Installing Arp Rod Bolts And Head Studs "questions"
#42
On the LS1, all holes are blind and no sealer required. I would assume your new block is the same, but verify with a flashlight first. ARP lube on the studs, then into the block hand tight.
#44
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Make 100% ABSOULTY,,,POSITIVELY SURE that the head bolts holes in the block are clean and DRY!!!!!!!!!!!!!!!!!!!!!!!!!!!! If there is any liquid in there, it can and will crack the block!!!!!!!
I used a nozzel with a long aluminum tube that I put all the way into the hole to the bottom of the hole. You will be amazed at what comes out !!!!
BC
BC
#45
St. Jude Donor '08
BC
BC
#46
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Great post for a TTT. I had to remove my head for some repairs and now I am reinatalling it for the second time. Good post to get the head bolt torque numbers again.
Bill
Bill
#48
CI 6,7,8,9,11 Vet
St. Jude Donor '08
#51
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just kicking this back up to the top. I had to pull the drivers side head to have it repaired (coolant leak in the #1 cylinder runner due to a casting flaw)
I am SOOOOOO GLAD that I have the ARP HEAD STUDS. It made the head removal and reinstall SO much easier.
Patriot Performance stood by the defect and repaired the head.
If you are on the fence about installing the head studs, JUMP OFF and get them! There OUTSTANDING!
BC
BC
#52
Mr Bill Curlee that is the first time i ever seen you ask a question..
Iv always seen you answer all questions.. An answer with great detail an knowledge...
I must say you are the man with it comes to vettes...
#53
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I dont have ALl the answers but I try to keep current. Some times you have to reach out for help in NEW unexplored areas.
Like my new SPEC Duel Disk clutch. I just called England Green and asked him for the presure plate torque specs.
30-35 ft/lbs
BC
30-35 ft/lbs
BC
#54
Are you installing the clutch now? I think I bought the Spec Street Twin same time as you....haven't installed mine yet either!
#55
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I broke my engine and just had it repaired this week. Rewelded the starter boss back on... Should have it running tomorrow and check for any weird vibrations before I reassemble the drivetrain.
Cant wait to drive it again
Bill
Bill
#57
Head bolt/Head gasket question
What is the part number for the correct GM head bolts for my 1999 c5 ls1 and the part number for the 2004 ls6 243 head gasket to use on my 1999 c5 ls1. Thanks
#58
