Coumn lock survey
For us MN6/MN12 folks, If GM removes the Column Lock,, we will not have ant Theft Deterrent system left. All the recall does is add a software change that tells the PCM to "CUT THE FUEL" in the event that the column is lock and the car is moving. So,,,,,,,,,not only are you screwed in the fact that you cant turn the wheel, the engine wont run!
The column lock takes care of the problem! PERIOD! I got BIT while I was at Carsile PA 2 yrs ago in my 98 Coupe. NEVER AGAIN! Column Lock is in the 98 and,, have had the recall done on my 02 Z06 and the column lock was installed a week later!!! It's working fine!
If you live close to me I will install it for you if you dont know how! How's that for service!
Bill C
Bill C
John
BC
Here is a nice thread to explain the whole issue if you havent seen it already.
The basic conclusion is:
Auto cars: go to dealer, have them remove the locking plate, install the harness K.
Manuals: get the column lock bypass. I just saw it for $45 on Thunderracing.com. This is the cheapest I have seen.
No worries
I had a ride home and ordered the bypass and installed it, havent had any problems out of it. A very must purchase if you have a M6.
Bill
Fired up my 2004 6-speed convertible after the winter nap and noticed the LCD display saying "Service Column Lock", but the whell was still free to move. Looks like my first trip this spring is to the dealer.
Will be installing the kit real soon.
Scott
Well, not since the recall doesn't fix the problem...
Bill Dearborn: Wait until your battery starts to die.
BC
Thanks for your kind offer to install bypass. IF I was closer I would be tempted to take up your offer. the instructions I've seen and read still make me hesitate. Has anyone had a shop perform it. I live about 20 miles SW of Boston. (Obvioulsy the shop needs to know this fix well or I wouldn't trust them). Actually, I meant to confine my poll to MN6 only since the recall works for automatics.
