engine dies
Old Jan 4, 2008 | 01:48 AM
jetmech09's Avatar
jetmech09
Default engine dies
2001 vette, engine dies after getting of expressway. no codes. starts right up and runs fine.
Old Jan 4, 2008 | 03:34 AM
DeeGee's Avatar
DeeGee
I had that problem once in the distant past
The engine just died. never reocurred
I'd check the codes and see if theres anything untoward. If not, clear them and see if it occurs again. probably not
Old Jan 4, 2008 | 07:27 AM
dougbfresh's Avatar
dougbfresh
The other GM's I've had that did this, it was usually the Crank Sensor loosing it. I've had to replace it 2 times in my Bonneville in 120K miles.
Old Jan 4, 2008 | 01:43 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Check the MAF. Neighbors went out and we just replaced it. Same symptoms. Everything is fine now.
Old Jan 4, 2008 | 06:50 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
How are you checking the DTCs ??? Aftermarket scanner or the built in code reader that displays the DTCS on the DIC???
What MODs do you have?
Check for vacuum leaks.
Does the car miss or studder at idle or under load?
Have you ever cleaned your MAF? Recommend doing that!!
Have you ever cleaned your Throttle Body? Recommend doing that!!!
Is the throttle blade free to move and free to return to the at rest position when you let it go from fully open? (Remember,,it will NOT go fully shut and will be slightly OPEN when the ignition is off!)
Check the intake tract between the TB and the MAF! It MUST be sealed and can NOT leak any air! If it does, it can cause this kind of symptoms.
Check all that out and let us know what you find and do.
BC
Old Jan 5, 2008 | 12:13 AM
jetmech09's Avatar
jetmech09
Default Engine Dies
will due all of this wwhen I get back in town on tue Thanks for the info!!!!!
To engine dies
