ebay Header Install
Old Apr 5, 2007 | 11:18 AM
  #581
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
For reducers, the best bet is a local muffler shop that has 2-1/2" SS pipe and a pipe expander that can open one end up to 3". You'll need to decide if you want to go inside or outside of the existing pipes to get the right OD and ID.
Old Apr 5, 2007 | 11:23 AM
  #582
cruisemon's Avatar
cruisemon
Cats and adapters
Take a look at this link http://www.performance-curve.com/ind...OD&ProdID=1149
I'll try to find it but there was a link somewhere in this thread I think that had a source for the reducers and ball type adapters that make this an easy job. Another source had clamps that were made of sheet SS maybe four inches wide with a clamp that didn't stick out like a regular saddle clamp, making for a much neater installation.
Charlie
Old Apr 5, 2007 | 11:28 AM
  #583
cruisemon's Avatar
cruisemon
Originally Posted by 200MPH
I used a ball flange on mine. 3" to 2.5" worked really well. I got mine through summit--part # FLO-15925
Here's one source for the ball flange adapter. I'm still looking for the band type clamp.
Charlie
Old Apr 5, 2007 | 03:38 PM
  #584
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I got my band clamps from Summit as well, they have the stepped and flat band clamps available.
WLK-33226 2.5" Stepped band Clamp
WLK-33272 3" Stepped band Clamp
Old Apr 5, 2007 | 03:42 PM
  #585
STOCKER's Avatar
STOCKER
wow i just send you a PM on this very question lol
Dave
Old Apr 5, 2007 | 03:49 PM
  #586
cruisemon's Avatar
cruisemon
That's the ones!!
Charlie
Old Apr 5, 2007 | 03:54 PM
  #587
tstar's Avatar
tstar
Charlie, I need some of your happy pills!
And Stocker is physicic or something!
Old Apr 5, 2007 | 09:45 PM
  #588
LightFighter_GXP's Avatar
LightFighter_GXP
I welded my reducers to my cats done deal
Old Apr 5, 2007 | 11:05 PM
  #589
STOCKER's Avatar
STOCKER
hey lightfighter, did you have any of the issues I had? Are y our o2s touching or almost touching the torque tube? Do the collectors point the right way? How bout the ac line or the primaries hitting the bellhousing/torque tube?
Dave
Old Apr 6, 2007 | 12:02 AM
  #590
RIP1976's Avatar
RIP1976
Ok my install is complete now got the mid pipes made today and installed. The install I have to say went pretty easy I did 98% by myself and had no probs at all. I simply followed the directions on the LS1 site. I'm very satisfied with 90% if the fitment of the headers the 10% I'm not pleased with is the PS O2 sensor its straight up to the differential its not removable with the headers bolted. Like everyone else my PS header was higher but it was not a prob at all.
We had a make a very very minor bend in the PS mid pipe other than that everything went crystal smooth. I do have some pics but I had to take them with my phone but I gotta get them to the pc and will post them up.
Old Apr 6, 2007 | 12:13 AM
  #591
nitrojunky's Avatar
nitrojunky
I amazes me how two different people can install the exact same Headers and have different problems! Do you have the streets or Pros?
The only thing that makes sense to me is subtle variances in assembly at Bowling Green or model year changes that aren't obvous to most of us, like engine mounts or something...
All I know is that every Header system I've ever installed took some work and creativity to get installed...
Have the streets. I was very impressed with the fit, but I also expected it. FWIW, LG's O2 fitment provides excellent clearance; they can be installed with the headers bolted up; they sit farther back (you run a set of rear O2 sensors for the fronts to take advantage of the longer wires), so you want to run the wires above the heat tunnel plate so they don't get burned; that's why they drill the holes. I actually didn't drill any, instead running the wires through the small holes provided by a joint in the sheet metal which attaches the tunnel plate to the car.
I have been unimpressed with the fitment JBA and SLP headers I've had on f-bodies; the hooker longtubes I had in my WS6 bolted up well, but had clearance issues (y-pipe UNDER the floorboards) due to the f-bods poor exhaust design. I have never dealt with the probs you guys seem to be running into, tho (headers against the floorboard or a/c lines). I'm not super experienced, but this is the fourth set of headers I've installed on an LT/LS motor. The JBA / SLPs were off a little at the y-pipe or made for near impossible spark plug install, but neither were so far off I'd have to make major adjustments.
The LGs are the first set I've had go in with so few problems and they tucked under the car very nicely. It was a pita to get them into place (they're a bit longer than what you guys are installing), but once there, everything was perfect.
I did replace LG's pos clamps the summit racing ss clamps, tho
Old Apr 6, 2007 | 12:40 AM
  #592
RIP1976's Avatar
RIP1976
Forgot to mention I have not got my tune done yet it will be done Saturday but right now yes I can defintanly feel a difference and not only can I but my wife says the power is greatly increased. If you stomp it now anywhere in 1st its blowing the tires off till it hits 2nd an just continues to pull.
I also got my SS Band Clamps at a napa dealer for less that $9 each.
But anyways here is the pics I promised sorry for the low quality but I ran off an forgot my camera at home.
Old Apr 6, 2007 | 12:46 AM
  #593
tstar's Avatar
tstar
Great job! And you have an 02 right? Can't wait to see your pics, and maybe a video/sound clip???? Mine was not very good...
Old Apr 6, 2007 | 12:55 AM
  #594
tstar's Avatar
tstar
Yeah my SOTP meter was pegged too... Yours looked just like mine did before any adjustments...
Except my front O2s are close to the bellhousing NOT the differential, I mean they are Long Tube Headers but sheesh! (sorry, couldn't resist! )
I have to ask, how LOUD is that bad boy anyway????????????
Old Apr 6, 2007 | 12:56 AM
  #595
RIP1976's Avatar
RIP1976
Yea my car is a 02. Its just a piece of 3" exhaust pipe that was expanded a hair to go over the collector and then it extends back to about 2" before the X where it goes into a 2 1/2" piece of pipe that is inside the X pipe that is expanded to accept the 3" pipe. the connections at the X pipe and the collector arfe band clamped and the connection at the 3" to 2 1/2" is welded. This way I can easily undo the hole exhaust by undo the x pipe at the mufflers and the band clamps.
Old Apr 6, 2007 | 01:01 AM
  #596
RIP1976's Avatar
RIP1976
ok I deserved the bellhouse remark its been a long week lol. As far as noise well for normal driving and idle its not to bad but once you get on the mat it gets noisey. We are going to Bowling Green next weekend with the local vette club and I have high hopes of getting some dyanmat in the trunk area before we go. 6 hrs of driving could get annoying and the last thing I want is a ticked off wife complaining about noise of the exhaust after an hour or less.
Old Apr 6, 2007 | 01:12 AM
  #597
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
And Stocker is physic or something!
To ebay Header Install
Old Apr 6, 2007 | 01:35 AM
  #598
tstar's Avatar
tstar
Thanx for the info!!!
One question about the rear to front O2 sensor swap, do you guys cut off and replace the connectors or what? On mine the front O2s have a flat in-line connector while the rears have a square connector...
Old Apr 6, 2007 | 02:22 AM
  #599
regorih's Avatar
regorih
where can I get a set?
Old Apr 6, 2007 | 02:26 AM
  #600
RainJ's Avatar
RainJ
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
The headers/Xpipe pkg?
