Restrictive Push Rods.....Still Too Much Oil !!!!!
Old Dec 22, 2007 | 12:04 AM
Dirty Howie's Avatar
Dirty Howie
Default Restrictive Push Rods.....Still Too Much Oil !!!!!
Well I was getting too much oil flow up in the valve cover leading to oil being pushed out the valve cover vent tube thus into the intake. I catch most of this with a catch can setup.
Smith Brother restricted push rods were supposed to cure this. Well I got them and it made absolutely no difference. I fill up the Elite can with oil after a 30 minute track session !!!!!!!!!!
DH
Old Dec 22, 2007 | 12:20 AM
Dave68's Avatar
Dave68
Mmmm, sounds like another enigma that may not be explained very easily!
Old Dec 22, 2007 | 12:28 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Were your lifter trays drilled out (for quicker oil return)?
Converting to the LS6 PCV system might be a good idea too.
Old Dec 22, 2007 | 12:30 AM
Dirty Howie
I wonder if the coalescing filter is too restrictive in the PCV line causing the oil to flow easier up top.
Or maybe this engine too has blowby pressure.
Or maybe a check valve is necessary in the valve cover vent line.
Or what else ....... ?????????
DH
Old Dec 22, 2007 | 01:26 AM
Dave68's Avatar
Dave68
Your coalescing filter is downstream of your AMW can - correct? If the filter were too restrictive, you'd have less oil in the AMW, not more. GM is offering more restrictive orifice fittings to replace PCV valves in some vehicles. This means (to me) that some restriction is not bad. Still, I doubt the filter is clogged unless your oil is unfiltered or you don't change your oil enough - both highly unlikely in your case!
Old Dec 22, 2007 | 01:54 AM
Dirty Howie
Dave
My coalescing is down stream of the AMW in the PCV line. It is not collecting unusual amounts during track sessions. It is the Elite can in the valve cover fresh air line that is completely full of fresh oil after thirty minutes. This line has that coarse white stone filter (flows much more), not a coalecsing down stream of the Elite.
DH
Old Dec 22, 2007 | 07:38 AM
vettenuts's Avatar
vettenuts
What oil pump are you running?
Old Dec 22, 2007 | 02:25 PM
TLewis4095's Avatar
TLewis4095
With the engine running at idle, take off your oul fill cap and feel if there is pressure pushing out. If so it sounds like blow-by....possibly the ringland broke on #7 (just a guess since it is the one that almost always breaks). Let us know.
Old Dec 22, 2007 | 03:19 PM
ZeeOSix's Avatar
ZeeOSix
DH
I've mentioned this many times ... that the crankcase gasses will take the path of least resistance. If the flow path from the crankcase to the intake manifold is more restrictive than the path from the valve cover to the throttle body then you will get flow backwards down the fresh airline. Even if both paths were about the same resistance, you may still get flow backwards down the fresh airline at WOT, high crankcase case production conditions because both the intake manifold and throttle body are at about the same vacuum level at WOT. In other words, at WOT the system acts like it has two parallel paths to the intake system and crankcase gasses could flow down both paths.
http://forums.corvetteforum.com/show....php?t=1884012
I think the only real fix for guys who spend a lot of time at WOT is to have a well baffled breather on the valve cover and block off the fresh air tube on the throttle body.
Old Dec 22, 2007 | 03:29 PM
ZeeOSix's Avatar
ZeeOSix
I wouldn't say a fixed 2.5 mm orifice is more restrictive than the original PCV valve. Remember that at idle, the PCV valve is almost closed, and the flow rate is small. At WOT the PCV valve opens up some under it's internal spring pressure based on manifold vacuum level. Hard to say how the flow rates would compare, but a 2.5 mm seems like a decent sized orifice in this application.
So DH ... have you tried the fixed 2.5 mm orifice PCV "valve"?
The key to making the PCV system suck vapors out of the crankcase and make up the evacuation with fresh air is to make crankcase vapors flow from the valley cover (on LS6) to the intake manifold and not backwards through the fresh air make-up path.
To do this with the current design, the path from the valley cover must have less resistance than the path from the valve cover to the throttle body when under WOT conditions.
Old Dec 22, 2007 | 03:33 PM
ZeeOSix's Avatar
ZeeOSix
Another way is to remove the dipstick at night while the engine is idling at full temp, and take a flashlight and shine it sideways over the dipstick tube opening. If you see lots of vapors coming out of the dipstick tube then something might be damaged internally. I did this with my Zee and didn't see any signs of vapors.
I've heard of engines with massive ring blow by will actually blow the dipstick up out of the tube during WOT use, as the crankcase pressure is so high that it has to go somewhere, and the PCV system can't handle the flow so it blows the dipstick out of its tube.
Old Dec 22, 2007 | 08:17 PM
Dave68's Avatar
Dave68
In a PCV system, reverse flow is impossible, due to the check valve-like behavior of the PCV. Since Howie doesn't have a PCV, maybe it's a good idea to install a check valve.
Old Dec 22, 2007 | 08:52 PM
Dirty Howie
What is drilling out lifter trays and is it a simple job??
I have a 2004 C5 it has the LS6 PCV system and no PCV valve.
DH
Old Dec 22, 2007 | 08:53 PM
Dirty Howie
Ported or shimmed LS2 I believe.
DH
Old Dec 22, 2007 | 08:58 PM
Dirty Howie
I will try it and get back tomarrow.
My last motor did the exact same thing. So on this new engine (has 4500 miles) I was hoping this would not be an issue with the Smith Brother push rods
So I kinda doubt its anything broken. But how would you know??
I did do a very long and hard canyon run without any appreciable oil collected. So some of it may be from the high speed lateral forces on the track.
DH
Old Dec 22, 2007 | 09:02 PM
Dirty Howie
What about a check valve that would only allow flow of air into the valve cover but not the other way.
DH
Old Dec 22, 2007 | 09:04 PM
Dirty Howie
I have a 2004 C5 it never had a PCV valve.
DH
To Restrictive Push Rods.....Still Too Much Oil !!!!!
Old Dec 22, 2007 | 09:07 PM
Dirty Howie
But I am not gettting excess oil in the PCV line. I could run all day at the track and not fill up the AMW can.
DH
Old Dec 22, 2007 | 10:14 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
DH
Yes, it is easy but a little time consuming since you have to pull off the heads.
Old Dec 22, 2007 | 10:28 PM
Dirty Howie
Should have been done when my new engine was put together
DH
