NEW Interior LED Mod Thread
Old Apr 7, 2014 | 06:25 AM
  #1061
CorvetteSPAZ's Avatar
CorvetteSPAZ
I put resistors on all of my leds. There weren't any shorts that I could see. For example I went to touch one led with the 9v and the whole board lighted up and then went out. Then I test another one and the whole board lighted up except for the previous one I touched. Having run out of leds and resistors to use I popped everything back in and 50% of the leds work. Maybe the leds just burnt out? If half the board is working perfectly it can't be the circuit board right?
  #1062
CorvetteSPAZ
What accidentally contacting both leads burn out one led but not the rest?
Old Apr 7, 2014 | 06:33 AM
  #1063
CorvetteSPAZ
Only thing I can think is I wasn't paying close enough attention and accidentally touched pos to neg while testing. I have more leds and resistors coming in (with extras this time) and will do a test. Didn't hear anything go tzzzz while testing or smoke
Old Apr 7, 2014 | 01:52 PM
  #1064
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
It's kinda hard to say from long distance but you could have burnt a track while soldering the LEDs on and that certainly would affect the "downstream" LEDs...
What Ohm value resistors did you use and for what color LED?
It's good you saw no smoke nor heard the Tzzzzzzt... Frying a power board means buying a new/used HVAC!
Anyway, if you're still having problems send it to me...
Tim
Old Apr 7, 2014 | 05:17 PM
  #1065
CorvetteSPAZ
This picture, as bad quality as it is, the blur shows you the lights that do work. Fan sweeps beside passenger blue work.
A/C, auto, drivers word, and recirculation work.
Now mind you, tell you the truth lol, I had installed all of them backwards, and they all worked perfect when I tested them until hooked up to the car. So I reinstalled then all pos on top. That's when they stopped working as I tested. Lighted up for a moment then off for the bottom row.
I've ordered warm white leds so I'm going to swap all the white ones and replace the blue sweep. See how it goes soon.
On a positive note...sanding the tips of the leds flat with 220 sandpaper really creates a nice even dispersion. I also fixed the back lcd display so not a complete waste of several hours!
Also I originally got the leds from oznium and did the resistors according to what they had on the website there.
Old Apr 8, 2014 | 03:14 AM
  #1066
tstar's Avatar
tstar
Double check all your solder connections and make sure you inspect for burnt/crackedtracks or solder pads!
Tim
Old Apr 18, 2014 | 03:20 AM
  #1067
gtrslngrchris's Avatar
gtrslngrchris
Figured I'd post this in here since I'd been having trouble getting even light spread throughout my single zone HVAC controls. I originally had some pretty "interesting" LED setups soldered together trying to spread the light but nothing would really do what I wanted and it was all rather fragile. Worst part is it seems like you guys with the dual zone don't have this problem! Worth noting this only affected the top half, the bottom half was painless as everything had it's own LED.
Anyway, it dawned on me a week ago that I'm spending all this time trying to piggyback LEDs onto one another to get them where I want them physically and still having to solder resistors on to get them to accept 12v... Then I realized I had LED strips that you can cut apart into sections of 3 LEDs a piece and they're already built in with resistors to accept 12v so I gave it a shot and had I done this from the beginning I'd have been done SO much faster and with no headache at all!
Here you can see how I laid out each strip and connected them together so I only had to wire each half in. Note that there is a single LED still soldered in at the top and that is the single blue LED!
Single Zone HVAC PCB
Just a closer shot so you can see a little better. I used a single dab of super glue on the right hand side to make sure it stayed in place, otherwise the 3M adhesive held well enough.
Close Up
Here you can see my solution to the red/blue mixing too much. I simply cut up a piece of plastic and glued it in place to keep the extra blue spread from going too far into the red.
Barrier 1
Barrier 2
I will post a shot of the finished product once I get a camera that will actually capture it properly and not wash it out completely.
Old Apr 18, 2014 | 04:18 AM
  #1068
tstar's Avatar
tstar
Good job! I can't wait to see the finished product...
Tim
Old Apr 27, 2014 | 10:01 PM
  #1069
gtrslngrchris
After many, many failed attempts with my Galaxy S4 and then my new Galaxy S5 this is the best I could do for a shot of how it looks in person. Fact is the camera doesn't really show it because it's not nearly so uneven and in the pic it appears that the 5 has blue light bleeding into it but it doesn't look that way in person from either seat.
Single Zone HVAC
At any rate, I HIGHLY recommend using the cheap strip LEDs from eBay/Amazon/wherever as it makes it infinitely easier to spread the light for the single zone HVAC controls.
Old Apr 28, 2014 | 03:30 AM
  #1070
tstar's Avatar
tstar
Looks really good!! I know that taking pics of the lighting is a major PITA!
Good job and thanks for the tip!
Tim
Old May 10, 2014 | 12:44 AM
  #1071
jodyjo's Avatar
jodyjo
I've gotten as far as soldering in new LED's in place of the stock LED's but when I go to solder in a 3mm bulb with the resistor, I can't do it! This is my first soldering project and it makes me want to throw it all away! Is there a forum member who can help me out? I'd ship you the bulbs and resistors, name your price!
Old May 10, 2014 | 04:05 AM
  #1072
tstar's Avatar
tstar
PM sent...
Where are you using 3mm LEDs in the HVAC?
Tim
Old May 10, 2014 | 11:29 AM
  #1073
jodyjo's Avatar
jodyjo
I think that was a typo. I'm not at home but I believe I have 5mm bulbs for all incandescent lights except for the two under the rocker switches, those are 10mm. I was successful in installing 3mm bulbs into the existing led spots.
Old May 11, 2014 | 04:49 AM
  #1074
tstar's Avatar
tstar
Yes the mode indicators are 3mm... I use 5mm everywhere else in the HVAC though.
Tim
Old May 11, 2014 | 11:37 AM
  #1075
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
I'm looking to do a slightly different LED swap on the auto dimming mirror. Does anyone have the pin out diagram for the connector on the auto-dimming mirror for testing voltage and illumination?
thank you
Old May 15, 2014 | 10:03 PM
  #1076
TheRadioFlyer
Supporting Vendor
Cree LED modification in Auto-Dimming Mirror:
More details here:
http://forums.corvetteforum.com/c5-g...post1586910173
Old May 16, 2014 | 03:37 AM
  #1077
tstar's Avatar
tstar
That looks good George!
It must be like two little mini suns in the car with the Crees!!!! I know swapping the stock bulbs for strong white 5mm LEDs is like night and day (no pun intended of course! )
Tim
To NEW Interior LED Mod Thread
Old May 16, 2014 | 01:14 PM
  #1078
jandr020's Avatar
jandr020
8th Gear
Default Pulling this back up for a question
I know this is an old thread and maybe somewhere in it is the answer im looking for but I figured id ask anyway to see if anyone can help. I've updated all the lighting in my c5 with the exception of the automatic transmission shifter. I just order 5- 10mm by 26mm bulbs from the website listed on the 1st page. Im wondering if anyone has a write up/pictures on how to take apart the gear shifter. I have the dash taken apart no problem, but I don't want to break anything with the gear shifter. Any help would be appreciated! Thanks
-Jason-
Old Jun 10, 2014 | 01:01 AM
  #1079
Rookieracer's Avatar
Rookieracer
Just wanted to share the results of my PRNDL mod from this thread. I used blue LEDs. As usual the pics aren't as good as seeing them in person. It's much better than the single 194 blue LED which failed after about a year. The individual LEDs under each letter are crisp, clear and bright. The single LED was crisp under the D but became noticeably darker towards the P and the 1.
Old Jun 19, 2014 | 05:00 AM
  #1080
tstar's Avatar
tstar
Hi Guy!!!
Yes the LED strip mod in the PRRNDL is the way to go!!!!
Looks great! How much bleed out around the edges are you getting??
Tim
