- How to Replace Battery
Step by step instructions for do-it-yourselfers.
Browse all: Engine and Powertrain
How to replace TPM Sensor Batteries
Luis
I did one thing different. Once I removed the potting material, I carefully lifted the battery and with a very slender screwdriver I was able to pry loose the metal straps from the battery. This left the straps attached to the circuit board.
I bought a product from www.frostfighter.com, mentioned earlier in this thread. This is an epoxy which contains silver so it will conduct electricity. Put a good dab of this on the bottom strap, which is the positive side, then place the battery positive side down on to the epoxy and strap. I let it set for about 3 hours. I then used the silver epoxy to attach the top strap, which is the negative side and let it set for about 3 hours.
Don't get sloppy with this epoxy because it can short out the battery.
Tested for volts at the soldered straps at the circuit board to make sure I had 3 volts. It checked out fine.
Bought PC7 at Home Depot, found it in plumbing department, and used it as a potting material to re-seal the sensor.
Also found the #9 O ring at Home Depot, in the plumbing section, for 23 cents each.
Bought the CR2477N batteries at www.batterystation.com for $4 each and had them in just a few days.
Once I find the thread to re-learn the sensors I will see if it all works out OK.
Not a hard job and spent about $ 70.
what????
are you crazy!
have a replaceable battery on the tire pressure sensors?
It makes more sense to make them non serviceable so that they can CHARGE us over $100.00 each for NEW ones!
It will also give you a service car soon message and a DIC message.
You will have to clear the message every time you start the car.
BC
TIA
Plasti-Dip...Thats the stuff you guys are referring to !
http://www.plastidip.com/home_solutions/Plasti_Dip
BTW, great thread, I assumed non rebuildable wasnt to be fact, anyhting is rebuildable with enough time and knowledge.
