I'm about half way done with my install. My time to work on it each day is very limited and I have been taking my time.
I've done quite a bit all at once. I have relocated the oil pressure sender via TPE's kit( very nice setup) swapping intake manifolds, coolant cross over pipe ( still waiting on the 2nd one), managed to screw up 1 plug wire, built my own tunnel plate from 3/8 plate aluminum ( not a bad project, could do a 2nd one 2x as fast)..and installing the headers and eliminating the AIR system.
I have everything in place now..I've been working on it solo and was able to get them in with minimal issue. I put both sides in from the bottom. I'm working on jack stands in the driveway. The drivers side went in very easy. The passenger side took a little more effort. I undid the wires to the starter then decided to loosen the motor mounts from the bottom and jack the engine up ...(hooked the starter back up as I realized they were not a problem with the motor jacked up)..then slid the header in from the bottom to get it started..then climbed out and pulled it up to it's home from the top. I did have to undo the ground strap on both sides, I also removed the coil packs for good measure. Not to bad really. I could do it A LOT faster a second time. Everything is in place. It was HOT today so I called it quits. I'll tighten all the exhaust up tomorrow leaving only the stuff under the hood left to finish ( intake, coolant pipes, plugs, wires ect)
I spent a few extra bucks for OME gaskets and band clamps for the x-pipe, locking header bolts. Picks to follow when I'm done.
That's what I thought but I couldn't remember! Jack the Passenger side of the engine and you won't have to mess with the starter wiring... You may need to loosen the starter but that's about it!
I'll tell ya what my friend... You are doing it RIGHT! All the extra "Fail Safe" parts you're installing in conjunction with the Headers is sooooo smart! Plus the DIY plate! PM me or Jon about that if you can make more of them!!
Here are a few pics. Nothing wrong with them, but they are a tad smaller.
Say yes to cats. I'm glad to have cats now.
Holy bejesus! I guess there is a size difference! Thanks for posting the pics Jhonathan. Now I can go in the corner and cry with my inferior OBX's. I can see there being a slight difference in high end power with these since the pipes are bigger.
Good job! AND you got em at a steal too!!!!!!!
Tim
I loosed both the motor mounts from the bottom, I took the nuts all the way off and jacked the whole thing up. I did not even loosen the starter.
The DIY tunnel plate was a fun project. I looked at the ones on the internet that were in the $300+ range and started looking for materials. At first, I thought they were way over priced..then I started shopping for a piece of 1/4 or 3/8 T6 sheet/plate aluminum. The widest part of the tunnel plate is just under 13" and length ~44". I shopped around for the aluminum..well it's about a $200 piece in 3/8. I have a few friends that work in the collision repair trade and was referred to a metal distributor. The manager there sold me a piece from their "cut off" bin...basically odd pieces left over from other peoples purchases, just so happened they had a piece of 3/8 that was just the right size..I got it for $50 cash. I have another $50 in fasteners ( bolts, fender washers and lock washers). I'm in it for about $120 if you include the band saw blade I broke. Hint: when cutting aluminum with a band saw, some wd40 makes all the difference keeping it cool and lubricated. It's a trick I learned and forgot from a metal fabricator until I broke the first blade. The stock tunnel plate is not a real precise fit. The bolts that hold it up are 6mm the holes in the stock plate are like 12mm. There's a lot of room for error. I made mine a tighter fit than factory. Using the factory one as a template, I only had issue with 1 of the 36 holes/ bolts. I opened it up a tad while under the car and it's in now. It was off just enough to keep the bolt from starting. I cut it out on the band saw and cleaned it up on the belt sander with an 80 grit belt. It's not as perfect as a CNC machined one, but it's damn close and it didn't cost me $300. It's not something I would mass produce this way but I'm glad I made myself one.
I have mine in! I have not started it up yet...working on getting a LS6 intake ( I think I have that covered now) but leave Sunday to go out of town for 7 days..so it goes on hold for a week.
I tighten the headers down first...then loosely bolted the rest of the exhaust together starting from the header collectors and working my way to the rear. I went back to the collectors then tightened everything down starting from the headers and working to the rear. Exhaust tips are better aligned now than they were before.
Installing headers for me was choosing my battles. Instead of removing the starter, I opted to do the following:
- Followed exhaust removal directions as seen earlier in this thread
- Removed motor mount bolts (from the top i used a long extension and swivel, was cake)
- Lifted motor a bit
- Installed drivers side from bottom, slid in without trouble (have to remove ground strap)
- Removed passenger valve cover (everything was already taken off so what's 4 more bolts?)
- Slid passenger side header in from top (was cake without valve cover)
No need to remove starter or anything else on the passenger side. This made it very easy!
I finally finished wrapping this up. I've been out of town for work the last week and a half, which actually worked out well as it took me some time to find an LS6 intake manifold.
I drove it for the first time tonight...runs and sounds great! No CEL or any codes, all seems perfect. I have the high flow cat system with Borla Stingers.
It made 319 with just the Stingers and Halltech intake. It will be on the dyno again here shortly in the next few weeks for a tune. I'll update with those results.
TIP: When installing the intake manifold..I found that the little vacuum hose to be easy to hook up if you take the rubber 90 degree elbow off the manifold and hook it up to the little black hose first, then manipulate the 90 degree boot onto the intake manifold.
Question to the guys who have got these and have em on already, are they loud? Im wanting something decently loud, on my 02 z06 i had a custom set of long tubes with an x pipe and the B&B exhaust and i loved the way it sounded so much. I found a vid of this setup from front to back and it put me in mind of the B&B. Anybody else think the same? Thanks to anyone who can help me out, its hard to tell how something sounds online haha
Although I sell them, I also run them on my car and have heard multiple other sets in person and I will tell you that they will fit your bill and you will not be disappointed Here's my latest in car video from the track last weekend!
as for sound, i have strait catless resonators then strait pipes after the exhaust. and it sounds wicked. they've calmed down after a little break in on those muffler/resonators and while not super throaty, it's got a great rumble, and opens up to sound like an F1 car after 4500 rpm.
Originally Posted by zribkl69
ready to get started. What gaskets and header bolts are you guys using for best results. Any info would be helpful.
you can re use the multi layered steel gaset sthey are the best. i've used them on numerous F-Body header swaps and vette swap. they are awesome. same for stock bolts. they work just fine. that or you can go locking header bolts if you don't want to check your bolts after a couple of heat cycles.
I reuse stock header bolts on all the ones I have done and also use the included header gaskets without a single issue yet! I make my own "hooks" on the first and last bolts so I can hang them in after I get the bolts started
FYI... I would get a set of OEM gaskets in case. Mine fell apart when I did my install and I was glad I bought the gaskets as a backup, I HATE having to run and get parts during an install!
If you end up not needing it you can always return em...
Nice run, you must have a coupe as you were only in third gear at the finish. That is what I hate most about the Z at the track is the need to shift into 4th RIGHT before the 1/4 point. There is just too big of a change in the 3/4 shift on the Zs which I will be fixing with some custom gearing on the Vert when the Tranny goes and requires "upgrade". Judging by the shape and size of these headers they should be more top end oriented. I had a similar set on my Z before the LGs and it was a little better and louder at the 6k+ point. I have been debating a set of these for the Vert since it is a DD and the sound is nice. Best of all no cutting required. I just don't know if I will be able to handle a year where the DMV "Randomly" selects both of my LT cars to go to a "Test Only" Center
