View Poll Results: C5 Reliability Issues....
I have had very few or no major mechanical issues!
65.06%
I have had some engine related mechanical issues
9.09%
I have had some transmission / driveline related issues
14.06%
I have had some electrical related issues
31.68%
Multiple Choice Poll. Voters: 704. You may not vote on this poll
C5 Reliability Poll....
Old Mar 1, 2008 | 11:16 PM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
Originally Posted by ajg1915
Only issues I have are the one's I created when I started modding the car.
I was thinking the same thing....LOL
Big power equals broken driveline parts and the on-going journey of finding "the next weakest link"!
Old Mar 2, 2008 | 11:39 AM
pro1955's Avatar
pro1955
2000 FRC 75k daily driver rain or shine. Slave cylinder leaked causing need to replace clutch, master and slave, also had pedal sticking to floor problem which seems to have gone away since clutch replacement. Battery leaked onto computer fixed by GM. No other issues so far.
Old Mar 2, 2008 | 01:50 PM
timemender's Avatar
timemender
2000 - Coupe - A4 - 33,000 miles - Stock - Performance Tune - VaraRam - Cat-back exhaust.
Only ONE "problem" in all 8 years:
Drivers rear axle seal replaced (slightly seeping - replaced before it became more of a problem)
Old Mar 2, 2008 | 09:03 PM
CHJ In Virginia's Avatar
CHJ In Virginia
2001 coupe had a disaster of a differential - In for warranty work - 4 times for leaks that they could never fix. Dumped it at 35K miles before the warranty ran out. Current 03 Z06 bad battery and drivers window lift in first 500 MIles. Since then, very reliable even with 7-8K of track miles. Only problem was a leaking differential half shaft seal.
Old Mar 2, 2008 | 09:16 PM
saw22's Avatar
saw22
Blown tranny parts as a result of the dreaded aluminum 3/4 shift fork. Replaced synchros, shift fork, slider keys and shift pads. Also electrical issues from bad grounds and/or burnt O2 sensor wires.
Old Mar 2, 2008 | 10:33 PM
cb98's Avatar
cb98
98 Battery only
Old Mar 2, 2008 | 11:43 PM
widewheel's Avatar
widewheel
2002 vert with 82,000 miles driven 2-3 day a week. Lost the A4 at 78,000 miles. Fixed the EBCM last summer and just put in a new oil pressure sender in last Saturday. One of these days I'll get around to fixing the rocking drivers seet. Only other expenses have been consumables like, tires, battery, belts/hoses, brake pads, etc..
Old Mar 3, 2008 | 01:09 AM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
Serpentine belt,tires,battery,and the Column lock recall is all
I've had to deal with.
Translation-cheap maintenance
Old Mar 8, 2008 | 02:48 AM
BlackRocket's Avatar
BlackRocket
TTT
I think this is a worthwhile poll and demonstrates that the C5 is of pretty decent quality.
Anyone out there thay hasn't answered....please submit status.
Thanks!
Old Mar 8, 2008 | 09:44 AM
Plasticfan's Avatar
Plasticfan
Only unscheduled repair I've had is replacing the starter at 75K. Other than that, drop dead reliable old car. The most fun you can have with your clothes on.
Old Mar 8, 2008 | 10:11 AM
J Z06's Avatar
J Z06
I drove my 2004 z daily back in 2005(August) when I first got it. rain, snow, whatever. Turned the key and drove it. The column lock thing made the car stall out a few times. CLB, and CAGS, no problems since. 26,000 miles on it now. I'd take it anywhere without fear.
Old Mar 8, 2008 | 12:23 PM
RedC5's Avatar
RedC5
'98 C5----Never seen a dealer since I picked it up in March 1998....oh wait only for stupid column lock recall. Now oil pressure sensor went out.
Old Mar 8, 2008 | 12:30 PM
  #33
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
98 here as well.
Sure,there are always little things that pop up,but overall.........
What an outstanding car!!!I am very pleased with it....
Old Mar 8, 2008 | 01:23 PM
  #34
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
AMEN - same here. Only problems I've had with my '04 were self-induced. It goes with the (mod) territory.
Old Mar 8, 2008 | 02:15 PM
  #35
RIJVETTES's Avatar
RIJVETTES
2002 coupe with 76000 mi. No significant problems until recently: battery , water pump, ABS and active handling and oil sender- oh, and another bad experience of delay and too much money spent at the local chevy dealer.....but I still love the C5.
Old Mar 8, 2008 | 09:10 PM
  #36
Mooneypilot's Avatar
Mooneypilot
C-5s x2 in this family. '02 vert w/ 67k and an '03 Z06 w/ 30k. Both daily drivers. '02 has had 5 door modules in it,2 left and 3 right. Window fell out of the soft top but reliable otherwise. Zo6 has been perfect up to the last month when the passenger window stuck for a day then started working again. I don't count the new battery each of them needed after 4-5 years of driving. Way better than the wifes c-4.
Old Mar 14, 2008 | 01:35 AM
  #37
BlackRocket
Can we get this poll to over 200???
To C5 Reliability Poll....
Old Mar 14, 2008 | 05:26 AM
  #38
c3andc5's Avatar
c3andc5
Ssveral electrical-related issues:
1. Replaced passenger window motor/regulator assembly.
2. Replaced HVAC control unit.
3. Replaced HVAC actuator.
4. Column lock
5. Replaced Delco batt due to notorious leaking problem
Old Mar 14, 2008 | 08:32 AM
  #39
Clay Assassin's Avatar
Clay Assassin
had the door lock relay go out. Fixed it with the tips here on the forum for 20 bucks and 2 hrs of my time.
Supercharged '01 W/36k miles. Pretty reliable car. Never driven in rain.
Old Mar 14, 2008 | 08:42 AM
  #40
bierbelly's Avatar
bierbelly
2001 Vert
1. Rering due to excessive oil consumption
2. transaxle leak
hmmm...gotta look up that door lock relay thing. I've noticed that my passenger side door won't unlock with the fob every time.
