Ramps?
Old Oct 23, 2011 | 01:05 AM
yaknow's Avatar
yaknow
I use a low profile 2 ton jack and jack stands, ramps a great for oil changes but, when you need to do brakes, shocks, or suspension work there nothing but a huge paper weight.
Old Oct 23, 2011 | 02:00 AM
Laser Guided's Avatar
Laser Guided
I just use these ramps I got from walmart for like 45 bucks. Since my car is lowered i have these 2 cement slabs that i put in front of them. No scraping or issues.
Old Oct 23, 2011 | 04:17 AM
1BAV's Avatar
1BAV
Cruise-In IX Veteran
I've tried all configurations listed in this thread, but nothing compares to the race ramps. If you're gonna be under the car very much, race ramps would be my recommendations. They're a little pricey, but I've been very satisfied with mine.
Old Oct 23, 2011 | 07:22 AM
chasboy's Avatar
chasboy
Oldtimer
I use Rhino Ramps and my car is not lowered.
I <thought> I picked up the 8000lb ones at the store, regardless, they are big improvements over the metal ones I used to have. Much wider, and longer run up.
Old Oct 23, 2011 | 08:54 AM
TorchRedRocket's Avatar
TorchRedRocket
I've never had an issue with the rhino ramps slipping. When you place them in position, just make sure you really wedge and push the start of the ramp up under the front of your front tires. This way, there is some weight and pressure already being placed on the ramps and they will not move one bit.
Old Oct 23, 2011 | 10:08 AM
warren s's Avatar
warren s
Rhino ramps are fine. If you dont like the front air dam scraping the ramp, you can make a ramp extender for a few bucks.
The Corvette tax is really steep on specialty plastic coated foam blocks.
Old Oct 23, 2011 | 01:27 PM
Zmeister's Avatar
Zmeister
Another vote for the Rhino ramps. I do all my own service and repairs....so far. I've had the Rhinos for a little over a year and they've been great. Advance Auto always has a coupon sale going on and you can get them for a great price.
Old Oct 25, 2011 | 08:04 AM
Fred@ReverseLogic's Avatar
0Fred@ReverseLogic
Former Vendor
The load rating on composite deck boards is probably about 100 PSF. It's not intended to be used in load bearing applications. Safety conscious DIYers choose Race Ramps.
A Corvette tax would be a premium charged to Corvette owners for the equivalent item sold at a lower price for other car brands. Race Ramps are the same price for any car. Using your analogy, Race Ramps buyers get a 50% to 75% tax refund when they no longer need the ramps. Super store ramps don't really have any resale value.
Super store ramps don't come anywhere close to comparing to Race Ramps. If anyone should appreciate the difference it should be Corvette owners who choose not to drive lesser cars.
Old Oct 25, 2011 | 08:17 AM
hammerdwn's Avatar
hammerdwn
Just jack it up. yeah a aluminum race jack will run $200. I think Sears craftsman has one for less than that. That is what i use and my car is lowered on stock bolts. Use jack stands and there is no problem. btw you can lift it up higher than ramps for more working room. JMO.
Old Oct 25, 2011 | 08:21 AM
warren s's Avatar
warren s
Thats totally ridiculous.
The space between the vertical supports on the "ramp extenders" is only inches and if it failed the wheel would fall 2 inches on the the Rhino Ramp. Been lasting just fine since 2001
Charging over $300 for a product that most likely costs a small fraction of that amount to manufacture in the hopes that the target consumer will just pony up the extra dough because they are perceived to have deep pockets is what I call a perfect example of the Corvette tax.
Old Oct 25, 2011 | 08:38 AM
rnelson11's Avatar
rnelson11
I built my own ramps following direction in the DIY thread on this forum. I used 2" X 12"s and I used screws to secure a piece of belting material to the bottom of the ramps. The belting material extends about 8" before the ramp so that the tire is on the belting before it gets to the ramp. This prevents any slipping of the ramps.
Old Oct 25, 2011 | 09:01 AM
gotz06?'s Avatar
gotz06?
I like the race ramps paid $300 for the 10 inch height. rhino are only about 6 1/2 inches and not wide enough for zo6 wheels. Just my 02
Old Oct 25, 2011 | 09:11 AM
  #33
warren s's Avatar
warren s
What size tires do you have? I just had an 04 Z06 on the ramps.
Old Oct 25, 2011 | 09:53 AM
  #34
0Fred@ReverseLogic
Former Vendor
Totally ridiculous? I don't think so. If the 5" wide deck board fails and the car drops 2" while the bumper is over the platform you will have incurred enough damage to have purchased a good set if ramps. There is a reason that the homemade ramps described on the forum from time to time are not made with deck boards. Maybe some engineers on the forum will chime in and explain this to us.
Anyone who ever priced manufactured products knows that the material costs of just about anything you buy is only a fraction of the total price. What do you think a superstore ramp that sells for $50 costs?
If superstore ramps were 10" high by 14" wide by 67" long they would sell for a lot more too. The volume would be lower, the distribution and warehousing cost would be higher, and the superstores would not carry them because of the low return per square foot of shelf space.
Oddly enough the people spending $500 for a set of our progressive incline Race Ramps with trailer ramp adapters or $800 for a set of 14' long trailer ramps are the most appreciative since they know any other alternative is too heavy and awkward to handle.
Old Oct 25, 2011 | 09:59 AM
  #35
tomringo's Avatar
tomringo
From: Richmond VA Everyone should have a VetteGuard
Not lowered - Use rhino ramps and some rubber backed rugs to keep them from sliding. Also 2x10's for the rears to get up on with the leading edge beveled and I put rubber backing in spots to keep those 2x10's from becoming air borne
Old Oct 25, 2011 | 10:20 AM
  #36
warren s's Avatar
warren s
You are really grasping at straws here. If the home made ramp extender fails, the plastic air dam will hit the ramp and bend like it was designed to do in the first place. Additionally, my simple creation is just one the the many variations to simply avoid the air dam from scraping, not that it does any damage if it does. Many Corvette owners that are more handy than me built their own ramps.
The fact still remains that there are many alternatives to spending between $300 to $800 for a similar product that is also available for one tenth the cost. Additionally that same $300 to $800 ramp if targeted to another consumer demographic, like say a Nissan owner would be priced much lower.
If some one wants to spend $800 for a set of ramps, then by all means go ahead. Corvette owners are a pretty resourceful bunch and my solution is just one of many. I am simply trying to point out an option to some one who wants to work on their Corvette, not make a profit from them.
Old Oct 25, 2011 | 11:07 AM
  #37
johnson-rod's Avatar
johnson-rod
I use Rhino ramps on grass. They don't move. The grass holds them.
I place a pair of 2x6s in front of them on the grass. The Rhino ramps hold the 2x6s.
I had 2x6 scraps from a remodeling project.
I drive the car up on the 2x6s and it picks up the front enough so the air dam wings don't scrape on the Rhino ramps.
Your experience may vary.
To Ramps?
Old Oct 25, 2011 | 01:30 PM
  #38
m6 c5's Avatar
m6 c5
FWIW race ramps arent targeted to just those with corvettes so saying that it has a corvette tax is incorrect. There are many people driving imports that would but race ramps as they offer a low approach angle that will allow lowered cars to get up without scraping. They also offer ramps that are extra wide to accommodate wide tires which wont fit on standard ramps. I actually purchased race ramps for my camaro as I couldnt use standard ramps to get the car up in the air to change the oil. Actually I cant use the race ramps without rubbing the front air dam on the vette just a little so I dont know how others are getting theirs up on other ramps.
Old Oct 25, 2011 | 11:55 PM
  #39
MarkyMarkGTM's Avatar
MarkyMarkGTM
Originally Posted by m6 c5
I personally think race ramps are worth every penny. I have never had one slip or anything, plus they are super light. I have had the standard ramps slip out from under the car while my dad was pulling up on them and shoot out across the floor right at me, after that I dont really trust them.
Originally Posted by SUPERCRUZ
Race Ramps - They are worth the investment. Light, easy to use, and low approach angles with no slip surface. No regrets spending the money for these.
[QUOTE=Fred@ReverseLogic;1579047874 Safety conscious DIYers choose Race Ramps.
...Race Ramps buyers get a 50% to 75% tax refund when they no longer need the ramps. Super store ramps don't really have any resale value.
Super store ramps don't come anywhere close to comparing to Race Ramps. If anyone should appreciate the difference it should be Corvette owners who choose not to drive lesser cars.[/QUOTE]
Besides price does anybody have anything bad to say about the race ramps that ACTUALLY owns them? Answer is no because they are awesome. There are zero issues with how they work and what they are supposed to do. No sliding, no set up or aligning the ramps, no laying down mats or adding 2x4s, no gimmicky crap. Just throw em on the ground and drive up.
Safety is NOT one of the areas where I try to save a dime, just not worth it in my opinion. Spend some extra money now, be safe, sell them when you no longer need them.
Here's a quick product review I did awhile back. I can't say enough about them. And like I said before, I haven't heard ANYTHING bad about this product from people that actually own them.
http://forums.corvetteforum.com/c5-g...with-pics.html
Car is slammed and no issues getting up or down
Old Oct 26, 2011 | 07:44 AM
  #40
Must_Have_Z's Avatar
Must_Have_Z
Couldn't agree more. Do NOT mess around when it comes to working under your car. Either invest some time and money into building the best, safest ramps possible, or buy a set *made* for cars like ours, specifically Race Ramps. Yes, they are expensive. But I got in on a group buy last year and the price was a little more reasonable. Then they sent me a coupon and I got a pair of their race roll-ups for the back after I dropped my car on coilovers (so I can get my jack under the rear cross member). It is incredibly easy to drive up on Race Ramps. No slipping or sliding whatsoever.
Here's a pic of my Z up on ramps, ready for the rear to be jacked up:
Here's a pic of the rear jacked up, higher than the front so the oil can drain completely:
