LED Reverse Bulbs Question...
You will notice in the wiring diagram I provided, that there is a second wire that comes off of Pin F9 that goes to to the ABS. On Active Handling equipped vehicles only, the ABS module uses an input from the backup switch.
I'm not sure if autodimming mirrors were even a factory option in 2000, but they don't show up in the manual I have to look at here. But on later MY of Vettes, the backup lamp circuit coming off of the relay has a second wire that leads to the autodimming mirror, to turn it off when the car is in reverse.
As a quick check, I might suggest individually unplugging the reverse switch connector, the connector off the ABS and the connector from the autodimming mirror, to see which device is at fault.
Also for the record, no reverse camera or anything else. Completely stock.
30 - 0.00 Volt
85 - 0.00 Volt
86 - 12.4 Volt
87 - 12.3 Volt
87A - 11.1 Volt but somewhat variable.
Seems 87A is the circuit coming from the Trans Switch. In normal condition, the relay should be set to that connection and there should be no power coming into 87A until reverse is engaged.
I guess the next step is to replace the switch and see if that does the trick.
Thanks ALOT!!
Also, I believe the reverse switch is a ball check type switch that screws into the transmission case. I am curious if adjusting it (backing it out some or screwing it in further) has an affect.
30 - 0.00 Volt
85 - 0.00 Volt
86 - 12.4 Volt
87 - 12.3 Volt
Thanks ALOT!!
I guess my thinking is, this backup switch is like $20 so seeing its the original, I might as well give it a shot. I do however think you are correct about it being sensitive to how deeply you adjust it. I figured I'd check continuity across the leads when installling to make sure its set correctly.
If this doesn't work, then its going to get tougher. Thanks again for your help!
When you see an 80 watt rating on LED's, that only refers to the equivalent output compared to the traditional incandescent you are replacing. For example, the stock 2057 bulbs draw ~27 watts which is around 2.25A. These 80 watt LED's draw approx 700mA which is over 3 times less.
The value of LED's are greater output, with less draw and heat. In my case, I live in a very rural area, big trees, etc, and it's impossible to see behind you with the stock set up. Going to the Adjure helped alot, but I did not want to risk going to a higher wattage and hotter incandescent bulb and risk heat damage. The LED's offer tremendously more output and run much cooler. A total win-win.
Regarding my issue, this is NOT an LED issue! This situation is merely warning me that I have an underlying issue that the stock incandescent were not sensitive enough to display. I'm actually happy that I'm getting to the root of the problem and taking care of the issue.
I hope this helps.
Based on what I've seen with LEDs, the wattage is not based on actual power draw but a luminous comparison to an equivalent filament-type bulb. In this case, an 80w LED bulb would be roughly 3X as bright as the factory bulb.
I hope this helps.
I had a "situation" when I installed LED taillights. Loved the way they look, but for some strange reason the left outside light would always flicker or "bounce" when i activated directional signal. Then the entire brake light went out. Then it came back on again. Was about to return them. But just for the helluva it, I switched the left outside & left inside lights. (And keep in mind all 4 LED taillights are exactly the same). Guess what? No more issues! It's been over 2 yrs & they function perfectly! No one could figure out why.
As someone mentioned above, sometimes cleaning the socket, and slightly sanding any imperfections on the contacts help. So, does simply swapping the LEDs to different sockets too. It's just a function of taking a close look and seeing if it's an easy fix. But again, the tolerance and quality of these LED products are getting better and better, so you don't see these kinds of problems as much anymore. But, it is important to also look at the old sockets to see if they might need some attention too. It's all about having a solid contact.
The sockets were in great condition. It was really strange, the Halo Taillight would work perfectly in other positions....so you would think it's not the Taillight, it's something with the vehicle. Yet when I swapped the 2 Taillights, it worked perfectly in that left outside position....so you would think it's not the vehicle, it's the Taillight. Weird!
