need intake recommendation!!!!!!
Old Nov 5, 2008 | 04:34 PM
01vetteman's Avatar
01vetteman
2nd Gear
Default need intake recommendation!!!!!!
what kind of intake should i be looking at ? vararam ? and is there any other i should consider?????
Old Nov 5, 2008 | 05:19 PM
Corvette Don's Avatar
Corvette Don
Vararam is the best IMHO
Old Nov 5, 2008 | 05:21 PM
vettelover84's Avatar
vettelover84
There are quite a few different style to go with.
search INTAKE. I am sure a few will pop up.
I have a Carbon Fiber bridge with a Blackwing. I really like it. It has alot of filter media and its pretty easy to install/clean.
Good luck
Old Nov 5, 2008 | 05:25 PM
PostShawn's Avatar
PostShawn
There are happy people with all intakes out there. Your best bet is to explain your goals, budget, etc. Or even better just look up other posts and see the every bit of info and more that you can think of that's all ready out there.
Old Nov 5, 2008 | 05:31 PM
GETOPLES's Avatar
GETOPLES
I was in the same dilemma not long ago and was fortunate enough to be set straight by a very reliable CF member. Long story short...Vararam!
Old Nov 5, 2008 | 05:33 PM
z06 hellcat's Avatar
z06 hellcat
Old Nov 5, 2008 | 06:56 PM
jrose7004's Avatar
jrose7004
Just get a Blackwing and be done with it.
Old Nov 5, 2008 | 08:12 PM
dobewillie's Avatar
dobewillie
do a search and figure out what you like and go for it good luck
Old Nov 5, 2008 | 08:21 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
I have a Blackwing and chose it for its superior filtering capabilities and its OEM fit and appearance. A 2002-2004 Z06 Airbox lid is a good choice as well, just make sure to use a quality filter.
You can also choose from Callaway, Halltech, any of the dual cone style intakes (make sure that they have high quality filters) or a Vararam as you know.
The Vararam is the most difficult to install and the Z06 lid the easiest.
It is a good idea to install a hoodseal with any open intake as a precaution to reduce the amount of dirt and water that can enter just above the intake trhough the space between the hood and nose.
Here is a picture of my Blackwing installed:
Old Nov 5, 2008 | 09:02 PM
motogib1's Avatar
motogib1
Callaway Honker - $500 and highest quality
Vararam - average quality and Pita to install, this is what I run
There are some other like Vortex rammer.
If you are going to install an intake, go with a true cold air intake that draws air from outside the car and not from the engine compartment. Otherwise, why even bother.
Old Nov 5, 2008 | 09:30 PM
DevilMan02's Avatar
DevilMan02
http://www.byunspeed.com/product_inf...oducts_id=6830
$267.00 vs $500... hmmm
I'm going to purchase the Vararam simply because it's a better system. The blackwing will add horsepower, but the air that it's going to be drawing is warmer. It's only with the blackwing that you need to install the hoodseal. Of course it's not a bad idea to have one anyway, but it's not much benefit if you have a true cold air intake system. If you read the writeups, you'll see that there's very little difference between the two in terms of performance benefits at speeds below 60mph. Speeds above that, such as a highway race from a roll, you'll benefit much more from a 'forced induction' / cold air system.
This topic gets covered probably once a week. Search the forum and you'll find lots of debates and answers to your questions.
Old Nov 5, 2008 | 09:33 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
A bunch to choose from, I picked VaraRam and couldn't be happier with my decision.
Old Nov 5, 2008 | 09:35 PM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
vararam or blackwing. I have a blackwing.
Old Nov 5, 2008 | 09:39 PM
Ralphyboy's Avatar
Ralphyboy
St. Jude Donor '08-'09
Let the search feature be your friend grasshopper.
Old Nov 5, 2008 | 09:49 PM
NorCalVette Kid's Avatar
NorCalVette Kid
St. Jude Donor '09
Originally Posted by Ralphyboy
Let the search feature be your friend young grasshopper.
Old Nov 5, 2008 | 10:43 PM
You'll get lots of opinions on this question. For the most HP gain, Vararam is probably the way to go. But the Blackwing or Callaway Honker are also good choices. I ran a Blackwing on mine and was very pleased with it.
Old Nov 5, 2008 | 10:53 PM
Dave68's Avatar
Dave68
Default Intake systems
My costs may be a bit off, but most of what is stated here is based upon my experience with aftermarket intake systems for the C5....
If you live in California, think twice about the Vararam, as it can be a royal pain to install/uninstall/reinstall for smog tests. If you live in a state that doesn't have visual inspections, then also take a look at the following (grouped by cold air and non-cold air, but in no particular order) and my comments, if any:
Vararam: Brings cold air in through the fog light panel area to a panel-type filter. Owners have had good luck with system on the dragstrip, but plan on spending hours to install and a bit more to get everything lined up well. Downside: Eliminates engine bay-cooling air that would've come in from the fog light panels (Z06 or coupe/vert with opened-up panels), so the engine bay may end up being toastier, especially if you add headers later. $300-$400 (NOT smog legal in CA)
Vortech Rammer: Brings cold air up from in front of the radiator and into an enclosed box. Its filter is quite a bit smaller than the Halltech Warhead or Blackwing unit. $250 (NOT smog legal in CA)
Callaway Honker intake system: This one relocates the MAF so that it is just in front of the throttlebody. It directs cold air from underneath and costs about $500. I believe this unit is 50 states legal (smogwise) for non=Z06 C5s. Excellent design and quality. If cost is no object, this bad boy should be at the top of your list.
K&N FIPK: This is more of a semi-cold air system, as the cold air intake opening is more of a slit. Its filter endcaps are carbon fiber. However, it is configured similarly to the Halltech Stinger-R and is 50-states legal. $350
Reverse Zip-tie: Allows cold air to be drawn in from underneath, but the bare filter is exposed to potential damage from larger objects. The advantage here is that you may pass smog if the tech doesn't know "which way is up".
Warm air systems: (Easy installation)
Halltech Stinger-R: Not only contains the massive Warhead filter, but also includes a larger-than-stock airbridge and smooth throttlebody coupler. For $350.00 or less, this system represents one of the best bangs for the buck. Fortunately, if you don't like Z06 screens in front of cored-out fog light panels, (for about $40) you can add cold air induction. See my procedure at http://www.conceptualpolymer.com/corvette_c5_corner.htm
This is what I did and a swap to smog-legal status is very easy to do, as I have kept my Z06 intake box.
Halltech Stinger SSM: This intake system features an even larger filter than that of the Stinger-R, TRAP, and Blackwing. < $400
Blackwing: Includes just a large filter, but an excellent one at that. Its cost is close to that of the Stinger. Like the Stinger, it is not smog-legal in CA, but can easily be swapped.
Volant Twin Cone: This system gives you more open filter surface area than any stock box does and is well suited to an engine bay that gets cold air in from the fog light panels, as the filters are more or less in the air flow path. $265
2002+ Z06 airbox cover: A larger opening allows more air to be drawn in through the filter. Expect up to a 5 RWHP gain from this simple swap. $50
Zip-tie: An easy and inexpensive mod (eliminates the OEM box’s upper lid), but its sealing ability is questionable at best.
According to Jim Hall of Halltech, at 95-degrees IAT, the Blackwing (and other non-CAI intakes) will lose 1 degree of timing. At 135-degrees a full 12 degrees is pulled on the LS1 which equals 10 RWHP.
I measured before and after air intake temperature data with a stock Halltech Stinger and then with the same intake but with my CAI mod. The difference was staggering:
After sitting in traffic/slow-moving for 10 minutes or so, my stock Halltech setup was pulling in air that reached 145+ degreesF. Even after driving at highway speeds for 15 minutes, the intake temps never fell below 110F or so.
After installing my CAI mod, sitting in traffic/slow-moving for 10 minutes or more never produced more than 104 degrees F intake temps. After driving on the highway for less than a few minutes, the intake temps went all the way down to ambient temperatures (about 80 degrees F).
As far as horsepower gains, most aftermarket intakes will produce about the same horsepower gains if the intake air is kept relatively cool. During the many dyno runs I have seen, each car had its hood open and a large fan blowing air on the radiator. Vararam-equipped C5s produced the same gains as the Halltech and Blackwing-equipped C5s.
As was mentioned, the gains are only achieved permanently if the intake air is kept below a certain level. If not, much, if not all of your gains will be "dialed back" by the ECU.
Ebay specials: Most intake system air "runners" are made of plastic, not because it is the cheapest (it often isn't) material, but because the last thing most people want is the engine bay heat being transferred to the intake air via a metal runner. Many of the inexpensive Ebay intakes I've seen have metal runners - not good, IMO. Also, the filter is the most critical part of the intake system - why buy an unknown brand of filter for such a critical application? Please, don't cheap-out on an intake system. Stick with brands that have a long history of making quality products.
How good are these systems? My experience has shown that most will bump up RWHP by at least 10. The advantage of having cold air is that power will not be "dialed down" under slow moving/stop&go conditions.
You could easily lose 10 HP with a warm air system after engine bay temps rise during slow-moving conditions. Cold air prevents this from happening.
To need intake recommendation!!!!!!
Old Nov 10, 2008 | 12:36 PM
DevilMan02's Avatar
DevilMan02
Vararam takes hours if you're handicapped or killing a case of beer. It's also $260 shipped as I posted above, not the 300-400 he's talking about.
Old Dec 8, 2008 | 08:33 AM
Chevy-SS's Avatar
Chevy-SS
Vararam: ...................
Vortech Rammer: ...............
Callaway Honker intake system: ...................
K&N FIPK: .................
Reverse Zip-tie: ....................
Warm air systems: ...............
Halltech Stinger-R: ..............
Halltech Stinger SSM: ..............
Blackwing: ............
Volant Twin Cone: ..........
2002+ Z06 airbox cover:.....
Zip-tie: ....
Damn! That's a terrific post That should be a sticky, for sure (assuming all info is correct, that is).
Many thanks for posting all that info.
Old Dec 8, 2008 | 08:39 AM
dixonk's Avatar
dixonk
St. Jude Donor '09
I love my Callaway it looks clean!
