Is 100% coolent OK
Old Jun 11, 2005 | 07:32 AM
sam123's Avatar
sam123
Cruising
Default Is 100% coolent OK
I did the 170 thermostat mode and flushed all the old coolent out of car.
Replaced with pure coolent. What if any are the props or cons. Or should I have gone 50/50
sam
Old Jun 11, 2005 | 07:53 AM
IM QUIKR's Avatar
IM QUIKR
COOLANT and no. 100% coolant is not desirable. In order for it to work as designed it must be 50/50, mixed with distilled water. You can buy it from the grocery store for $2 a gallon or risk thousands of dollars in repairs later.
Old Jun 11, 2005 | 07:56 AM
leaftye's Avatar
leaftye
NOOO! Antifreeze is really only good at preventing freezing, boiling and corrosion, but not that good at cooling. If cooling is your primary goal, then a high ratio of distilled water with a bottle of Water Wetter is best, but you're probably better off (safer) with a 50/50 split of antifreeze and distilled water.
Old Jun 11, 2005 | 09:13 AM
vetterlatethannever's Avatar
vetterlatethannever
Made for 50/50 mix.
Old Jun 11, 2005 | 09:25 AM
97 BBB C5's Avatar
97 BBB C5
with leaftye...50/50 mix with 2 bottles of Waterwetter and you'll see big difference in temp ratings! Waterwetter will help with the "hot pockets" within the cooling system and lower you temps anywhere from 20 to 30 degrees os so. I have used Waterwetter on all of my vehicles and just adding to existing mix will be an improvement in lowering temps. Try it, you might like it!
Dave
Old Jun 11, 2005 | 10:43 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
I'm with you on the 50/50 mix, but I have my reservations about Water Wetter...
http://forums.corvetteforum.com/show...post1549908006
Old Jun 11, 2005 | 01:00 PM
vettenuts's Avatar
vettenuts
Carefully clean your radiator drain and then drain and keep the coolant you drain, distilled water is cheap at Wally World.
Old Jun 11, 2005 | 02:32 PM
Jim2003's Avatar
Jim2003
WOW did you just get off the boat. You never run 100 % antifreeze. That has been the pattern for many many years. Is this the first car you have driven or owned? 50/50 mix is the best protection.
Old Jun 11, 2005 | 02:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
DID YOU USE DEXCOOL??? I hope you didnt use the green stuff!! 100% strength is very bad for cooling your engine!!! The antifreeze additive is just that. It is designed to mix with water. The water is what provides the cooling. If you could run 100% water that would be better but, you need the antifreeze to increase the boiling point of the water in summner and decrease the freezing point in the winter. I doubt if you harmed anything but you need to dilute it with distilled water.
BC
Old Jun 11, 2005 | 05:04 PM
azmusclecar's Avatar
azmusclecar
Wow...don't hold back, let the person really know how you feel! Jeeesh talk about respect? Unless you're pure native american I would say one of your relatives "just got off the boat one day". ...so watch your accusations.
Old Jun 11, 2005 | 05:07 PM
azmusclecar
Did you check the members date of membership? Give the new people the benefit of the doubt.......welcome to the forum inspite of the dissin' you get.
Old Jun 11, 2005 | 05:45 PM
sam123's Avatar
sam123
Cruising
Default Takes all kinds
Thanks for the help,
I usually let the chauffer take care of the car.
Old Jun 11, 2005 | 07:21 PM
FTG's Avatar
FTG
In different areas of the country, and different brands there are differences between anti freeze and coolant. Many companies put out coolant that is ready right out of the bottle whereas antifreeze needs to be mixed with h2o. Read the instuctions on the label.
Old Jun 12, 2005 | 02:14 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Another issue is you can blow seals (waterpump, etc.) by running pure coolant. It's thicker than a 50/50 mix, and will cause the water pump to run at higher pressures internally.
Old Jun 12, 2005 | 11:13 AM
b98's Avatar
b98
Be nice, some day you might ask something, and I better be nice and not say.
To Is 100% coolent OK
