 21, 2012 | 11:29 AM
  #885
For 02z06dave - could you please re-post up the pics in the post SilverC54me references two posts above? Would like to see what he is talking about.
Old Jul 23, 2012 | 03:41 PM
  #886
MrGary2011's Avatar
MrGary2011
Default LED upgrade
It has been a while since I have been on this thread. I have had a problem with my LED in the middle DIC position (goes out, flickers, stays on sometime). It has been bugging me for months. Finally figured out it has to be the bulb (tried 2 different DIC modules). Anyway my LEDs have always been dimmer then the ones in the climate control. I noticed OZUIM now has brighter wedge LEDs that are 2 time the brightness! I just ordered a full set for all non climate control pieces. Has anybody else put these more brighter wedges in their car?
Old Jul 23, 2012 | 03:46 PM
  #887
MrGary2011's Avatar
MrGary2011
Originally Posted by irvbulldogs72
Has anyone attempted an LED cluster yet? These LEDs look really great in the buttons, *****, and switches, but I'd love to see a cluster with C6 brightness and crispness to match. The El-Glo gauges are close, but I don't love the bold font. The stock Z06 font is wonderful, just woefully dim from the factory.
There is a place that sells C6 floresent bulbs and colors can be ordered. I have a spare cluster an may attempt to back engineer this in the near future, believe it can be done (its done on the C6). A red glow to match all the other red leds would look awesome!
Gary
Old Aug 26, 2012 | 07:45 PM
  #888
jerrad's Avatar
jerrad
I replaced my map lights with LED's. For some reason the drivers side doesnt light up near as much as the passenger side. I swapped bulbs and have the same result.
Anyone have any ideas?
Old Aug 26, 2012 | 09:51 PM
  #889
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
perhaps a bad contact I would take the mirror down and clean the contacts and then check the voltage
Old Aug 26, 2012 | 10:22 PM
  #890
jerrad's Avatar
jerrad
What voltage should I see? Do I just check across the contacts?
How should I clean them up, just some sand paper?
Old Aug 27, 2012 | 05:43 AM
  #891
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Same voltage as the passenger side would be a likely target voltage, probably 12ish... measure DC voltage between the two sets of contacts. We are assuming that you have a standard mirror using the 212 Festoons??????????
You want to see good clean metal where the bulb makes contact and also where the wires are connected, no corrosion, dried on cola ect... Those Festoon contact fingers can be a real PITA!
Tim
Old Aug 27, 2012 | 05:44 AM
  #892
tstar's Avatar
tstar
Gary
Update???????????????????????????
Tim
Old Aug 27, 2012 | 09:13 AM
  #893
TheRadioFlyer
Supporting Vendor
CRC spray-on electrical cleaner would probably help too.
Old Aug 28, 2012 | 12:10 AM
  #894
jerrad's Avatar
jerrad
I have a small issue, I had some led's placed in my DIC and the top one took a dump on me. I spoke to the guy that did the work and he said they are 5mm 20k bulbs that are bright white. He won't be able to send out the led/connector for a bit and I need one by thursday. Is there anyway someone could hook me up and send me one ready to just screw into my DIC?
I can PP you whatever it cost.
Thanks for any help.
Old Aug 28, 2012 | 09:21 PM
  #895
rpm462's Avatar
rpm462
Tim
Hey Tim, was wondering if you were still around!
Old Aug 29, 2012 | 05:24 AM
  #896
tstar's Avatar
tstar
Yeah, I'm still kicking!!!!!!! I don't hang out on here as much anymore. How have you been doing?????? I haven't watched the weather this morning but I hope that Hurricane leaves you guys alone!
You dump the C5???
Tim
Old Aug 29, 2012 | 12:14 PM
  #897
rpm462's Avatar
rpm462
You dump the C5???
Tim
Good to hear. Doing good. Thanks....Hurricane hasn't been too bad where I'm at, mostly a lot of rain, few strong wind gusts and some flooding close to the beach but haven't lost power at all so far...fingers crossed! Lol
No, still have both...you?
To NEW Interior LED Mod Thread
Old Aug 29, 2012 | 05:40 PM
  #898
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Great info!
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Aug 30, 2012 | 05:26 AM
  #899
tstar's Avatar
tstar
Originally Posted by SacCityCorvette
Great info!
Thanx! As usual it's too big and jumbled again but there is alot of good info in here.
Tim
Old Sep 25, 2012 | 02:29 AM
  #900
ragu1585's Avatar
ragu1585
Any1 in north Houston area available to do my hvac for me (LEDs). I just did my resisters for the digital readout and didn't even think about the lights (guess almost all mine are burnt out?
Here's what I ended up with
