Well I've replaced 2 of 4 sensors right now as preventative maintenence since I'm switching over rims. This is what I've learned so far:
The Digikey batteries work well. I bought 10 of them, since I have 8 sensors total, and 2 incase I screw up a battery (already did) and 10 is slightly cheaper per unit.
I found that removing the potting material was fastest and easiest/cleanest with a dremel with the wire brush attachment. Wear a mask/respirator cause it turns that material into fine dust. And then, use compressed air to clean it off.
Important step- be sure the tabs are completely desoldered. I ruined the first one and tore off most of the conductive contact strip off the circuit board. Fortunately I was able to repair it with a crap load of solder. Hopefully it holds.
Also, be sure to test that the sensor is working before you glue it all up.
I'm using this epoxy stuff from Home Depot, it is a 2 part paste that is dark grey so it matches the color. I will report tomorow how well the material works after it dries.
Well its done. The stuff I sealed the TPS's back up with is called PC7. It dries almost the right color, hardness feel and it appears to be removable with wire brush should I need to do it again.
I got my Y2K chromies mounted and balanced today with the new TPS that I had serviced. They learned fine and upon my first road test they appear to work accurately. Hopefully they will hold (crosses fingers!). This forum has been a wonderful resource! Probably saved me $200+ for when my sensors started dying.
That material on the back of the sensor looks like that rubber you buy in the hardware store to make thr rubber handles for tools. I have used it before to rubberise the handle of a pair of pliers and it sticks very well while it is still pliable. Anyone know what I am talking about?
Luis
Well I tried it. It still didn't work. I ended up buying a new one from fred beans. I noticed that the new one had something rattling in it, where the old one did not. Perhaps this rattling ball is what activates the TPM when the car starts moving. So it is my assumption that if your TPM does not sound like it has a rattling ball inside, then the battery is not the problem. Does anyone else know about this?
Hmm thats strange. I think 2 of mine did have the rattling sound, the other 2 did not. I had a 100% success rate on replacing mine, and they still work great.
I have 4 extra tire sensors, all made in 1998, and none of them rattle. All of them still work, including the one that I replaced the battery in. I know that people have been replacing batteries in these things for some times. Does anyone have any long term experience with sensors after battery replacement, including those replaced by Neri Creations. Also,deveaum , you might want to recheck the sensor that you replaced the battery in. When I first replaced the battery in mine, it initially failed to work. However, after setting for a while, the BCM was able to learn it quite easily.
Just found this, this is great! I was wondering if a liquid rubber would be a better potting material for the reinstallation? I was thinking of the can of liquid rubber you can buy at tool shops that you dip the handles of your tools into to give them a rubber handle. I've seen it at Sears and Walmart and HD and Lowes. anyway, this is so cool! And saved!
I suspect that that that the liquid rubber would work fine. I was not able to locate the PC7, that others have reported using, but did find something called "Liquid Electrical Tape" at Home Depot. This is a solvent base rubber like material. The only problem is that it requires several applications to fill the cavity around the battery since the material shrinks upon solvent evaporation. The end products resembles silicone rubber but is somewhat stronger and stiffer. It should be easy to remove if battery replacement is again required.
One thing to consider when selecting a potting material is it's electrical conductivity. A conductive material will eventually drain the battery since it is in contact with both positive and negitive sides of the battery.
yes it could be used, but if the epoxy is too hard you may loose the option of changing batteries again, so you would want to use a "softer" potting material.
