Dumb blonde needs help! PLEASE!
K&N filters do suck some times, then the car dies, won't start, won't stay on for too long, and so on.
Just teasin' ya, and no offense Bella.
Bella,
Welcome to the family!
Take Bill Curlees advice and check the wiring and connections. Clear your codes, and wait for it to happen again. If the sensor is truly bad, it will throw the code again right away. If it's a wiring issue it may take a while for it to happen, as the wires have to be put in such a way as they break contact and throw the code. Once contact is broken, the code is thrown. Then contact is re-established and all is well again. Maybe it only happens when you hit a lage enough hole in the road, or enough vibration causes the wiring to break contact.
Let us know what you find out on this.
After all I've read here, I'm inclined to believe that it is a bad wire. The check engine light will be on sometimes, I'll park the car and the next time I drive it, all is well. Does that sound like a wire problem to you?
Once you learn to check codes, which is easy to do, it really helps you to figure out what is happening with the car.
Also, it's rather funny how your level of interest here increased when you announced that you are a blonde female.Work it girl!!
You'll get tons of help, and offers from all the guys here to help you work on your vette. Hey, maybe we should have a Vette Dating Forum section, for members trying to hook up!
Back to the point though, welcome to the forum, and ask questions as much as you want. There are some really knowledgable people here, and you will learn alot about your vette. Also, by checking your local Event Section, you can find out about cruises, shows, and other cool things to do in your area.
you can pretty much gurantee that any thread title that references a female will get a lot of attention.
have a good mechanic check this for you
1,309 post views!! Did you ever get this fixed??
