Hollow or solid cam?
Old Sep 1, 2005 | 12:17 PM
vettenuts's Avatar
vettenuts
Default Hollow or solid cam?
Just picked up an aftermarket cam and it is solid, not hollow like the stock cam. Are all the aftermarket cams solid or is it by manufacturer?
Curious as to others experiences.
Old Sep 1, 2005 | 01:55 PM
Patches's Avatar
Patches
The LS1/6 camshaft is machined out of a steel billet and is rifle-drilled to reduce mass. The aftermarket cams for the LS1/6 I've seen are hollow as well. What brand is it - who sold it to you?
Old Sep 1, 2005 | 04:57 PM
Jay-rod's Avatar
Jay-rod
My cam is competition cams and it is hollow too.JER
Old Sep 1, 2005 | 05:03 PM
vettenuts's Avatar
vettenuts
It is a Crane. I spoke with Crane, the cam I have is a street performance cam with peak power at approximately 6,200 RPM. They told me that there was no need to drill out this type of cam, and higher RPM cams would be drilled. Drilling does tend to weaken the cam a little. I was just surprised since the stock unit was drilled.
Old Sep 1, 2005 | 05:32 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
I think you are a "victim" of cost-cutting measures on Crane's end.. That's like building C5 bodies from sheet metal instead of composites; both serve the same purpose, but one leads to higher performance than the other.
If you followed Crane's philosophy to the extreme, you'd end up with an iron block and heads motor w/ accessories that would weigh several hundred pounds more than the unit you currently own.
It's up to you to accept the cost-cutting version of an LSX camshaft; being the weight reduction freak I am, I wouldn't. That's spinning mass as well.
Old Sep 1, 2005 | 11:16 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
My Comp Cams is hollow. Good for 7000+rpm (if the rest of my engine can stand it)
Old Sep 2, 2005 | 08:19 AM
vettenuts's Avatar
vettenuts
Understand what you are saying, but I hardly think it will make much difference as the core of the cam has minimal rotating mass, and in comparison to someone who puts on a double roller chain, the cam mass is in the noise of system mass. I think the other consideration is a hollow cam is also weaker, but that is not a driver either. I have since found a number of folks who have solid cams, including Thunder Racing, Comp Cams and others. I don't think it is a cost savings measure, but rather it is not necessary to remove the material from a cam whose peak power is in a lower RPM band, which this one is.
Old Sep 2, 2005 | 10:19 AM
Dan_the_C5_Man
Umm, honestly I think you are placating yourself because you don't want (or can't) send this cam back, and believe me, I sympathize..
But think about it. "Drilling the cam makes it "weaker", but we usually drill out our "high RPM" cams", which as anyone could guess would see more stress w/ more RPM's, right? What you should really be asking is "how can the king of penny pinching (GM) justify drilling it out, yet this aftermarket company selling parts at a premium can't".
Don't kid yourself; it is a cost cutting measure, no two ways about it. That's an extra machining step they skipped. It all takes time, and time is $$.
That said, install it and let's see some numbers!
Old Sep 2, 2005 | 12:29 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
I agree with Dan the man. It just doesn't make any sence. How many camshafts break at 6200 rpm? How many cams break period? How much stress does a heavy cam have on the all ready weak timing chain?
Randy
Old Sep 2, 2005 | 02:08 PM
vettenuts's Avatar
vettenuts
Dug into a couple of my LS1 books, and they state it is drilled for weight savings. I can't weigh the difference due to both cams (stock and new) sitting in a messy oil bath, but based on volume I come up with a 1.8 lb weight savings. Don't think it's a huge issue.
Not sure I got the straight scoop from Crane either. The only thing I like the hole for is a 1/2 pipe fits neatly inside and will be helpful for installation and removal. I'll just make up a handle instead.
Old Nov 9, 2022 | 11:41 PM
Wolf777_Mustang's Avatar
Wolf777_Mustang
2nd Gear
Default Metal, Rpm, and Mass weight
Look... Company Bull-s aside, let's be honest about full spec.
reliability, performance, and cost. Hollow aluminum cams will out-perform ona strips a couple of times. At light load they'll get you better reliability. But Aluminum had an infinite wear curve: aluminum can't be truly forged and tensioned, and will wear until it breaks. Hollw means less mass, but also less tensile strength: physics- Mass+Weight=Mo
Mo=Momentum. Your hightest lobe adds momentum force. Which WILL break the Cam under performance load.
Iron can be forged (and is more heat resistant) more than steel. Steel is lighter than Iron, and can be forged. Also (with less than 5% nickel, tin, aluminum content) has a limited wear limit. It'll stay stable until you hit a certain torque coeffecient for hundreds of years.
Aluminum: wears infinitely, weighs 1/5 the weight of steel at the same density. Way more cpaoble of heat warp. AKA warps fast, lasts a very short time.
in other words: Steel Hollow Cams are the most cost effective way to get long term, high load performance, for the buck. Solid Iron cams on single valve 60's plus setups are super reliable. Modern v-8's need steel, solid cams, that have been forged and balanced for YOUR ENGINE! A tuning co.pany that does in-house balancing will do you the best, cost vs. performance and durability.
Price and Pride, vs. one shot, bolt on performance.
Wolf777_Mustang
2nd Gear
Old Nov 10, 2022 | 01:29 AM
vette4fl's Avatar
vette4fl
You do realize you’re responding to a 17 year old thread, no?
Old Nov 10, 2022 | 03:33 AM
493lszosix's Avatar
493lszosix
Thread is from 2005, hopefully he’s bought a cam by now 👍
Old Nov 10, 2022 | 06:34 PM
grinder11's Avatar
grinder11
Probably 2 or 3, if I know Marc!!!
Old Nov 10, 2022 | 10:52 PM
Supercharged111's Avatar
Supercharged111
Aside from the fact you resurrected this thread from when my car was almost new, who the fvck is making cams out of aluminum?
To Hollow or solid cam?
