Help! valve train damage!
Old May 2, 2008 | 11:06 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bret
Thanks bud!
I been around the block a few times but,,,,,,theres ALWAYS something that needs learning! As much info as I provide people,,,, there are things that I lack. I will admit that I am NOT savy with tuning! and ,,, LS engines are always a learning curve. The tuning guys have my greatest respect!
Thanks for the complements!
Bill Curlee
Old May 2, 2008 | 11:20 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by ISeeRed
You can do it either way. If you don't rotate the cam 180 out, you have to tighten it down in steps and let the lifters bleed down a bit, so you don't put all the stress on it at once.
ISeeRed
Ahhhhhhhhhhhhhhh! I have a saving grace! My new caddy racings lifters are BRAND NEW! So,,,,they were never pubped up.
Note to self: self,,,,,,,,,,,,,,,,,,,DO NOT DO THAT AGAIN!! BAD SELF!
BC
Old May 3, 2008 | 12:23 AM
ISeeRed's Avatar
ISeeRed
Originally Posted by Bill Curlee
ISeeRed
BC
That helps a lot. The lifters just gave way and pumped up when you fired her up!
Old May 3, 2008 | 09:18 AM
ArKay99's Avatar
ArKay99
Originally Posted by wildman572
With the Harland Sharp rockers it looks like they came with pedistals for the rockers to sit on to do away with the factory one. Thats what I came up with anyway, there were no instructions for installation?
You used Harland Sharp rockers? I had to clearance the heads at the rear of the rocker where the pushrod cup is on mine. If there was no clearance this could have caused this failure. I also feel your pain. Back in August I was chasing a vacuum leak, pulled my intake manifold and dropped a very thick washer right down into the #7 cylinder. I didn't notice and when I started it back up it sounded like I ran over a pile of wrenches with my lawnmower.
The only other thing I can think of that could cause this, other than the other theories suggested, was the heads could have been over CNC'd and the one that failed had the bosses fail from fatigue. i.e. the floor of the rocker compartment became too thin from excessive machining of the ports. I've seen pictures of this on other boards, but it usually only happened on one cylinder, not all. It's rare to hear of the rocker bosses failing, but it does happen occaisionlly.
Old May 3, 2008 | 09:30 AM
euro@EFIAlchemy.com's Avatar
0euro@EFIAlchemy.com
Former Vendor
I have seen something like this happen before, and the culprit was the porter took to much meat out of the intake ports, which caused the structural integrity of the rocker boss's to fail.
Old May 3, 2008 | 09:55 AM
wildman572's Avatar
wildman572
The rockers cleared the heads so that shoudlnt be a issue. I wouldnt say that the porting was to thin because it had about the same lift cam in it that I took out and put in and im sure they broke because of the severe interference with the valves and pistons. Im taking the heads off today and have another set of better one to put on. All I can think of is set the lifters by the book and roll it over by hand to make sure there is no interference. If you guys have more suggestions Im deffinatly still open. Thanks for all the help and concern, you guys are great!
Old May 3, 2008 | 09:56 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Old May 3, 2008 | 12:51 PM
ArKay99's Avatar
ArKay99
Well, if it was interference and it caused that much damage to the rocker bosses, I wouldn't be too optimistic about the condition of the pistons and valves. I hope your outcome is better than mine.
I'm still not sure of how the car was set up before your most recent mods, and how it is now. Without a specific setup and change history we can only guess what happened. However, it still would be a crapshoot until you get in there and see what happened in actuality. Good luck, and please post up what you find.
Old May 3, 2008 | 03:44 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
It would be unlikely but as intimated in an earlier post, is it possible the lifters were pumped up at the time you spun the motor over? I can't see how they wouldn’t have bled down from the time you installed to buttoning everything up, but...
Old May 3, 2008 | 09:25 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
The rockers cleared the heads so that shoudlnt be a issue. I wouldnt say that the porting was to thin because it had about the same lift cam in it that I took out and put in and im sure they broke because of the severe interference with the valves and pistons. Im taking the heads off today and have another set of better one to put on. All I can think of is set the lifters by the book and roll it over by hand to make sure there is no interference. If you guys have more suggestions Im definitely still open. Thanks for all the help and concern, you guys are great!
The way to check piston to valve clearance isn't to turn the motor over by hand to see if it stops. You should put low tension springs in place of the standard valve springs in one cylinder to hold the valves up and turn the motor by hand and then put a dial indicator across the retainer. When you get into a close interference position, push on the spring and you need at least .030" clearance at an absolute minimum ( if I remember the distance correctly) to run the motor. You can't simply make sure that it doesn't hit while turning it over by hand. Lifters pump up, metals swell and change clearances etc. at .030", those numbers will change at 6800rpm on a hot engine!!
Please make sure you have the proper clearance!
Old May 3, 2008 | 09:33 PM
BLOWNBLUEZ06
You can also use modeling clay on top of the piston, torque the head down, rotate the engine, cross section the clay and use a dial caliper to measure it's thickness. Get with a machinist or tuner that you trust to discuss the thickness that you measure versus what it should be.
Old May 3, 2008 | 11:20 PM
ArKay99's Avatar
ArKay99
Textbook is .080" intake .100" exhaust. I wouldn't go closer than that.
Old May 3, 2008 | 11:41 PM
  #33
BLOWNBLUEZ06
Thanks for the proper numbers
Old May 4, 2008 | 04:28 PM
  #34
wildman572's Avatar
wildman572
Ok fellas, I got the heads off and all the valves were bent on the drivers side as well. The cam is .575in and .589ex w/1.7 rocker 226/232 @.050 115+2 Im am positive the cam is lined up right because I never removed the crank gear so it was just line up the dots. The only thing I can come up with now is that the lifters did not bleed down maybe. I removed 2 of them and they are hard as a rock, I tryed to compress the plungers with no luck. But if that was the case why did just the intakes bend and not the exhaust? Or maybe the cam is wrong which I find hard to believe cause I bought it off of a fellow forum member. I do have access to a piston to valve clearance tool with the little spring and such which im deffinatly checking this time. Oh I was gonna ask are those MLS head gaskets reusable, thanks
Old May 4, 2008 | 09:46 PM
  #35
gpracer1's Avatar
gpracer1
Either cam timing or wrong cam.
Old May 4, 2008 | 10:10 PM
  #36
vettenuts's Avatar
vettenuts
That cam shouldn't result in this problem. Either cam is not ground correctly or timing is FUBAR.
I wouldn't start buying new parts until you figure out why this happened.
Can you photograph the timing sprockets/chain?
Old May 4, 2008 | 10:13 PM
  #37
BLOWNBLUEZ06
Only way to be sure of proper cam timing is to degree the cam. Some think it is difficult, but it can be learned and once you understand it, you will probably never forget how to do it. I have had a .649 lift cam in my car, and TSP sells them for stockers to use, but the valve timing is different from yours.
If you don't figure out what happened, you put yourself at risk of it happening again.
If your gaskets are in good shape, some may say that they are reusable, but they're too cheap not to replace in my opinion. If you do reuse them, just clean them well.
Do let us all know when you check your PTV what you end up with.
To Help! valve train damage!
Old May 5, 2008 | 12:51 AM
  #38
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
I bet it wasn't timed right, it's easy to not get it right. One of my buddies had his trans am two teeth off and also bent all the intake valves.
Old May 5, 2008 | 09:22 AM
  #39
wildman572's Avatar
wildman572
Well I guess I just as well bite it and tear it down to the cam again and see what is going on. That has to be what it is. I must have missed something or goofed which I guess can happen to the best of us. Thanks a million fellas and I will keep you posted
Old May 5, 2008 | 10:58 AM
  #40
ajg1915's Avatar
ajg1915
St. Jude Donor '08
**** Happens. I'm sure we all have some at least goof up in our wrenching history.
I'll be doing a cam / heads job along with several items in the next month or so. I'll be watching to hear what the problem was so that I don't end up doing it too.
