ECS Speed Density Cold Running Update
Old Nov 29, 2006 | 01:21 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Default ECS Speed Density Cold Running Update
After ECS did my S/D tune in the spring, I had many people asked how the car would run during the cold weather and although the Northeast has been pretty nice I had a chance this weekend to test it out.
The car is usually in a garage so cold starts are never an issue, but Friday night it sat outside in my parents driveway. My parents live in upstate NY and in the morning when I woke up the pond behind the house has a thin coat of ice on it so I know it was cold.
I go out to the car to see frost on it and wonder what is going to happen at start up with the S/D tune. I turned everything on and saw the oil temp was 17 degrees (it was at this point I was happy that I just changed over to Mobil 0-40). The outside temp was 27 degrees.
The car started right up and went right to the correct idle. I actually think it was a smoother startup then on a warm day. The car warmed up for 10 mins and then off I went. No problems with the car at all. It ran and idled fine. I was happy to see this since people had me thinking that there might be a problem in the winter.
It seems to have passed the first test now I am just waiting for Jan/Feb to see what it will do when it is cold the entire day.
Old Nov 29, 2006 | 02:36 PM
vettenuts's Avatar
vettenuts
Its funny, my C4 (90) had a SD setup. Everyone told me a MAF setup was better (later years). Now we have MAF's and are going the other way.
Old Nov 29, 2006 | 03:03 PM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
Thanks for posting the update. Don
Old Nov 29, 2006 | 06:56 PM
Wicked Weasel
I think MAF is better from the factory. Probably hell of a lot easier to tune MAF for all cars across the nation, but from what I see from other people with the G5X3 on MAF is that my car runs a ton better and smoother.....
Old Nov 29, 2006 | 07:07 PM
vettenuts's Avatar
vettenuts
Yep, my tuner told me he could make the car sing with SD. Sound like it is running good
Old Nov 29, 2006 | 07:08 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
on your S/D tune, does your MAF stay turned off, or is it S/D tuned then turned back on ?
Old Nov 29, 2006 | 07:23 PM
Slowhawk's Avatar
0Slowhawk
Former Vendor
SD can run perfect in every weather condition.The only variable is that the A/F at WOT can change if the temp table is not right.The main benefit of SD is for part throttle tuning on big Cams that have low vacuum.Smaller Cams will gain nothing hp wise when a MAF is used.
Old Nov 29, 2006 | 08:08 PM
Phil97SVT's Avatar
Phil97SVT
Maf gets turned off, SES for 0103 gets turned off and no ce light. The O2s get turned back on to correct.
Old Nov 30, 2006 | 07:18 PM
phils C5 vette
Phil,
correct me if Im wrong, but I thought you told me on your S/D tuned cars, you turned off the MAF for tuning, then turn on the MAF to allow for flucation in temperture and elevation.
I believe mine is on.
Old Dec 1, 2006 | 02:36 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Glad to hear it's running well Bob.
We have found better idle quality out of large cam cars with this process. It takes longer to tune it this way, but as Bob said, it is easy to tell how much smoother they run when done that way.
We also do this same type of process on cars that are still using the maf to dail in VE tables.
Old Dec 1, 2006 | 03:18 PM
HRDTOPC54FUN's Avatar
HRDTOPC54FUN
Doug - just curious, what affect if any does SD tune have on ability to pass emissions inspections. I assume any OBD codes can be edited out somehow.
Old Dec 2, 2006 | 12:49 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
This is a EXCELLENT POST!!
Thanks for all of the good info!!
BC
Old Dec 3, 2006 | 06:58 AM
WKMCD's Avatar
WKMCD
Phil97svt did my SD tune last week when we had 70 degree weather here. It's f'ing below freezing out now. I'll see how it runs.
DAMN! I hate winter.
Old Dec 3, 2006 | 07:31 AM
phils C5 vette
Come on 21 degrees isnt bad. Did you have wet dreams about the car last night?
Old Dec 3, 2006 | 07:32 AM
WKMCD's Avatar
WKMCD
Pipes were clean long before I fell asleep.
Old Dec 3, 2006 | 07:41 AM
phils C5 vette
Old Dec 3, 2006 | 08:51 PM
WKMCD's Avatar
WKMCD
My car in SD mode ran the same this morning in 23 degree weather as it did in 70 degree weather...
To ECS Speed Density Cold Running Update
Old Dec 3, 2006 | 08:53 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
Good to hear, I've always heard that SD was weather dependent.
Old Dec 4, 2006 | 06:52 AM
see5's Avatar
see5
My experience is if weather changes, SD tune changes .
At least with a modified engine you can see the VE needs change from day to day based on temp and barometer. That results in AFR swings in PE. SD tuning gives fabulous results but the MAF is a really smart device when used to stabilize the tune. If you SD tune then dial in the MAF to close the loop, you get the best of both worlds. Just my personal experience, in the ever changing Midwest.
Old Dec 4, 2006 | 07:41 AM
supercoupe01's Avatar
supercoupe01
Good to hear Bob. My car has an ECS SD tune and I drove it yesterday after it sitting for about three weeks and the car ran great. Big difference on how my car runs around town after taking it back up for a SD tune.
