cold air intake
Thanks,
Kent
Halltech TRAP with cold air option: This design can bring cold air in through a “Tunnelport” cutout (where the license plate would reside) that provides the shortest ram-type air path to an air filter, compared to all the rest. Its Warhead filter can only be described as "Massive". Not the easiest thing to install.
Vararam: Brings cold air in through the fog light panel area to a panel-type filter. Downside: Eliminates engine bay-cooling air that would've come in from the fog light panels (Z06 or coupe/vert with opened-up panels), so the engine bay may end up being toastier.
Vortech Rammer: Brings cold air up from in front of the radiator and into an enclosed box. Its filter is quite a bit smaller than the Halltech Warhead or Blackwing unit.
Callaway intake system: This one relocates the MAF so that it is just in front of the throttlebody. It directs cold air from underneath.
K&N FIPK: This is more of a semi-cold air system, as the cold air intake opening is more of a slit. However, it is configured similarly to the Halltech Stinger-R and is 50-states legal. $350
Warm air systems: (Easy installation)
Halltech Stinger-R: Not only contains the massive Warhead filter, but also includes a larger-than-stock airbridge and smooth throttlebody coupler. For $239.00 or less, this system represents the best bang for the buck. Fortunately, for about $40, you can add cold air induction. See my procedure at http://www.conceptualpolymer.com/corvette_c5_corner.htm
Blackwing: Includes just a large filter, but an excellent one at that. Its cost is close to that of the Stinger.
Volant Twin Cone: This system gives you more open filter surface area than any stock box does and is well suited to an engine bay that gets cold air in from the fog light panels, as the filters are more or less in the air flow path.
How good are they? My experience has shown that most will bump up RWHP by at least 10. The advantage of having cold air is that power will not be "dialed down" under normally hot underhood (and intake air) conditions. You could easily lose 10 HP with a warm air system after engine bay temps rise during slow-moving conditions. Cold air prevents this from happening.
I gained a substancial amount of power from by Blackwing. approx 12rwhp (10 on one dyno(a Mustang), 14 on another(A Dynojet) ) Did the Vararam install and it was amazing the difference. This is where I will disagree with Dave. It got better (stronger) as the speeds increased.
Racing my Brothers 03 Cobra with the blackwing I would give up 4 cars to 130 from a 45 roll. With the Vararam it was down to 2 cars and Like I said it felt MUCH MUCH stronger especially over 100. Did not dyno it as I wanted to use that extra $80 to mod in preperation for my H/C install. I drive this car very hard, very often and with all the track times I have had with it know when something is very different and the Vararam did that for me.
These after market systems WILL give you additional power.
The Vararam, Halltech Trap, Halltech Stinger, and Blackwing are your best systems in that order.
Enjoy
I don't think the stock box will fit with the Vararam ducts in place Shurite.
The reason I believe this is because during my install, I forgot to remove the two studs from the frame of the car which hold the stock airlid in place.
The Vararam ducts are right up against these studs and reinstalling the stock box at this point would be difficult if not impossible with the ducts in the way.
The Vararam is a good system (provided all leaks from ill-fitting components are taken care of), but for far less money, a CA resident can get an easily swappable system, add the cold air mod, and end up with 99% of the power gain and none of the hassle of trying to find a "look-the-other-way" shop.
Your stock air intake on a C5/Z06 is pulling mostly static and and some light turbulent air from under the front fascia, but at speed it is pretty close to ambient air temperature.
It is not as restrictive as it looks at first glance, if you pull off the front cover and remove the air filter element you will see the many additional paths that air flows into the filter box from behind and the sides of the box.
Don't fall for the 'RAM AIR' effect that some vendors claim, here is a formula for ram air pressure in PSI:
Pra = MPH squared x .0000176 [a constant]
70 MPH = .09 PSI
140 MPH = .35 PSI
288 MPH = 1.46 PSI
In short, the intake systems you see that promise HP gains over stock are misleading at best, downright fraud at their worst.
Do you think GM would have spent the time, money and engineering resources to increase the 2001 Z06 from 385 to 405 hp for 2002 [by only 20 hp!] which involved changing the intake manifold, the heads and the cam, if they could have gotten 35 MORE hp just by installing a modified air cleaner?
But if you believe an aftermarket air cleaner will give you 35-43 more hp above stock, what can I say... ? =;-]
http://www.vararam.com/reality_of_ram_air01.html
Did you notice all the mispellings and poor grammar on that page?
Did you notice how many times they change the car speed at which the Vararam begins producing *boost* above 1 bar?
Or is there some "validity" in the Blackwing? He must have been looking for a performance increase by doing so. I wonder what scientific evidence he relied upon to determine if it gave any improvement over the factory stock airbox.
