i will get them fixed asap. just have to figure out what im going to do. anyone know if the heat shield above the o2's on longtubes has anything above it... if i decide to cut. i only drove the car home. about 8 miles. had to or i would of had to get it towed
I would not drive that car anywhere with the primary front O2 sensors not installed, the main purpose of those are to control your air/fuel mixture....you could lose a motor that way!
He's in no danger of losing a motor...but sure wasting Much-o, Gas-o!!
You'll notice a seat of the pants difference with the headers installed, but you'll not get the real gains until the car is tuned..
As a side note for ANYONE doing a header system..this one or another...This is the Absolute BEST time to put in a insulated tunnel plate while the exhaust is off the car, Trust me, the car will be MUCH cooler when you get that heat out of the chassis tunnel area...plus, it will stiffen up the chassis a great deal and make the car feel sooooo much better!
~Maverick
Don't forget the fun part...thicker tunnel plates can interfere with the rear O2's on some header systems..
It took me a long time to get the motor looking like that!! It gives the car a one off, custom look! A great conversation piece Seriously though I am embarrased it is so dirty! Funny thing is I detail the outside of the car weekly. Any advice on cleaning under the hood besides pressure washing it? I had a 96 Dodge Ram and the one time I pressure washed the engine, I got the distributor wet and had to limp her home. A box fan and a few hours later the truck ran fine.
Originally Posted by Todd157k
Wow.. a lot of reading, but good info here. Glad this install went well.. now to the OP, get out there with a pressure washer and CLEAN THAT MOTOR!
As a 'heads up' on chrome/SS headers... If you spray the inside of the header tubes (tape off the flange) with several coats of High Temp (1500 deg) WHITE paint, it will help in keeping them from discoloring. It's a trick we used on motorcycle pipes for years.
hey guys just installed my longtubes last night with off road x pipe. got my front o2s in and rears removed car it throwing system to lean codes. and it also has multipal misfires..... cant figure out why.... do i just really need a tune?? or is there something else that could b wrong??
did you install the O2 sensors? Make sure they are not crossed (the rear ones) this would cause your issues...
Make sure you didn't cross the front ones, it's easy to do... Also if you removed the ground strap on the driver's side of the block make sure you reinstalled it...
well i extended the fronts by chopping my rears up and using the wires to extend my fronts.... anyway i did drivers side header to drivers side connector and passenger side header to passenger side connector...i think thats right... anyway i failed to mention during the install i jacked up 2 coil wires and lost a spark plug lol. my friend had a couple old wires and plugs layin around and used those maybe they were bad??? thanks for all the help fellas in advance!
I am betting the plugs/wires are bad. When I first started my car after installing the headers my car idled fine...at speed you could tell it needed a tune, but no backfiring etc. Good Luck
i was thinkin of goin with rksport headers....and every1 was knockin me in a past thread because they never heard of them or they dont know any1 that has used them. and i mean these headers are 900$ headers without an x pipe http://www.rksport.com/shop/item.asp?itemid=785
so people on this forum will jump on your case if you try to save money in any way or go in a different route.
I didnt buy those headers b/c ive been hearing about the obx and lookin around for some good used ones...which are just as good.
All that matters is that you like it and the best part is they worked for you. Im not a person that would buy *** parts for an American car....but it doesnt matter....
congratulations
People that post up about these type of 'unknown brands' usually are ASKING what others think of them when they post up...but what they are 'really' wanting is everyone to endorse them and tell them to go for it...and when the people DON'T endorse the 'unknown brand', they then start defending their choice...usually because they have already bought them.
It's your car, put whatever you want to put on it...what do you, or ANYONE else for that matter, care about what 'others' think of your choice?...YOU have to live with it, not them. Life's wayyyy to short to spend it trying to please everyone else.
your an idiot...look at my dyno #'s. Sounds to me like you are the one trying to defend your purchase...haha
What an idiot you are, you can't see the humor of what I was saying?? I don't CARE what Headers or Heads or even what GAS you run in YOUR car...You think your Dyno #'s mean squat to me???
YouMIGHT want to try re-reading what I said...it says...Do whatever YOU like, quit worrying about what others think...
"People that post up about these type of 'unknown brands' usually are ASKING what others think of them when they post up...but what they are 'really' wanting is everyone to endorse them and tell them to go for it...and when the people DON'T endorse the 'unknown brand', they then start defending their choice...usually because they have already bought them."
I took offense to this as I posted the thread...I shared my personal experience to let others know that there are other options out there. I do not like naysayers who voice opinions w/o the facts.
"Now, Go order REAL Headers, not those cheapies..."
I'm sorry dim-bulb...I can see you do NOT understand what 'smilies' mean...The laughing 'smilie' immediately following the comment was indicative of it being a comment NOT to be taken seriously, ie: headers are headers and you do NOT have to pay $1800. to get good ones....you need to stop taking yourself soooooo seriously. Gheez, I guess you beat your kids for laughing in the playground, or giggling in church too? It's called HUMOR, but I can see you don't understand that concept.
Key words/phrases in my comment you need to re-analyze: usually(11th word), and then this paragraph, of which you seem to have totally skipped: "It's your car, put whatever you want to put on it...what do you, or ANYONE else for that matter, care about what 'others' think of your choice?...YOU have to live with it, not them. Life's wayyyy to short to spend it trying to please everyone else."
