Rearview mirror camera
Old Apr 9, 2024 | 03:54 AM
  #41
22229stingray81's Avatar
22229stingray81
Originally Posted by Black_Valkyrie
Use it every day. No issues. Only change made was adding a little double sided tape to the top of the rear camera to hold it at the correct angle. For whatever reason closing the trunk would refocus the camera a bit and that solved that. All good. It's a great upgrade.
Can you recall which fuse you piggybacked off of for the yellow “B+” wire? I used the accessory fuse (#11 if I recall) for the rearview, red lead. Thanks!
