Getting Fed Up!!! Please Help!!!!
Old Jun 26, 2010 | 11:17 AM
  #61
97Vette8531's Avatar
97Vette8531
Veteran: Marine Corps
Well thank you all very much for the help. I'm gonna try the ignition switch this weekend. I'm sorry about not mentioning the HVAC issue earlier, but I had been dealing with that for so long with no other issues with the car I didn't think of it until I noticed that when it worked so did everything else. As for not posting in tech, I have noticed that whenever I have issues if I post them in tech, I rarely get much feedback, so I tried posting here in general for more exposure. But in the future I will post in tech. I'll let you all know how this turns out.
Old Jun 27, 2010 | 01:26 AM
  #62
lucky131969's Avatar
lucky131969
Yep, you'd be surprised how things can be related. Bill Curlee's ignition switch repair is excellent. If there is something you need help with, or need service manual procedures.....send me a PM with your email address, and I'll send it to you in .pdf format.
Old Jun 27, 2010 | 08:17 AM
  #63
corvettedaddy11's Avatar
corvettedaddy11
I have an Autozone wiper motor works perfect,Parts are parts in Some cases!!
Old Jun 27, 2010 | 06:31 PM
  #64
97Vette8531
Well, I took the ignition switch apart a few hours ago, and drove around for a little bit. I noticed a few things. 1, the HVAC display comes on strong all the time, and works perfectly. 2, the door alarm dings all the time if a door is open, even if the key is not in the ignition. 3, the idle has evened out, and seems like I remember it being before. So I have a few more days of driving to do in order to be sure that no new codes come up, but I have a good feeling about this. I threw the red top on the charger to see if it holds the charge, and if it doesn't I'll just invest in a new one I suppose. I want to say thank you to lucky131969 and Greg_E especially because you guys sure got me going in the right direction. If either of you make it to the San Diego area, the beer is on me. Thank you all again.
Old Jun 27, 2010 | 07:01 PM
  #65
abigfoot's Avatar
abigfoot
Just because you throw a oxygen sensor code does not mean you have bad sensors. It means they are getting a reading that does not fall into specs. You should test before you change.
Example:I've seen lean mixture codes thrown out all the time, usually its a fuel pump. The chance of four sensors going out are slim.
Old Jun 27, 2010 | 08:10 PM
  #66
countslav's Avatar
countslav
Don't forget about PCFRED.......
Hope you got her fixed.....
Old Jun 27, 2010 | 08:55 PM
  #67
Speed Trap's Avatar
Speed Trap
This doesn't sound right. Maybe you just mis-typed the sentence. The door alarm should only sound if the key is in the ignition, at least that is how mine has always been.
It's very interesting that something as simple as an ignition switch can cause so many other symptoms. Definitely good info in this thread.
Old Jun 27, 2010 | 09:52 PM
  #68
97Vette8531
I agree that it isn't normal, my car has never made the dinging with no key in the ignition...guess I put something together wrong? But yeah, it now dings if the door is open with no key in the ignition.
Old Jun 27, 2010 | 10:12 PM
  #69
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Originally Posted by Greg_E
If the fuse is good, check the splice pack for a bad ground. The grounds for all four of the sensors are at splice pack 122.
what is that? the floor plans for your office building?
Old Jun 27, 2010 | 10:21 PM
  #70
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
According to this diagram, the fullback needs to pick up the inside linebacker which will open it up for a halfback sweep to the strong side.
By the way, it sounds like the OP is well on his way to getting this thing fixed. Yeah!
Old Jun 28, 2010 | 07:22 PM
  #71
69's Avatar
69
Cruise-In VI Veteran
Had this ghost key chime also. GM has a TSB on this issue.
TSB Here
http://www.corvetteactioncenter.com/...+from+Ignition
1997 - 1999: Service Bulletin: Chime Sounds When Key is Removed from Ignition
Subject: Chime Sounds When Key is Removed from Ignition, Intermittent Operation of Power Door Locks, Keyless Entry, Steering Column Lock or Memory Seats (Inspect/Replace Lock Cylinder Actuator or Lock Cylinder Assembly)
Source: Chevrolet Dealer Technical Service Bulletin
Number: 99-08-49-008
Models:
1997-99 Chevrolet Corvette, Malibu
1997-99 Oldsmobile Cutlass
1998-99 Oldsmobile Intrigue
1999 Oldsmobile Alero
1999 Pontiac Grand Am
This Bulletin is being revised to add additional symptoms and conditions. Please discard Corporate Bulletin Number 83-83-20 (Section 8 - Chassis/Body Electrical)
Condition:
Some customers may comment that the key warning chime continues to sound after the ignition key has been removed from the ignition lock cylinder. They may also comment that the automatic power door locks will not lock the doors when the key is removed from the ignition lock cylinder and the warning chime is sounding.
On Corvette models, some customers may comment that there is an intermittent operation of the passive keyless entry system, the steering column lock, or the retracting feature of the memory power seat option when exiting the vehicle.
Cause:
The actuator, located in the ignition lock cylinder, may be sticking after the key is removed.
Correction:
Remove the ignition lock cylinder for the instrument panel using the following procedures. Once removed from the vehicle, use the "Actuator Type Identification" and "Test Procedure" sections later in this bulletin to determine the correct repair procedure
