Old Feb 20, 2015, 01:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
How to replace TPM Sensor Batteries
Old Mar 7, 2005 | 11:29 PM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
Originally Posted by Bill Curlee
Is there any way that you can completly disassemble and display the workings of one of your bad sensors that failed the repair. I'm dieing to see what is inside one of those suckers!
Thank you so much for your efforts and sharing this with us!
Bill Curlee
That`s my next project...total disassembly!
Old Mar 13, 2005 | 07:58 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Default Potting compound
here's a link for potting compounds.
Epoxies.com
I'm sure that they have something that will work.
Old Mar 13, 2005 | 09:11 AM
jimcork1's Avatar
jimcork1
Default Soldered?
The battery leads, are they just touching or spring held on the circuit board? thanks 99 Nassau Blue.
Old Mar 13, 2005 | 09:18 AM
RPOZ4Z's Avatar
RPOZ4Z
they are soldered to the board.
Old Mar 13, 2005 | 12:26 PM
jimcork1's Avatar
jimcork1
Default What turns on the sensor
The sensor doesn't read until the car is about 20 mph. Is there a switch in the sensor or is this just in the car's program. The reason for asking ,, is,, are the batteries on all the time much like a computer,, or do they turn on only while driving.
I will be changing tires w/in the next year and have to change the bat's in the sensors,, now approaching 7 years old. Just might do it myself. Thanks for the great info.. 99 Nassau Blue.
Old Mar 13, 2005 | 12:34 PM
12stepvette
I`m Guessing here, since I`ve not found a Schematic for the sensor...To conserve batteries, I believe the sensors come to life at tire rotation.
Old Mar 13, 2005 | 07:43 PM
flash134's Avatar
flash134
St. Jude Donor '05
Thanks for all you guys sharing this info, i posted this question yesterday and find this post today, excellent.
Old Mar 13, 2005 | 08:50 PM
Sentinel's Avatar
Sentinel
Excellent Thread.
For attaching the battery to the metal clip, I wonder if this product
would work...http://www.frostfighter.com/ff_pdt_2000.htm.
I used it to reattach my defroster clip after it broke off. Good for
applications where the intense heat of a soldering iron might damage
the surrounding area. It's a 2-part mixture of adhesive and liquid
silver which conducts electricity. Dries as sturdy as a soldered piece.
Old Mar 13, 2005 | 10:00 PM
12stepvette
Originally Posted by Sentinel
Excellent Thread.
I dont see why that wouldnt work!!
Old Mar 14, 2005 | 09:38 AM
jimcork1's Avatar
jimcork1
It would be interesting to use a defective battery to see if tabs could be soldered. I do this with the NIMH batteries I use in my R/C hobby.
Old Mar 18, 2005 | 12:01 PM
ericdwong's Avatar
ericdwong
Anymore info on this? Esp of the DigiKey battery? I wonder if there is a kit you can buy to "weld" those straps onto the battery without destroying it.
I just got Y2K chromies, and am going to transfer over my tires and sensors. But seeing as how my car is a 1998, with 85K miles on the original sensors, I'm betting they will die sometime this year, so now would be the opportune time to change them out.
In the meantime, I'll dismount my tires, yank the sensors and them mount my snow tires back on my car temporarily. Isnt there an O ring that should be replaced on the sensor?
Also, any other recommendations on the Potting material? JB weld is a little too permanent for me.
Old Mar 18, 2005 | 12:11 PM
2KVetteMan's Avatar
2KVetteMan
Great work. This info is valueable. I just got a new sensor and going to remove the old. My be a good experiment.
Old Mar 18, 2005 | 01:59 PM
  #33
yellow01's Avatar
yellow01
A few drops of Nitric on the mold just above the battery should open up a nice hole if you have any of that laying around That's what we use to 'decap' our ICs.
Old Mar 18, 2005 | 02:01 PM
  #34
ericdwong's Avatar
ericdwong
Where can you get the replacement O rings? Just a generic O ring or is there a specific GM part?
Old Mar 18, 2005 | 04:48 PM
  #35
RPOZ4Z's Avatar
RPOZ4Z
wher can you get the Nitric?
Old Mar 18, 2005 | 05:08 PM
  #36
lost's Avatar
lost
The o-rings are standard hardware store items, not positive about the size, but Corvettes of Houston just gave me four though I was buying my tires from discount. Do a search...
Old Mar 18, 2005 | 07:42 PM
  #37
RCK1999's Avatar
RCK1999
GM does make an actual o-ring for the old sensors. Most dealers don't even stock them becuase of the "corvette factor" in their pricing. One O-ring from a dealer is about $2. The exact same thing from a hardware store is about $.05. I replaced the O-rings when I swapped wheels. The dealer didn't have 4 in stock. I whined to the parts guy so he went back into the garage and pulled four plain O-rings from their shop supplies and gave them to me for free!
To How to replace TPM Sensor Batteries
Old Mar 19, 2005 | 02:21 AM
  #38
Greg'sC5's Avatar
Greg'sC5
Default Tire Sensors
I had three of four working and tried to retrain. Now I have the left front and that is it. No XXX, just nothing. Is that the batt or what. I have not changed them but why did they work before?
Old Mar 19, 2005 | 05:26 AM
  #39
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds like there not training. I would use a different magnet and keep trying.
BC
Old Mar 19, 2005 | 10:32 AM
  #40
Greg'sC5's Avatar
Greg'sC5
Default Sensors
Thanks Bill. I will try again today. I have heard stories of owners buying new sensors and not being able to retrain.
