my first corvette, my first "build" thread
Old May 8, 2020 | 11:35 AM
  #541
2k2wranglerx's Avatar
2k2wranglerx
C5 of Year Finalist (performance mods) 2019
So after talking to BTR and doing some more research on the morels. It looks like their recommended preload is .035-.060
I'm at 7.330 fully collapsed. if i do a 7.275 pushrod that puts me at .055 preload. So that's what i'm going to.
Old May 10, 2020 | 10:11 PM
  #542
2k2wranglerx
Alright. So good news is with the shorter push rods it fires right up. The knock is gone. Its good to go!!!!
Bad news is these are too short lol
Hopefully the last set ordered for Tuesday and I can be done haha.
But im getting there. Learned a valuable lesson. Or three.
Old May 11, 2020 | 08:56 AM
  #543
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
I applaud you for illustrating the mistake that was made for our benefit.
Old May 11, 2020 | 09:15 AM
  #544
2k2wranglerx
Some guys get embarrassed but I mean... we all start somewhere.
I've never done this on an LS before. and guys that give people a hard time usually pay shops to do their work lol.
I won't lie, when i thought this was the clutch i legit considered how much it would be to have a shop pull it and redo it... but then i was like... This is my project car. and i've turned every nut and bolt on this thing... No reason to change that now.
new pushrods are on the way. Should be here tomorrow. Then hopefully i can wrap this thing up and get it ready for the tune! Not gonna lie... once i found out this was a pushrod length issue and not a clutch issue my stress level dropped DRAMATICALLY lol. I really didn't want to pull that trans again haha.
Old May 11, 2020 | 09:36 AM
  #545
Toys4Life C5
St. Jude Donor '21
Agreed 100%. Turning your own wrenches is very satisfying.
There are those days you want to jump out a window, but once you solve the issue - all is good!
Toys.
Old May 11, 2020 | 10:49 AM
  #546
jrob56's Avatar
jrob56
Awesome work brother, and thanks for sharing again. The good build threads really do show the good and the bad, not just the highlights.
Old May 12, 2020 | 09:02 AM
  #547
2k2wranglerx
Thanks guys,
Ya i try and be honest with my mistakes. Nothing drives me more crazy than when people defend something because it's what they have lol.
Also, found out the heads are off an 06 CTSV. so they're off an LS2. so they don't have the sodium filled valves. no big deal. Still an upgrade from stock ls1 heads
New pushrods are out for delivery. so i'll toss those in today and hopefully have a fully running/functioning car!!!! now i just have to get the stupid clutch inspection plate back in haha... sigh... that's gonna suck (have to pull mid pipe and hang the headers lower to get it in...
I'm so tempted to cut it in half so i can get it in without pulling them lol.
Old May 12, 2020 | 12:53 PM
  #548
jrob56's Avatar
jrob56
Thanks guys,
If you are anything like me, youll probably regret later not putting it back in one piece.
Old May 12, 2020 | 01:44 PM
  #549
2k2wranglerx
HAHA ya i know me... and I'll go down and be all like "f it i'm just going to cut it in half" and i'll get under it and go "sack up Ry and get this thing done" lol
Old May 12, 2020 | 05:26 PM
  #550
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Looking forward to your progress report. Sodium filled valves are overrated anyways.
Old May 13, 2020 | 09:19 PM
  #551
2k2wranglerx
I think these heads are going to have to come off.
7.300 has lash 7.350 pushes on the spring.
I'm thinking that something is up with the lifters either i messed them up with the 7.4s or theyre just stuck.
Sigh.
Old May 13, 2020 | 10:25 PM
  #552
dskinsler83's Avatar
dskinsler83
My fear is damage from driving it with it ticking like it was. Have you pulled the valley cover or oil to see if there may be any damage to the cam or anything else?
Old May 13, 2020 | 11:07 PM
  #553
2k2wranglerx
No not yet. This whole time I thought I was chasing pushrod length issues. Intake is probably the next step and then heads. I know if there's an issue it doesn't take long to fubar the cam. But I don't think I hurt it yet. I do think I may have messed up the lifters. Or they were always messed up. Hqrd to say... i may run down and pull the intake now lol
Old May 13, 2020 | 11:40 PM
  #554
2k2wranglerx
cam looks ok. You can see where the roller rides but it's smooth and everything. Looks way better than the one I took out haha
Old May 14, 2020 | 12:14 PM
  #555
dskinsler83
Ok. Next check your oil and plug to be sure a bearing hasnt failed completely also. Did you say one of the rockers was loose when you pulled your valve covers?
Old May 14, 2020 | 12:54 PM
  #556
2k2wranglerx
They all have lash when on base lobe. But when I step up from a 7.300 to a 7.350 it compresses the valve spring.
So either they're all stuck or i dunno. Everything points to lifters. I ordered some ls7 lifters and trays
Old May 14, 2020 | 01:06 PM
  #557
2k2wranglerx
Double post
To my first corvette, my first "build" thread
Old May 14, 2020 | 01:42 PM
  #558
jrob56's Avatar
jrob56
Hate to see it, fired up youtube this morning with coffee and saw your channel and intake off and was like "well ****".
Old May 14, 2020 | 03:24 PM
  #559
dskinsler83
I meant loose as in no tension on the push rod. Floppy with your finger. If you are changing lifters I dont think LS7 is best but they will work if set up right.
Old May 14, 2020 | 03:29 PM
  #560
dskinsler83
The youtube video feom Scruff’s Garage shows how to make a solid lifter and how to measure for zero lash woth your tool on base circle. Then based on what the lifter manufactures recommendations for preload you add that length to the checker length and get your pushrod length if I remember correctly
