Traction control system failure caused accident
Old Dec 15, 2012 | 09:13 PM
Silverback51's Avatar
Silverback51
Originally Posted by Mattie Num Nums
I'm going to be frank and say you have no case.
I agree with Frank.
Old Dec 15, 2012 | 09:14 PM
Mattie Num Nums's Avatar
Mattie Num Nums
Originally Posted by Silverback51
I agree with Frank.
Frank Drebin?
Old Dec 15, 2012 | 10:23 PM
FD2BLK's Avatar
FD2BLK
I don't think you have a case but will say that the TC in my 01 C5 is terrible compared to the my 94 C4. I have had the C5 sideways a few times now with normal acceleration and have chalked it up to the crappy Cooper Tires that came on the car but the TC on my C4 would never let the rear tires spin more than a split second before engaging
Old Dec 15, 2012 | 10:26 PM
duramaxsky's Avatar
duramaxsky
There is a slight power difference.
Mattie Num Nums
Just slight though
Old Dec 15, 2012 | 10:33 PM
Michele Borja's Avatar
Michele Borja
Default Google it!
There is actually a lot of info on exactly what I inquired about. The same thing happened to me before this incident. To be clear, no I wasn't driving like an idiot & the weather conditions were clear. Thanks Vette family for your input - I guess. Happy holidays.....
Old Dec 15, 2012 | 10:34 PM
Mattie Num Nums
Unless the traction system some how caused your wheels to lock up or your steering to lock up and the weather and conditions are good, I just don't see how you have a case. Just being honest.
Old Dec 15, 2012 | 10:44 PM
Michele Borja
I'm going to see if there may be a code in the computer.......
Old Dec 15, 2012 | 11:10 PM
dblerman's Avatar
dblerman
You still didn't give us any information on what you were doing and what the car did before and when you "lost control."
All we know right now from your post is you wrecked the car because the TC system failed to engage.
Old Dec 15, 2012 | 11:23 PM
OKZ06's Avatar
OKZ06
St. Jude Donor '13-'14
Family doesn't always sugar coat things.
Here is a video reenactment of it
http://www.ebaumsworld.com/video/watch/82962511/
Old Dec 15, 2012 | 11:26 PM
TheoZ's Avatar
TheoZ
.... I believe that the Traction control system disengaged/failed causing me to lose control. Is anyone aware of a class action lawsuit based on this?
Uh .... no.
Old Dec 15, 2012 | 11:41 PM
duramaxsky's Avatar
duramaxsky
Ricers
Old Dec 15, 2012 | 11:42 PM
  #33
mdiiulio's Avatar
mdiiulio
Wow, everybody pile on...
Sorry, but I have to be the devil's advocate...
First off (using a legalism to relate to this) eye witnesses provide the most inaccurate testimony. i.e. he probably wasn't staring at the DIC when this occured, he was probably trying to save his car, and therefore doesn't know what the hell was exactly going on with AH/TC at the time. More info from the OP would help this immensely.
There are a few things (malfunctions) that will cause AH to activate on a good warm dry straightaway. One example: if your steering wheel position indicator is failing, the EBCM may receive a faulty signal. If the signal is off enough, the sensor may incorrectly detect a commanded turn (thinking you turned the wheel) even on a straight section of road. The EBCM will then expect a corresponding signal from the yaw sensors. When it doesn't get that signal (you're still straight) it will activate AH trough differential braking in an attempt to achieve that signal. This will be seen by the driver as an uncommanded and unanticipated activation of AH and a jerking motion of the car to one side or the other. If severe enough, it could theoretically cause an accident, especially if the driver overreacts to it.
Old Dec 15, 2012 | 11:45 PM
  #34
duramaxsky's Avatar
duramaxsky
The car is a 98 so it may or may not have active handling. It came out mid year in 98. My 98 does not have it.
Old Dec 15, 2012 | 11:51 PM
  #35
James2002z06's Avatar
James2002z06
Default Question
For the owners that have these issues with their traction control can't they just push the button and turn it off ?
Old Dec 15, 2012 | 11:52 PM
  #36
Dave68's Avatar
Dave68
Actually, in a comparison test against the Porsche Boxster, Mercedes AMG SLK, and the BMW M roadster, Car and Driver editors described the active
handling of the 01 C5 was equalled only Ferrari's best.
By the was the C5 very won the comparison test.
Old Dec 15, 2012 | 11:58 PM
  #37
TheoZ's Avatar
TheoZ
Sorry. Didn't mean to take part in a pile on. But I would like to know what the symptoms are of a malfunctioning Traction Control. A loud screeching noise? Tire smoke? Perhaps followed by a loss of control should an imprudent driver not recognize these symptoms in time?
Hey, I hate for anyone to wreck their Corvette. But come on .....
To Traction control system failure caused accident
Old Dec 16, 2012 | 12:06 AM
  #38
CactusCat's Avatar
CactusCat
I have a 98 also. Has TC but no Active Handling. OP, why don't you give us some more info as to what exactly happened and why you think that the TC could have been the reason for your accident. Your details are pretty sketchy....
Old Dec 16, 2012 | 12:10 AM
  #39
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Frank Drebin?
Or Frank Zappa?
Dayummmmmmmmmm
Old Dec 16, 2012 | 12:13 AM
  #40
CBZZZC5's Avatar
CBZZZC5
Drugs are bad. Don't do drugs.......................and drive
