DTE LS2 Engine Conversion Performance Upgrade Package- C5 Corvette
Old Jul 6, 2005 | 05:17 PM
  #101
1badc5GoStrong's Avatar
1badc5GoStrong
Default Go For More - Afr Heads Next - Soon
I NEED MORE! THE CAR IS HOT, BUT I WANT TO SEE WHAT THE AFR HEADS WILL DO. BOATBOATBOAT, GET THE HEADS MAN
Old Jul 6, 2005 | 05:26 PM
  #102
DTE Powertrain's Avatar
DTE Powertrain
Collections Hold
We're pleased that you're pleased. Another 900 miles and you'll be ready for synthetic engine oil, so you should see the operating temps drop just a bit and the engine's smoothness/power delivery increase slightly.
Regards- DTE
Old Jul 6, 2005 | 06:02 PM
  #103
boatboatboat's Avatar
boatboatboat
Phil 1Bad has offered to pay for AFR's for my car ........
Having trouble getting traction? what type of tires are you running?
Old Jul 6, 2005 | 06:14 PM
  #104
1badc5GoStrong
Default Tires
I will check when I am back in town and advise
Old Jul 7, 2005 | 10:32 AM
  #105
1badc5GoStrong
BBB's output better not exceed mine
Old Jul 7, 2005 | 10:43 AM
  #106
boatboatboat
Phil has assured me, that after you see my dyno graph, you will take your car back for a more aggressive cam and prolly some AFR heads. In fact, I believe he has already ordered the heads. If I were you, i wouldn't worry about it, who cares if I end up with 50-60 more ft lbs of TQ then you do? It's not that big of deal............
Old Jul 7, 2005 | 11:01 AM
  #107
DTE Powertrain
Collections Hold
3B, stop trying to get us into trouble...
I suspect the power output would be nearly a wash since 3B's cam has more duration/lift than 1bad, but 3B has also chosen not to use headers/high flow cats as 1bad did either. It's going to be interesting to see how the engine bahaves with stock exhaust manifolds/H-pipe through an automatic w/ 3.73's.
Old Jul 7, 2005 | 11:08 AM
  #108
boatboatboat
Phil do you have a dyno graph showing 535 RWHP that I can borrow?
I wouldn't get REAL mad, if by chance when I picked up the car you said "well Jim I went ahead and put headers on, turns out I picked up 35 ft lbs of tq by doing this"........
Old Jul 12, 2005 | 02:34 PM
  #109
1badc5GoStrong
Default Take Charge of the House
3B, take charge; then look for another place to live
Old Jul 12, 2005 | 03:05 PM
  #110
boatboatboat
I live 3 houses down from the dealer where I bought the Vette. He is a pure "stock" type of vette guy (has 6 zr1's amoung many others), he looks at the stuff I have done and just shakes his head ..........
Phil has assured me, that even without headers he will be able to get me, ATLEAST 1 more foot pound of TQ then you have.
intresting info about the ls2
http://www.hotrodlane.cc/
go down about 1/3 of the way and click on LS2 Video.
Old Jul 12, 2005 | 09:41 PM
  #111
1badc5GoStrong
I can't wait to see the numbers. You will love it. The way the car pulls through the powerband, amazing.
Old Jul 13, 2005 | 08:05 AM
  #112
boatboatboat
Have you sold any of the ls2 parts you had left over?
Old Jul 13, 2005 | 11:20 AM
  #113
1badc5GoStrong
Not yet, I haven't had time to work on it. I will try Ebay first.
Old Jul 13, 2005 | 11:26 AM
  #114
1badc5GoStrong
What are your thoughts?
Drive by Wire throttle body was used.
Horsepower rating (create motor with alternator added to run the water pump)
Factory Computer programming............................. ........................................ ........................................ ........................................ ............428 hp
S&P Computer programming............................. ........................................ ........................................ ........................................ ................449 hp
S&P Computer programming and Comp Cams Shaft................................... ........................................ ........................................ ..............498 hp
S&P Computer programming, Comp Cams Shaft and CNC Ported Heads with Roller Rockers................................. ..................................540 hp
S&P Computer programming, Comp Cams Shaft, CNC Ported Heads with Roller Rockers, 90mm Throttle body and Fast Intake............. 549 hp.
Old Jul 13, 2005 | 12:06 PM
  #115
boatboatboat
I am going to crash.
Old Jul 13, 2005 | 12:20 PM
  #116
DTE Powertrain
Collections Hold
Yeah.....but just think of how much fun you'll have getting there!!!!!
Old Jul 13, 2005 | 12:26 PM
  #117
1badc5GoStrong
Phil, I just talked to the AZ co Street Performance and you are on targete with the LS2 project, better numbers with less mods and the AFR heads will rock when installed. Sweet!
To DTE LS2 Engine Conversion Performance Upgrade Package- C5 Corvette
Old Jul 13, 2005 | 12:59 PM
  #118
boatboatboat
Phil have you given any thought as where you are going to put the line lock button? If it will still be easy to take the center console, radio surround stuff in at out, VERY easy, I think maybe in the ash tray area would be a good place? ( I will be taking that center area out many times for various reasons) or you could just run in down on the right side of the center console area, where you will see the mute button for my escort, as long as I wouldn't hit the button by mistake.
Maybe you could mount it in the middle of the air bag, so when run into a tree it will leave a cool round mark on my forehead?
Old Jul 18, 2005 | 04:53 PM
  #119
boatboatboat
I took my car to DTE to get washed and waxed,
and OH MY GAWD............look what they did!!
Phil I said " have a good day TOO"............not, "I'll have the LS2"
Old Jul 24, 2005 | 05:00 PM
  #120
boatboatboat
