Head and Cam numbers????
Old Sep 22, 2006 | 02:28 PM
Jstyle's Avatar
Jstyle
Default Head and Cam numbers????
Ok I just picked up a corvette from a forum member I like the car and everything. It has having so crazy valve noise but I am getting that checked out next weekend. The reason I post is because I am bothered by the dyno sheet I have. It only shows 388 to the ground. Now I know that the gears drop it a little but come on now... Is it just me or does this sound really low to anyone else.
AFR 205 Heads
224-228 with 581 lift and 112 LSA
80MM BBK TB
LS6 Intake mani
Dynamax headers w/ high flow cats
B&B RT 66 exhaust
3.90 gears
Blackwing intake
smooth couper and Z06 air bridge
Old Sep 22, 2006 | 02:29 PM
chaase's Avatar
chaase
St. Jude Donor '12
Seems a little low..see my sig, the cam is very close to yours and I use ported LS6 heads
Old Sep 22, 2006 | 02:57 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
look at my sig for my numbers. I dont know how the G5X3 cam compares to yours, but I would think your numbers are low for what I see on the list.
Old Sep 22, 2006 | 07:09 PM
ksett's Avatar
ksett
That does seem very low for the mods listed. Have you looked at the heads to see if they say AFR on the front side? The numbers sound like a cam only with that size cam and the gears.
Old Sep 22, 2006 | 07:19 PM
22655td's Avatar
22655td
It wasn't a zo6 so the factory stock ponies would be around 340 hp (guessing) as the 01 zo6 was around 340 and the 02 and later was 360-365. So with those mods you should around 400 rwhp if it wasn't a zo6 to start with. The C/R was lower on the non zo6 so maybe you are losing around 15 there. Also has it been tuned correctly as they could have done the mods but not tuned and that could be aniother 20.
Don't flame me but that cam is close to a stock zo6 spec isn't it?
I think your close to expected maybe a little more left
Old Sep 22, 2006 | 07:31 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I dont know what kind why kids of gears you have, but I put down 370 RWHP with all the bolt ons and a TR224 cam.
You should be in the 410-420 range
Old Sep 22, 2006 | 07:45 PM
Face's Avatar
Face
A4 Or Mn6?
Old Sep 22, 2006 | 07:49 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
you didn't state the dyno, different dynos could show +/- 30 to 40hp
Old Sep 22, 2006 | 09:20 PM
LF97C5Vette's Avatar
LF97C5Vette
Nope, pretty good difference.
2002+ LS6 cam
204/218 int/exh @ 0.05" duration
0.551" / 0.547" int/exh lift
117 LSA
From everything i've read and the mods i'm about to do to my car
P&P LS6 Heads
LS6 Intake
Dynatech LT & B&B Bullets
Cam 224/224 .581/.581 112lsa
valve springs/rods/lifters/oil pump/ ls2 chain
+ A good dyno tune
should be at or above 400rwhp on a MN6.
I don't know how the AFR 205 heads compare to Ported and Polished LS6 heads, but to me, with a good tune, you should be closer to 400 than that, if not above it...
Of course, every LS1 is different...
GL
Dan
Oh Yeah - and i forgot; some things that could easily effect 20+ whp: Mustang vs. DynoJet, Temp, Humidity
Old Sep 22, 2006 | 09:35 PM
Blue02ws6's Avatar
Blue02ws6
It should be alot higher, I have a buddy that has that cam and tsp cheap headers and put down 408rwhp. It might be in the tuneing. Then again that crazy valve noise might have something to do with it. If it is seeing knock it could reduce the timing a lot. You could have a bent pushrod or valve even, there could be a lot of stuff you need to check, but to answer your question that is too low for those mods.
Old Sep 22, 2006 | 09:43 PM
Honez's Avatar
Honez
I wouldn't loose to much sleep on the dyno numbers. The HP your missing could be in the tune. I would bet that your AF is really fat and with a little work on the PE table you will find the missing HP. Valve noise is also normal for your mods. I have tuned a lot of setups similar to yours and I would expect about 405 to 420 out of the mods you listed. Get the car on the dyno and look to see if the AF is set really fat.
Old Sep 23, 2006 | 07:40 AM
quimbo's Avatar
quimbo
Jstyle valve train noise IS NORMAL!!!! WHEN YOU DO HEADS AND CAM. YOU NEED A TUNE YOUR NUMBERS ARE A LITTLE LOW!!!!!! GET A TUNE YOUR SHOULD BE UP IN THE 400'S
QUIMBO SEEYAAAH
Old Sep 23, 2006 | 08:10 AM
Jstyle's Avatar
Jstyle
I think it was a dynojet dyno run... It's an M6 so it should be a lot higher I think. They are definately AFR heads I can see the logo right on the front. I will be getting it tuned next week.
Old Sep 23, 2006 | 08:51 AM
6Speeder's Avatar
6Speeder
Yes, it should be higher. I'm running arguably poorer flowing heads (P & P 5.3 L) , a much smaller cam (218/.561"/114), simular gearing and heavy aftermarket wheels and made 422/398 sae on a dynojet.
Get a tune, it'll pick up.
Old Sep 23, 2006 | 08:56 AM
vettenuts's Avatar
vettenuts
Valve train noise is not normal with a cam, it is a sign the pushrods have not developed the correct lifter preload. I would start there. I would also contact Tony Mamo at AFR, since that cam looks like his grind. He may also be able to point you in the right direction.
Old Sep 23, 2006 | 09:16 AM
quimbo's Avatar
quimbo
Valve train noise is normal with heads and cam change do some searches you will find that that it is normal with heads and cam change!!!!!!!!!!!!!!
http://forums.corvetteforum.com/show...ve+train+noise
http://forums.corvetteforum.com/show...+machine+noise
QUIMBO SEEYAAAH
Old Sep 23, 2006 | 10:52 AM
tjwong's Avatar
tjwong
QUIMBO SEEYAAAH
It isn't always normal. I did a head swap on a customers car which had MTI ported heads. He said it was always a bit noisey since it was done. When I disassembled the heads, I found shims under the rocker plates, and found that there wasn't adequate preload on the lifters due to the shims. The tops of 90% of his valves were all chewed up as well as the rocker arm tips. So just because someone says its normal, one had better check to make sure that there is proper valve geometry and lifter preload. This guy was going to sell the heads for around $1000, and he would have got that but to repair the heads would have cost $500+ so all he got was $600 for them
To Head and Cam numbers????
Old Sep 23, 2006 | 10:59 AM
quimbo's Avatar
quimbo
Listen im not trying to start any Sheot here but if my tuner says its normal and other forum vendor tuners say its normal i would have to go what is told to me unless its proven different to me!!!!!!!!! I have seen and heard many heads and cam cars done by various tuners not only corvettes and have heard some valve train noise in all those cars. Aslo i have also heard that Headers will also contribute to more valve train noise
QUIMBO SEEYAAAH
Old Sep 23, 2006 | 12:10 PM
Busa196's Avatar
Busa196
Valve train noise on a H/C car is normal, period. That's like owning a blower car and telling me that the whistle of the blower isn't normal. I've seen over a dozen H/C cars dynoed and have known several people who have a H/C car......depending on the combo you go with you should be between 410-440rwhp. Sure, every car, every dyno, every package etc. is different- but from what I've seen on a DynoJet, that's accurate assumption. It's all in the tune.
Old Sep 23, 2006 | 12:41 PM
vettenuts's Avatar
vettenuts
It is not normal, what is your lifter preload? Stock lifters will quiet right down with 0.100" of preload. There are a ton of cars out there running cams that sound stock for load. Mine sounds stock, and my preload was set with a dial indicator to the lifter specifications. If you are running stock pushrod length on an aftermarket cam, you preload is probably too low.
