Which heads are best
Since you have a long winter (longer than us ) you should devote a month or two reading up on cams and heads and then start selecting your parts (David Vizard has some good books he has written on small blocks, very good reading).
You can install yourself but if you don't get some of the finer technical issues correct like ptv clearances, you won't get the maximum performance out of your mod!! and my tuner spent over four hours going thru the range before the first dyno run
PS....Savage1....awesome results with the heads cam swap. How big was the cam you installed?
and Tony with that cam set up the AFR's seem to really match up well with the LGPro's
savage1
When you start milling the heads, using thinner gaskets and then install a cam with more duration, the valves get closer to the piston as it reaches top dead center on the overlap stroke. Both valves are open at the same time and you should measure how close they get to the piston. The closest point may not actually be when the piston is at the top so I measure from 20 degrees before the piston reaches the top to 20 degrees after in 2 degree increments. The smallest measurement taken is the one you are looking for. There are what are considered acceptable limits of clearance, which if you drop below you need to consider fly cutting the pistons (putting a notch in them). Some people run them closer than these limits and get away with it, but it is a risk when you do.
Thanks for the info.
I have a stroked ls6 383 in my 02 z06. I have a supercharger making 17 psi at 6500 rpm. I am currently running an aftermarket head, but it will only hold a 600 lift. Im running a 550 lift cam right now. I want to go up to a 630-650 lift cam.
Ive heard nightmares about valve issues with ls6 motors. I keep hearing the way to go is the afr mongoose heads... My etp's will need the rocker stands for my stock z06 rockers. I hear the stock rockers are actually better than most aftermarket ones.
I need someone who knows etp heads, and can vouch that im safe putting them on my car, otherwise, ill sell them and get the afr mongoose to be sure. Let me know, thanks, Brandon
Randy
763-477-9272
www.dougrippie.com
Because of their shallower valve angle, the ETP heads will give you much more PTV clearence than the stock, or AFR (which are the same as stock) heads will. The TF heads are in between the two as far as clearence goes. Depending on your cam's overall specs, you can safely run more lift than the AFRs, and of course, the big ETP heads will easily outflow the AFRs, if you are building mostly a car to run in the higher rpm areas. I assume this is the case, because of your other mods you spoke of.
Ed Curtis may tailor you a camshaft for your application, with your ETP Heads, isn't it what you are requesting???
Christian
This is also part of you cam selection.
http://forums.corvetteforum.com/show....php?t=1800404
I have 3 people with the afr mongoose heads on the identical engine build as mine, saying to jsut use the ones they have bc they saw big power gains, and their motors are still on one piece.
Every company is going to say their heads are the best, its the question of "where are all the cars with this particular head, and do they work?" Thats what im after
Do you know to what parameter "valve float" is linked???
Again, the heads are by far not the unique reason to the consequences you mention here!!!
Regards
Christian
PS:did you receive my answers to your questions by PM???
Your right, theres lots of reasons for engine failure... but one of the big thigns i have heard from several engine builders is that the ls6 has a very unique valve train. I have talked to engine builders and drag racers who swear that the stock rockers on mongoose heads are the "only" thing and the first combination that they have found that dont have valve train failure when pushed to the limit.
Corvette connection owner Rich has a car with the identical motor to mine.... he built them both. He says that a ls6 stroked to a 383 with a forged lunati bottom end is a tricky motor to find heads that are compatible with the stock rockers. He had tried literally 4 other high dollar brands and had issues with every single one, and swears by the stock rockers. He was concerned with using a rocker stand that the etp heads require bc he said this geometry of the valve train has to be so precice, and even the person i talked to at etp admitted that the rocker stand allows for some flex vs rockers that are the correct size for the head and the motor. Obviously I would buy aftermarket rockrs, but since several people have mentioned that the ls6 is the one motor you dont want to mess with the rockers, im hesitant.
I do things by numbers, its nothing personal, but right now its 3 people saying watch out, vs you and one other person saying go for it. Those arent good enough odds in my mind, so i will continue to ask questions until i bump into the person that has an ls6, blowing 17psi at 6500 rpm, has the rocker stands with the stock rockers, or has an aftermarket rocker... and has not encountered any valve train failure.
My definition of a good head is first and formost... one that does not cause rocker or valve failure with my stoked 383 at higher rpms. I can always take the head off if it doesnt produce power. But if somethign fails, im out an engine.
Again, hopefully this makes sense to you, and me gathering information from other people than yourself and ed makes sense to you, its not meant to be offensive.
Im eager to talk to Ed, and hope that i can figure out why others have had valve train issues on stroked 383 ls6's and what the common denominator is between their failures so that i can avoid it.
Thanks for hooking me up with ed, and let me know if you have anymore questions for me. Thanks, Brandon
Do you think my heads are too big? You can find them on the etp site, and they are under the ls1 category, and are actually listead as 240's, but mine are 245 bc of being bored out i believe. Thats the other reason im considering the mongoose bc they are smaller if these etp's are too big. I drive the car on the street a lot, but im after power as well, and i dont mind powerbands, corvettes and v8s in general have more low end torque than most cars can wish for.
