[Z06] matte black wheels
Old Jun 6, 2011 | 06:16 PM
  #41
007Duc's Avatar
007Duc
Originally Posted by jake07Z06
Yep! They are the stock 18x10.5 rims on all four corners. Handles on rails now.
Just finished bleeding the brakes tonight so Im hoping to get some good pictures tomorrow!
Old Jun 7, 2011 | 11:34 AM
  #42
jake07Z06's Avatar
jake07Z06
Originally Posted by BLKWDWZ06
guys did you need spacers for the brakes
I didnt use any and only had a slight rub on my front right wheel where the powder coat was a bit heavy, its fine now.
Originally Posted by KrispyZ06
What is your front tire size?
How much are you lowered?
Car looks great. Makes me wish I went black.
Thanks man, front tires are 295/30/18. Ive lowered the front all the way on stock bolts and used wcc rears but I would guess about 1-1.5 inches if not more on the rear.
Originally Posted by pql-lbc
Slight thread jack but still on topic...
For those on this thread who have gone with a C6Z brake conversion on your C5Z or are considering going this route, is it pretty much a direct swap out with our C5Z setup or will I need to purchase other parts (i.e. brackets/brake lines...) besides the obvious (calipers/rotors/pads)? I keep hearing something in these discussions something about the C6 caliper pins.
Please help a brother out. I just got some new TSW wheels (19/20 setup) and my stock calipers look completely lost inside these wheels. Thus my C5Z is crying out for new calipers...It's rather silly I know.
Make sure your offset is correct for caliper spoke clearance. But yes it is pretty much a direct bolt on, you will need brake lines though. I used the WCC kit and it came with everything you need including way more than enough fluid, hawk pads, and steel braided lines for a good price.
Old Jun 7, 2011 | 11:48 AM
  #43
jake07Z06's Avatar
jake07Z06
Pics are here!
Old Jun 7, 2011 | 11:52 AM
  #44
jake07Z06's Avatar
jake07Z06
...And some more
Old Jun 7, 2011 | 12:39 PM
  #45
hp_performanceparts's Avatar
hp_performanceparts
Wow that looks sweet!!! I have a black z06 and this is what i want to do.
So these wheels are the ones that came with the car correct? You just powder coated them.
Did you have to grind anything on the wheels?
Old Jun 7, 2011 | 12:40 PM
  #46
BLKWDWZ06's Avatar
BLKWDWZ06
looks killa
Old Jun 7, 2011 | 01:56 PM
  #47
jake07Z06's Avatar
jake07Z06
Yes and no. They are the stock 18x10.5 inch rear wheels on all four corners. The C6Z brakes deffinately WILL NOT fit under the stock 17x9 inch front.
No grinding was required.
Old Jun 7, 2011 | 02:11 PM
  #48
hp_performanceparts
That's what I figured.
How is your turning/cornering with the 18x10.5 in the front feel? Any issues?
Old Jun 7, 2011 | 02:43 PM
  #49
hp_performanceparts
Did you need any kind of conversion brackets?
Old Jun 7, 2011 | 03:50 PM
  #50
jake07Z06's Avatar
jake07Z06
Well when you consider that the zr1 has 285's on the front and im running 295's, its really not that big of a deal. No rubbing issues, not very noticeable hunting, and it handles on rails.
To your other question, no brackets, it bolts right up with the factory bolts even.
Old Jun 7, 2011 | 11:10 PM
  #51
envyz06's Avatar
envyz06
Looks sick!
Old Jun 7, 2011 | 11:43 PM
  #52
speedyhawk101's Avatar
speedyhawk101
Conversion Brackets are not required. They are a direct bolt on. just need wheels to clear.
Old Jun 7, 2011 | 11:45 PM
  #53
speedyhawk101
Jake the pics look awesome!! Nice job.
Old Jun 8, 2011 | 01:11 AM
  #54
pql-lbc's Avatar
pql-lbc
Thanks. The new setup looks awesome. Those calipers are huge compared to the stockers.
Old Jun 8, 2011 | 10:47 AM
  #55
jake07Z06's Avatar
jake07Z06
Thanks everybody, Im really pleased with how it turned out.
Old Jun 8, 2011 | 11:30 AM
  #56
007Duc's Avatar
007Duc
Yup, definitely doing this. I've already had conversations with speedyhawk for sources to make the tweaks I want, but the just of it is the same. Jake, the car looks killer. speedyhawk, thanks for all the help. I'd post pics, but my car will end up looking like yours. Although, I've had the lower body line around the exhaust on my rear bumper blacked out as well. Really excited about doing this.
Old Jun 8, 2011 | 12:26 PM
  #57
Number 23's Avatar
Number 23
No rubbing up front on the ducts even at fully turned?
To matte black wheels
Old Jun 8, 2011 | 02:38 PM
  #58
speedyhawk101
No Problem. Show the pics anyway.
Old Jun 8, 2011 | 03:23 PM
  #59
jake07Z06's Avatar
jake07Z06
Not that Ive noticed so far. Keep in mind that every tire is going to be different though.
Old Jun 9, 2011 | 08:33 AM
  #60
007Duc's Avatar
007Duc
Yeah, I suppose I will. It'll be a bit. I'm sure you remember, it didn't happen over night.
