Cluth replacement...yeah I know...
Old Oct 24, 2006 | 12:21 AM
SultansDiamond's Avatar
SultansDiamond
Originally Posted by chuckster
Read on... The LS7 cannot be slipped without glazing bad over 3500 rpms.. Ranger has documented this...
By "slipping the clutch", I mean normal street driving where you ease the clutch out for normal smooth shifts. Race clutch's drive differently on the street. Aluminum flywheels require higher rpm's. If this fella wants a DD that drives nice, but is beefier than stock, then I still say the LS7 isn't the worse choice out there and it'll do the job.
Yes, Ranger has documented he can destroy an LS7 clutch. He doesn't understand why his clutch is starting to show signs of abuse after only 50 race launches dumping it mega-hard on rpm's north of 3500 off the line! I'm not sure what clutch he's gonna get next, but this much I am sure of.... he'll destroy it too. Ranger is a dedicated, hard core racer driving a low 11 second car, who I feel is expecting too much from a factory type clutch. Even he doesn't know what clutch he'll try next. Bottom line is if you hard core race an 11 second car (our boy posting here only has 400 ponies, so he's what... maybe the high 12's), you outta be prepared for stuff to break and bring your wallet. I enjoy reading Ranger's posts and marvel at how well his equipment stands up. Do I correctly recall him mentioning he replaces the clutch fluids something like every week? I don't recall if he's running stock tires or racing slicks, I'm pretty sure he is running DR's that can't be fun for the clutch either.
The way I read the post is this fella isn't planning to spend his every waking hour at the drags abusing his equipment to shave .01 seconds.
Nothing against Ranger, but let's all put his comments in correct context to make an honest and fair evaluation in giving advise to members. Personally the way I read his comments is that's a pretty darn good endorsement of the LS7 - if all he's done so far is glaze the damn thing. At the end of the day, even Ranger admits:
I doubt your clutch would show any sign of failure or impending failure. My clutch does what your did, when I don't make a clean, fast release. But it bounces back for the next pass and has done so repeatedly through 47 and counting.
That's about as good as it gets with any clutch. I still say the LS7 clutch has street maners and driveability. Ranger needs to get a clutch that takes both feet to push in - maybe something from the John Force collection? Race clutches don't slip and they aren't fun in traffic for a DD.
When ever I read Ranger's comments on the LS7 clutch, it conjures up an image of a guy taking a test drive in a new vette with the salesman sitting along side him. They exit the showroom and go a short way down the road when the buyer say's to the salesman "can I see what she'll do"... the salesman says "okay". Bringing the car to a dead stop he brings the rpm's up to 4000 and hammers the clutch - away they go pinned to their seats in a blaze of sound and smoke. Finally (with both of them wearing broad smiles), the buyer brings the car to another stop.... looks over at the salesman and says "that was fun wasn't it"... to which the salesman sheepisly nods yes (trying to avoid eye contact). Next the buyer ebows the salesman and announces - "you know what that was so much fun, I'm going to do it 47 more times"!
Anyone who drives a car like that outta consider the extended warranty.... lol Anyway that's the image I always get reading a Ranger post and his dissapointment with parts that just don't seem to measure up.
Old Oct 24, 2006 | 06:08 AM
vettenuts's Avatar
vettenuts
The one thing I don't like about the LS7 clutch is the heavy flywheel. I have seen several guys state the car is much softer in the lower RPM's because of it. This is one of the reasons I am now favoring the Tex clutch, flywheel decision aside.
Old Oct 24, 2006 | 11:09 AM
chuckster's Avatar
chuckster
Dude, I love your description of Ranger.. I actually laughed out loud because I pictured it in my mind the way you described it..
Anyway.. As far as 400hp being high 12's... I think that driven properly it can be an 11 second car..
I have exactly 345rwhp and 346rwtq and I have run 12.55 using a Stock LS1 Clutch.. It would not hold anything after 3000 rpms if I slipped it too much..
I would rather have a clutch that is overkill with Street manners then a clutch that WAY too many folks here are bashing.. Ranger is not the only one.. look for Phils C5 Vette here are a few...
http://forums.corvetteforum.com/show....php?t=1495634
http://forums.corvetteforum.com/show....php?t=1516813
http://forums.corvetteforum.com/show....php?t=1517800
Old Oct 24, 2006 | 11:20 AM
SultansDiamond
There is a reason Detroit puts in steel flywheels. Here is what little I think I know about them.
The lightweight ones mean you can shift gears faster, but in normal driving you have to maintain higher rpm's to move forward from a stop. How much fun is that for 2 hours on an LA freeway. Plus with a stock shifter you ain't gonna be moving through the gears all that quickly.
One of the reasons, I originally mentioned the Textrilla with hollow steel flywheel is it's a compromise flywheel which is heavier than aluminum and less than stock weight. Plus from all I've read the Tex clutch is mega strong. Don't have one, never had - so I don't know the negatives.
The only clutch I can intelligently speak about is the LS7 and can say I do not notice any difference from the original one.
Old Oct 24, 2006 | 01:11 PM
Ranger's Avatar
Ranger
You sure haven't been very diligent in reading my posts over the past six years while I've done weekend passes in three Z06s without any breakage whatsoever, and documented the process and results.
Couple of points.
(1) I have never written a word in 6K posts advocating "clutch dumps." So attibuting that to me is plain wrong.
(2) C5 Z06 clutch supported launch rpms of 4000-6000 without complaint. LS7 clutch complains about 3500. That's not progress. That's a compromise to preclude strong launches. Every LS7 clutch owner that makes passes complains about the LS7 clutch. Few ever did about the LS6 clutch. So I'm in good company.
(3) I keep my cars stock while you choose to mod yours including the engine internals.
(4) My LS7 clutch has not failed and is not failing. And I've never written a word different from that. So saying that I have destroyed an LS7 clutch is Here, for example is what I wrote yesterday:
Originally Posted by Ranger
Like all clutches, the LS7 clutch has a personality...and not a pleasant one.
It just will not accept:
(1) a high launch rpm, period. 4K is the limit and I'm not having luck above 3600.
(2) any slip on the engagement. If you slip it more than, say 6 feet of forward launch movement, at above 2900 rpm, the clutch will glaze. That means, the pedal will hang and the clamping power is near zero until it cools and the pedal is returned to the full-out position.
This is not really a sign of a defective clutch; it's reflective of a defective design. Changing to another stock clutch will not create a new personality.
What I've done through my 47 passes is develop a routine that keeps my launch rpm at 3500-3600 max and gets the clutch out fast. Not a side-step, not a dump. Just a fast release.Clutch all the way out by 6 feet of forward movement. If I lose focus and give it some unintentional slip, it will glaze. Again, changing to a new clutch won't solve anything.
There are two alternatives:
(1) Mod the driver's technique, the course I follow or
(2) Go to an aftermarket clutch; but there is absolutely no sure fire clutch solution in the aftermarket, as of today. And $1500-2500 including installation is pretty expensive to do repeatedly, while looking for a reliable clutch.
In the meantime, 355spider, I doubt your clutch would show any sign of failure or impending failure. My clutch does what yours did, when I don't make a clean, fast release. But it bounces back for the next pass and has done so repeatedly through 47 and counting....
So please avoid falsely attributing writings or actions to me that I have never posted.
If you are happy with your LS7 clutch, that's great.
But to say that those who think it's a weak element in a 400+ rwhp Corvette are shameless abusers, is ridiculous. The C5Z had a world-class clutch. The C6Z has a very pale imitation of a world-class clutch. But it may satisfy those who never launch a car, such as yourself perhaps.
Ranger
Old Oct 24, 2006 | 02:00 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Ok....take this pizzin match elsewhere....I ask for recommendations not a bunch of please read the original post, car specs and give input
Thank you
Old Oct 24, 2006 | 02:27 PM
Architect's Avatar
Architect
How can we accurately recommend a clutch when you haven't mentioned a word regarding your driving habits? I know guys "02GT350" that would consider their cars daily drivers... but from my perspective would be considered pretty damn aggressive *****-to-the-wall driving.
If you don't race it and are right around 400 HP with no plans to considerably increase that anytime soon, the C5Z clutch is perfect for you.
Old Oct 24, 2006 | 02:46 PM
RobG03Z06's Avatar
RobG03Z06
St. Jude Donor '08
Originally Posted by pewter99
need a new clutch for an 02....putting down just under 400rwhp. Daily driver....
gimme pros and cons of your choice...
IMO....put in another stock clutch. At under 400rwhp, the stock clutch should hold up fine. How many miles on your '02 and what kind of driving?
Rob G.
Old Oct 24, 2006 | 03:04 PM
chuckster's Avatar
chuckster
Rob G.
Yep, that would be the simplest thing to do.. However.. If swapping clutches were cheap it would make the most sense...
But it costs as much in labor as it does for the clutch... So I always recommend UPGRADING... then if he wants to every take it to the track or try a little road racing... It will not come back to haunt him..
There are plenty of better clutches than stock that have reported great daily street manors.
I really think his relatively average HP output should be secondary in deciding which clutch to go with..
I picked a Cartek.. Capable of holding over 600HP... I have 345rwhp.. I could care less... that means the clutch won't get half the beating expected and last longer.. I chose it simply because it has rave reviews. the Cartek racers in NJ put them through hell.. and they last..
Thay all say the clutch has near stock feel and street manors..
Now I can confidently Drag with it.. or go Forced induction... without the added expense..... Just my humble .02 cents
Old Oct 24, 2006 | 03:14 PM
pewter99's Avatar
pewter99
well I think Daily Driver pretty muchs sums it up and we all know we drive a little "spirited" as it were so...take it from there
I am thinking that the Z06 clutch or the LS7 would be fine......
Old Oct 24, 2006 | 03:18 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
If you plan on doing any racing do not use the LS7 clutch.
Old Oct 24, 2006 | 03:20 PM
pewter99's Avatar
pewter99
yeah...I saw that.....I think it would be ok for a couple passes nothing like what I see on here but have no plans of that as of now....
Old Oct 24, 2006 | 05:03 PM
  #33
yellowvette837's Avatar
yellowvette837
St. Jude Donor '03 thru'19
Tampa Events Princess
2015 C6 of Year Finalist
I Believe In The Beer Fairy
Shall we get a few other opnions on my driving "spirited" :bb .
And a few passes down the track will probably happen
Old Oct 24, 2006 | 05:10 PM
  #34
pewter99's Avatar
pewter99
And a fe passes down the track will probably happen
well you haven't killed my car yet
Old Oct 24, 2006 | 08:57 PM
  #35
yellowvette837
So, can I pull out of hooters with it
Old Oct 24, 2006 | 10:42 PM
  #36
pewter99's Avatar
pewter99
anytime
Old Oct 25, 2006 | 12:02 PM
  #37
chuckster's Avatar
chuckster
anytime
So Other than a little Flirting... what have you decided?
To Cluth replacement...yeah I know...
Old Oct 25, 2006 | 01:39 PM
  #38
yellowvette837
Not sure of a decision
Old Oct 25, 2006 | 09:45 PM
  #39
ksett's Avatar
ksett
Since your not going to drag the car I would go with the LS7 clutch. It costs the same or less than the LS6, can hold more power and has the same stock drivabilty. I have been through two LS6 clutches (sticking pedals) from spirited driving (no drag racing). The first clutch failed at 15k with stock HP and was covered under warranty. The second failed with about 5k with 400 rwhp.
I currently have the LS7 clutch with a Findanza flywheel and the drivability is like stock even with the alluminum flywheel. I decided on the alluminum flywheel because of all the complaints on how heavy the LS7 clutch setup is with the stock flywheel. Hope this helps.
Old Oct 31, 2006 | 03:20 PM
  #40
02gt350's Avatar
02gt350
hey, why buy it to look at it? drive like you want to and enjoy the car Dosnt mean that its not babied though
