Help! valve train damage!
Old May 2, 2008 | 09:09 AM
wildman572's Avatar
wildman572
Default Help! valve train damage!
Fellas I am one bummed SOB! I put a cam and supercharger on my 01 Z06. Put on roller rockers and such, long story short I went to start the and it rolled over way easy so I figured no compression pushrods must be too long. I took of the pass. side valve cover off and here all the intake valves are bent and broke all the rocker arm bosses! I took off the driver side and everything is mint! WTF This really blows cause now I have a trashed set of fully cnc ported ls6 heads and dont know what the heck is going on!
Old May 2, 2008 | 09:18 AM
Novakain1970's Avatar
Novakain1970
Did the motor fire at all?
Old May 2, 2008 | 09:26 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
A few things could have caused this. Sounds like cam timing is off. Your heads may not be trashed. You might be able to get the rocker arm bosses welded back up, milled, drilled and tapped for repair if you have enough money invested in them, the repair cost may be justifiable. Pushrods would have to be way too long to cause this I think. You didn't put in some huge cam and then some 1.8 rockers did you?
Either way, sorry for your loss. I am in the process of rebuilding my motor from a broken valve that destroyed 1 head and 1 piston, so believe me when I say I feel your pain!
Old May 2, 2008 | 09:27 AM
BLOWNBLUEZ06
How did you line up the cam timing marks?
Old May 2, 2008 | 09:34 AM
vettenuts's Avatar
vettenuts
Did you degree and check PTV?
What springs, installed spring height and lift?
Old May 2, 2008 | 12:06 PM
WKMCD's Avatar
WKMCD
Need more info.
Old May 2, 2008 | 12:46 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
HOLY CRAP! I am JUST finishing up a Heads/Cam/push rods/ caddy lifters/ FAST90 intake/90 TB LS2 /Timing chain/ powerbond damper/42 lb/hr injector MOD tonight and this happens to you. MAN,,,,,,,,,,,,,,,,,,,,,,,Turing that ignition key for the first time is going to be a BITCH!
I'm VERY methodical; almost to the point of being overly cautious when I do mechanical repairs,,,so,,,I really shouldn't be worried BUT,,,,,,,,,,,,,,you know how you can worry about unforeseen things. I'm really sorry you had problems like that.
I hope you can work through the problems and find the smoking gun!
Bill Curlee
Old May 2, 2008 | 01:06 PM
corvettebob1's Avatar
corvettebob1
Even if the cam timing was off I can't see it damaging only 1 head, something else must be really wrong.
BTW 2 things in life you NEVER DO, don't **** off Leroy Brown and don't ever change a cam without checking PTV clearence on both banks!
Good luck with your repairs, and check and recheck everything before trying to start the engine.
Old May 2, 2008 | 01:26 PM
wildman572's Avatar
wildman572
The cam that came out was .580 lift and the one I put in was a blower cam that is .590 lift with non adj 1.7 roller rockers. Ive installed many cams, so I know the cam timing is right. I used the same pushrods. It was some major interferance like 1/4 inch I would say to break the heads bend the pushrods and valves. Only thing I can come up with is theres a bullitan (hes a mechanic) at work that says if you do not set the valves with each cylinder at TDC valve train damage will accur. So that seams to be the only thing I can come up with that makes any sence what so ever.
Old May 2, 2008 | 02:02 PM
STL94LT1's Avatar
STL94LT1
Old May 2, 2008 | 02:23 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Quick question??? Theres a rocker rail pedestal (Long aluminum bar) that the rockers sit on. One on each side. Did you install the pedestal on BOTH sides. Now that I look back, there was some one else who had simular damage and that was the issue. I would check that.
BC
Old May 2, 2008 | 02:29 PM
vettenuts's Avatar
vettenuts
Bills' response above is very logical, and I remember that happening. Just oversight by the installer.
I think what he meant is that each lifter has to be on the base circle to tighten the rocker. Here is the correct GM procedure:
Old May 2, 2008 | 05:00 PM
BLOWNBLUEZ06
Looks like in the picture that the cam is 180 out eh??
Old May 2, 2008 | 05:04 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ok.....I don't understand why one would need to rotate the engine to TOP DEAD CENTER of each cylinders compression stroke to install rockers for that specific cylinder.
If number one is at TDC, the timing marks are all lined up and you install all the rockers without moving the engine, all the pistons will be at the CORRECT position relative to the can lobe position s for that pistons stroke as well as the others.
Am I not seeing something here that I'm suppose to????
Some one PLEASE explain this to me because I JUST did this very install (have not moved the eng of #1 TDC yet ) and need to know I I'm fuked
Bill C
Old May 2, 2008 | 05:06 PM
BLOWNBLUEZ06
Bill C
Bill,
You're right about what you're saying. The thing is that you never want to tighten down a rocker arm when the lifter is not on the base circle of the cam. This will put extreme stress on the bolts, head etc. if you try to cinch down a rocker arm when it is anywhere on the lobe of the cam.
Old May 2, 2008 | 05:08 PM
BLOWNBLUEZ06
a little more...just in case it's needed. This procedure only ensures that you are in fact on the base circle of the cam when tightening the rockers down.
Old May 2, 2008 | 07:37 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
BLOWNBLUEZ06
This is TWICE in one day that you have given me some excellent information! Well,,I did install the rockers without doing the base circle procedure and everything seemed to work out fine. Now I know why THANK YOU for some more excellent info.
BC
To Help! valve train damage!
Old May 2, 2008 | 09:46 PM
wildman572's Avatar
wildman572
With the Harland Sharp rockers it looks like they came with pedistals for the rockers to sit on to do away with the factory one. Thats what I came up with anyway, there were no instructions for installation?
Old May 2, 2008 | 10:13 PM
BLOWNBLUEZ06
BLOWNBLUEZ06
BC
BC,
I don't think anyone on this forum could possibly begin to repay you for your contributions to this forum. I am always more than happy to share and even more with a man whom has been so generous!
Bret
Old May 2, 2008 | 10:36 PM
ISeeRed's Avatar
ISeeRed
You can do it either way. If you don't rotate the cam 180 out, you have to tighten it down in steps and let the lifters bleed down a bit, so you don't put all the stress on it at once.
