ebay Header Install
Old Oct 17, 2006 | 05:49 PM
  #241
gonbad's Avatar
gonbad
Originally Posted by Boeingman
Why in the world would you want to remove your TPIS and install the EBAY headers ?????
His headers are coated and is having a detonation problem. Some people have had this problem with coated headers. The shop tuning the car also said they have had problems with cars and coated headers. Fovsky has already put a lot of money into this car. He is looking for an easier answer to this problem. These are a lot less expensive than paying $1,500+ for SS Long tubes from some of the venders on here.
Old Oct 17, 2006 | 07:59 PM
  #242
molten vett's Avatar
molten vett
Originally Posted by Ryan L
I'd go with high flow cats over stock cats for two reasons...
1) They will net you more power than stock cats, which is the point of getting headers in the first place. Get the 02 sims if using highflow cats.
2) You won't have to hack up your stock cat pipe and can be reused if you ever decide to remove the headers in the future.
why would i need o2 sims?
Old Oct 17, 2006 | 08:14 PM
  #243
Ryan L's Avatar
Ryan L
Some high flow cats flow so well that it trips the check engine light because the computer doesn't think any cats exist.
Old Oct 17, 2006 | 10:17 PM
  #244
molten vett
thanks
Old Oct 17, 2006 | 11:57 PM
  #245
RainJ's Avatar
RainJ
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
any long term pics?
Old Oct 18, 2006 | 02:54 PM
  #246
ryoder's Avatar
ryoder
Why do coated headers cause detonation?
Old Oct 18, 2006 | 05:19 PM
  #247
willyv's Avatar
willyv
Default Where are these things?
Great thread and cookbook; how do I get a set? The ebay sites mentioned don't list anything but rice and Ford stuff. I can't find ssauto on ebay but on their website, they want $550 w/o an x pipe.
Old Oct 18, 2006 | 08:08 PM
  #248
Ryan L's Avatar
Ryan L
search Corvette headers
If nothing comes up, then wait a couple days and try again.
Old Oct 20, 2006 | 01:34 PM
  #249
SmoothFRC's Avatar
SmoothFRC
Their back up, but dont outbid me! He will put other set's up soon.
Old Oct 20, 2006 | 03:06 PM
  #250
willyv's Avatar
willyv
You got it. Thanks for the tip.
Old Oct 20, 2006 | 03:28 PM
  #251
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Has anyone here gotten the seller to answer an emailed question? I'm going to buy a set, but can wait until early spring. I will wait if they plan to start making sets that are bolt on for '01-'04.
Old Oct 20, 2006 | 03:42 PM
  #252
fovsky's Avatar
fovsky
Read post #10
http://forums.corvetteforum.com/show....php?t=1471269
"connecticut" a tuner on the forum has heard of this too...
as soon as I get to the bottom of this and get my timing back to where it needs be I'll be able to tell you guys whether the coated headers were my problem or not
Old Oct 20, 2006 | 11:08 PM
  #253
rgjaglowski's Avatar
rgjaglowski
I have a 1999 A4 and got the Powerboost29 headers about a month ago. I had a local vette guy do the install and he was impressed with the finish, fit and ease of installation. I believe it was about a 3-4 hour job. Front O2 sensors were no problem. I had the cats removed and the rear sensors edited out in my tune. Having driven with them for a couple of weeks I have not had any problems. With a Passport performance meter I gained 0.4 seconds in the quarter with the headers and a cold air intake installed. Definite SOP gain as well!! Lots of bang for the buck!
Old Oct 21, 2006 | 09:31 AM
  #254
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Originally Posted by madeouttaglass
Thanks Ryan,
My biggest concern was the fitting of the air tubes. It looks like these headers are designed for the 97-00 cars. I've emailed the ebay seller about this issue a bunch of times, but have gotten no response. I'd like to see some pictures of the air tube setup from anyone whos done a later model C5.
As for cats, I'm up in the air as to use H/Fs or just eliminate the pup cats and use the stock main cats.
You'll find that the eBay headers are for 1997-00 C5's only, but you can block off the air tubes and eliminate the cold start air system and have it edited out of the Computer. If you do that you might as well install HiFlo Cats and have the aft O2 sensors edited out also.
Old Oct 22, 2006 | 10:47 AM
  #255
bluevette1's Avatar
bluevette1
I have a 97 and want to run no cats. What do I need in place of the cats? X pipe? I have stinger exhaust. What is needed to go from the collector to the stingers?
Old Oct 22, 2006 | 11:04 AM
  #256
slow ride's Avatar
slow ride
I'd just run the stock h pipe, it's the same size (2.5") as most x pipes. I don't see much gain in an x pipe and the stock h is stainless I believe.
Old Oct 22, 2006 | 02:31 PM
  #257
vetpet's Avatar
vetpet
You don't get something for nuthin. Looking at where the front 02's are mounted I'd say be prepared to replace them in the not to distant future. When the car is first started up condensation will collect on them a lot easier and stay there. As they warm up the condensation along with the heat may cause them to crack eventually with enough cold starts. Also, the 02 bung welds look pretty bad to me and it looks as though they were welded on after the headers had been coated. These headers are a copy cat of TPIS & Melrose. Do as you wish, it's your money, but the job you save by buying local may be your own.
To ebay Header Install
Old Oct 22, 2006 | 04:37 PM
  #258
cruisemon's Avatar
cruisemon
The headers are all 304 SS and not coated. At least one set has been on for six or more months now. Wonder if anyone who is running them could comment on O2 sensor service problems due to condensation or excess heat. Any input on the quality of the welds? I think there was someone on here who is a welder or else owned a welding shop who could give us an input.
Oops. Just checked and they're 321 stainless not 304.
Charlie
Old Oct 22, 2006 | 06:47 PM
  #259
Ryan L's Avatar
Ryan L
Let me guess... you are one of those who spent $1500 on headers.
02 sensors are what, $100 each? I guess I can replace them 10 times and still be ahead of the game. Regardless, mine cleared just fine.
  #260
ryoder's Avatar
ryoder
Boy these headers really scare some people.
