Hankook update...
Old Jun 12, 2011 | 11:51 AM
dklowrider's Avatar
dklowrider
Originally Posted by Yello95
I now have a little over 500 miles on my new Hankook Ventus V12 evos and would like to report that it has been a pleasure so far...great handling, etc...don't know why I waited so long to get rid of the Goodyear runcraps
$604 shipped ...minus $60 rebate...plus mounting/Hunter roadforce balancing...
...forgot to mention putting on C6Z51 swaybars...wow what a difference in handling so far...now all I need is C6Z06 shocks...ooooooooooboy
ok, now back to the tires. what are you, or any others, doing about preparing for a flat? plug kit w/ compressor, slime or something similar? i just am having a hard time giving up the run-flats [not oem of course].
Old Jun 12, 2011 | 12:07 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Dale......ok...I thought about that a long time...I carry a plug kit and small compressor and scissors jack...the difference in ride is worth the small risk of a flat...another thought (learned from ET)...if I get a nail in the tire(usually the cause of a slow leak)...I will just keep putting air in the tire until I can get to a place to fix it
Old Jun 12, 2011 | 12:21 PM
dklowrider's Avatar
dklowrider
that seems to be the most logical way to go. i have never heard about the 'after' part when using a sealant. what's the main pain in using this stuff, what's the cleanup like when you do pop the tire off to be repaired. and you will have to do that. i never heard if it's a true slime almost like contact cement, or if it's a pain, but cleans up with soap and water or what.
Old Jun 12, 2011 | 12:40 PM
01vetter's Avatar
01vetter
All you Hankook owners, please comment on your steering response with these tires.
Old Jun 12, 2011 | 02:47 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
I have never use the canned goop so I can't comment on it...some say its ok and some say its not...
Old Jun 12, 2011 | 03:17 PM
Sinister-one's Avatar
Sinister-one
My hankooks have very good steering response ! I have no complaints about these tires.
Old Jun 12, 2011 | 04:08 PM
baxsom's Avatar
baxsom
I dont worry about flats, that is why i have AAA and towing insurance.
Old Jun 12, 2011 | 05:24 PM
95wht6spd's Avatar
95wht6spd
Well the Bilsteins I have are part of the Electronic Selective Ride system(FX3)...the shocks have an actuator on top of the shock...$3200 for new Bilstein shocks and new actuators...I may replace them with standard shocks...after 70,000 miles they are weeping a little so that means they may need replacing sometime in the future...biggest problem I have had is the rear leaf spring splintering over a damn railroad track...replaced it and 5 years later went over the same fkn track and broke the spring again...got a new one on order...
1. FX3, you can send to Bilstein like I did and get them rebuilt and custom valving if you wish for about $100 per shock. You can also get the actuators rebuilt by a co. on the web.
2. Don't go over those tracks ever again! What were you doing 100mph?
Old Jun 12, 2011 | 05:51 PM
dklowrider's Avatar
dklowrider
call me a worry-wart, but i've seen [and known] too many tow truck drivers that i wouldn't want touching my car. let alone the guy that you may be trusting to pop your tire off of that beautiful rim. at least with the run-flats i have a little leeway to find a place that i trust. that is the root of my turmoil.
Old Jun 12, 2011 | 06:32 PM
jd86L98's Avatar
jd86L98
Go with Bilstein sports. The Hankooks get better once you heat cycle them.
Old Jun 12, 2011 | 06:36 PM
jd86L98's Avatar
jd86L98
Not as good as the Verdesteins I had before but after a break-in canyon run last weekend, were I finally got some heat into the Hankooks it is better. The only reason I switched from the Verds was I wanted a 305 in the rear and the widest the Verds go is 295. Hankooks are smoother though. Overall the Verdestien is a better handling tire but I am happy with the Hankooks.
Old Jun 12, 2011 | 06:58 PM
BLKWDWZ06's Avatar
BLKWDWZ06
Originally Posted by steve8
I cannot believe the difference since ditching my oe runflats!
So smooth and quiet.
Went with 265-35-18 and 305-30-19.
same here and awesommmmme!
Old Jun 12, 2011 | 09:00 PM
  #33
OldGuard's Avatar
OldGuard
I also want to get away from the GY Run Flats but know one has explained how you get some sort of jack under the Corvette which is already very low to the ground after your tire has no air in it. I think your car will be too low to the ground to get anything under it so you can lift it so you can rotate the tire to plug it.
I also don't like the idea of someone you don't know or trust putting my corvette onto a flatbed truck.
Old Jun 12, 2011 | 09:51 PM
  #34
dklowrider's Avatar
dklowrider
you should be able to find a scissors jack low enough. someone has to make one that is flat enough to start out with.
Old Jun 12, 2011 | 09:54 PM
  #35
Z06ster's Avatar
Z06ster
I found this thread interesting... I will be putting Hankook's on my front and rears this week... I will report back (probably in a separate thread because there is a whole story about that...)
I also want to get away from the GY Run Flats but know one has explained how you get some sort of jack under the Corvette which is already very low to the ground after your tire has no air in it. ....
Good question....
Old Jun 12, 2011 | 10:07 PM
  #36
GHL4505's Avatar
GHL4505
I've always liked knowing I had run flats in case I picked up a nail and had a flat. Of course the GY run flats had their downside of being noisy, rough riding, very expensive etc. There has been a lot of talk about the non run flat tires and Hankook tires in particular. I checked them out and they looked pretty good for the price. Might just go that route myself. Who doesn't want to save $500 plus on tires compared to the run flats.
I was worried about getting a flat with the Hankooks until I gave it some thought about when was the last time I had a flat. Hmmm! It was about 22 years ago behind my shop. I walked out to get in the car and noticed the rear tire was flat. I walked back into my shop, grabed the air hose, pumped the tire back up and drove down the road to the tire shop. They had it fixed in no time and away I went.
Think, I'll get a small compressor, patch kit and scissor jack to carry in the car. Maybe a small piece of 2x6 to drive up onto to help lift the car so that I can get the jack under the car, just in case.
Old Jun 12, 2011 | 10:20 PM
  #37
Yello95's Avatar
Yello95
St. Jude Donor '11
Originally Posted by DFOR
Mind if I ask where you bought them from? That's a great price.
Discount Tire Direct
www.discounttiredirect.com
1-800-707-8473
Fast & friendly service
Sales rep was "Peter"
Order by July 30 and get a $60 rebate
Shipping was included
:cheers...PM me if you have any questions
To Hankook update...
Old Jun 12, 2011 | 10:29 PM
  #38
Yello95's Avatar
Yello95
St. Jude Donor '11
the firstime I went over them at 45mph...years later I didn't realize that they were the same tracks and they hadn't been fixed...so I again went over them at 45mph and bam....anyway if I ever go over them again I will slow down to 5 mph
Thanks for the info...I just may send them off to have them rebuilt
Old Jul 8, 2011 | 08:57 PM
  #39
hig4s's Avatar
hig4s
Originally Posted by GHL4505
I was worried about getting a flat with the Hankooks until I gave it some thought about when was the last time I had a flat. Hmmm!:
I have not got my Vette yet, but running with no spare could be a PITA if it didn't have run-flats.
The last flat I got was just two years ago, driving over a bridge in rush hour traffic in my 08 Jeep Wrangler. The TPMS warned me, but by the time I was able to safely slow down get over and get off the bridge (because there was no place to safely stop on the bridge) I had destroyed the tire. And this was an over sized off road tire, much less likely to get a puncture than super soft high performance tire.
Old Jul 8, 2011 | 10:02 PM
  #40
mcm95403's Avatar
mcm95403
Originally Posted by Dave68
Get back to us when you have 5000 miles on em. Hopefully, they will feel the same.
By the way, consider Bilstein shocks over the Z06ers. The Bilsteins are rebuildable but even before their first rebuild are likely to outlast any OEM shock.
I have about 9,000 on mine and still love them - in fact I love them even more now than I did when I got them. They work great in the wet and dry and they stick REALLY well. No complaints at all about these tires!
