Engine knocking after new air intake - help
you may want to check your connections after the maf just to make sure you are not sucking in extra air.
P.S. make sure all maintenance items are up to date! Dirty anything =
and the effect could be magnified by more mods, especailly ones that lean it out i.e. increase airflow.
Like CONNECTICUT stated,
you really need to include what DTC codes are set in the DIC. If you had too much oil on the filter, it can contaminate the sensors inside the MAF. Get some electrical contact cleaner and wash down the wires and thermsistors inside the MAF. Just dont touch them!!
With the DTC info, we can point you in the correct direction.
Are you sure that you have the intake air fittings between the throttle body and the Mass Air Flow Sensor properly secured and tight, If there is an air leak and it is allowing unmetered air into the engine, it will cause some of the symptoms that you are having. Those connections are CRITICAL!!!
Do you have any MIL (check Engine lights) on??
Here is a link to codes and how to read them:
This is the absolute best C5 Code web site!!!
http://www.corvettedoctor.com/Codes_Page.htm
Once you write down the codes, clear them and thak it for a ride. Check the codes again and post the results of both DTC checks.
Bill C
Anyway, you did learn a bunch from that exercise!
