HELP!!! Failed emissions with a cam...
Old Jul 7, 2006 | 06:34 PM
bsmall423's Avatar
bsmall423
Default HELP!!! Failed emissions with a cam...
Hey guys.. i have a 224/228 on a 114 untuned in my car with straight pipes. I failed the emissions test because i cleared all of the codes. If i dont clear the code im going to throw a check engine light. If i get my car tuned would this help out the situation, or am i fighting a lost cause?
Old Jul 7, 2006 | 06:37 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
i wouldn't go to a sniff test w/out cats, what codes are you getting? you shouldn't have a problem with cats and a tune
Old Jul 7, 2006 | 06:43 PM
bsmall423's Avatar
bsmall423
P0113 Intake Air temperature (IAT) Sensor Circuit High Voltage -B C
P1111 Intake Air temperature (IAT) Sensor Circuit Intermittent High Voltage -C C
B0521 Tachometer Signal Circuit Malfunction H
U1160 Loss of Communications with LDCM H
B2276 Door Lock Motor/Mirror Heater Fit DCM-L H
U1096 Loss Of Communication with IPC (No SOH Message Received -RFA H
U1064 Loss Of Communication with DCM (No SOH Message Received -RFA H
U1016 Loss Of Communication with PCM (No SOH Message Received -RFA H
C2120 TPM System malfunction (No Sensors Received -TPM HC
those were the codes left on my dic
Old Jul 7, 2006 | 06:44 PM
bsmall423's Avatar
bsmall423
i still have cats and its a 2000 so no sniff test for me... i guess ill have to get it tuned.
Old Jul 7, 2006 | 06:49 PM
FRCTony's Avatar
FRCTony
Looks like if you just fix your wonky Intake Air Temp sensor, you'll be good to go.
You probably know you need a tune...
Old Jul 7, 2006 | 06:51 PM
bsmall423's Avatar
bsmall423
any ideas what could be the matter with it? i obviously have an intake, it seems like i could be using the wrong coupler to attach it, but would that be a problem? buy a new sensor?
Old Jul 7, 2006 | 07:38 PM
FRCTony's Avatar
FRCTony
I'd check the connector and wiring.
Try a search, I seem to recall someone else with this problem recently.
Old Jul 7, 2006 | 07:48 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I had the TR224 cam and passed emmissions both in NY and VA. I had the cats and all the bolt ons. I good tune will help you pass emmissions.
Old Jul 7, 2006 | 07:56 PM
WKMCD's Avatar
WKMCD
Get it tuned by someone good and have them turn off any remaining codes that are thrown. I run a 230-236 112 in a H/C engine and FAST intake with LS2 TB and I don't through any codes at all.....That anyone will ever see.
Old Jul 7, 2006 | 08:09 PM
vettenuts's Avatar
vettenuts
Looks to me that you have an IAT issue that needs resolution, try to diagnose and correct it. The rest of the codes shouldn't be an issue for emissions.
Old Jul 7, 2006 | 09:47 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
Old Jul 7, 2006 | 10:24 PM
bsmall423's Avatar
bsmall423
Originally Posted by Threed
awesome.. i ordered a new sensor ($4.90) and a new harness (13.xx) ill post an update if it resolves the problem..
Old Jul 7, 2006 | 11:21 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The tune is NOT your problem!! You have an electrical or sensor problem that is causing the MIL to set. Fix the:
The other codes should not be emissions related and wont effect the emissions test.
Before you go back and have your emissions rechecked, clear all the codes and then, you will need to complete the driving cycle portion of the PCM test before it will pass the emissions test.
I have the procedure at home (on the road to a C5 car show in Canada ) and will post it when I get home if no one else does.
Bill C
Old Jul 8, 2006 | 10:19 AM
SpeedyZ's Avatar
SpeedyZ
Clear all your codes then drive it around at least 30 minutes and recheck your codes. Post any codes that return. All those U codes don't look good, but was probably the result of a dead battery at some point in time. Other codes may also be from a dead battery. Clear then, drive it, check and post the codes that return.
Old Jul 8, 2006 | 11:17 AM
johnnyvettes's Avatar
johnnyvettes
CHICAGO CREW !
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
you still need to tune to get all the HP & TQ the cam is giving you ! I have a 224x224-114 lsa+4 and the car ran like crap before the tune .
To HELP!!! Failed emissions with a cam...
