The headers are all 304 SS and not coated. At least one set has been on for six or more months now. Wonder if anyone who is running them could comment on O2 sensor service problems due to condensation or excess heat. Any input on the quality of the welds? I think there was someone on here who is a welder or else owned a welding shop who could give us an input.
Charlie
i just got mines took them to a mufflershop to get a price and he told me these are some of the best headers he's seen he thought they at least cost 1000.00 or more. im just waiting on my hi-flo cats 80.00 new o2 bungs 5.00 and 3''clamps 15.00 then im gonna try to install these myself total price 450.00 cant beat that
one question what kind of gaskets did you guys use? the factory or an aftermarket hi-perf. gasket.
i once used those soft aluminum 2-piece gaskets and they worked pretty good.
I take it you are referring to the pictures on page 1? SXE60 had those weleded in by RPM Motorsports because the bungs that come in the headers, welded at the 12'o'clock position, require the O2's to be installed prior to installing the headers. Something that was not discovered until more forum members started installing them. The bungs they welded in are at the 3 or 9'o'clock position and seem fine to me. Welding them at a 10 degree angle would be impossible on the car. The new bungs' welds are not the best but I'm sure they were done on the car so they are about as good as you can expect and look very much like the WB O2 bung I had welded into mine.
Originally Posted by vetpet
You don't get something for nuthin. Looking at where the front 02's are mounted I'd say be prepared to replace them in the not to distant future. When the car is first started up condensation will collect on them a lot easier and stay there. As they warm up the condensation along with the heat may cause them to crack eventually with enough cold starts. Also, the 02 bung welds look pretty bad to me and it looks as though they were welded on after the headers had been coated. These headers are a copy cat of TPIS & Melrose. Do as you wish, it's your money, but the job you save by buying local may be your own.
5 Liter Eater is correct. The only reason those bungs look shabby is because they were added on after we found out the sensors couldn't be install with the headers bolted up. I hated to screw up the nice clean look of the headers, but I didn't feel like paying to have them removed to install the sensors. The only occassional code I get, after 6 months of use, is from the aft O2 sensors not reading sufficent exhaust change thru the Cats. Sims will cure that.
Got my bid in. You guys have me drooling for a set of these things. Last 2 sets of headers I put in were the pricy, perfect fit kind (mustangs, tho) and neither one fit w/o major massage. The posts y'all have done will make this a piece of cake. Great work- thanks.
Might even get a set for my brother in law.
If your brother in law passes on them, you can send them my way.
With all the money you guys saved on these headers can you guys start a collection so that at least one of you can get yourselves a dyno and then post with actual gains.
Thanks in advance from someone who did pay too much for headers way back about 4 yrs ago.
Enjoy em
Matt
The next local Dyno Day, I plan to do mine just to confirm. But really, its the sound and SOP kick you get that make them worth it.
