C5 Tech gurus: C5 push button start.
Old Sep 5, 2008 | 10:17 AM
  #201
THE TECH's Avatar
THE TECH
Originally Posted by dre99gsx
Not dead, still looking through the electronic diagrams for the C5. At least, trying to get them
If no one can get you what you need electronically, I can send you the entire FSM in paperback form if needed.
Old Sep 6, 2008 | 09:56 AM
  #202
dre99gsx's Avatar
dre99gsx
I've got an image copy laying around but trying to find HD space to port it over to a CD. Been trying to finish a few Supra units to distribute but should have some more time to get back on the C5 unit feasability
Old Sep 9, 2008 | 07:47 PM
  #203
dre99gsx's Avatar
dre99gsx
Ok, I'm set with the manuals. Thanks everyone. I'll be sifting through them shortly and let everyone know how feasible this will be with regards to the ignition circuits.
Old Sep 9, 2008 | 08:46 PM
  #204
adam205348's Avatar
adam205348
That is great to hear. Can't wait to see the finished product.
Old Sep 10, 2008 | 01:00 AM
  #205
dre99gsx's Avatar
dre99gsx
Ok. Need a quick wire color check for the ignition switch. Schematics are a bit fuzzy, but there are two connectors that plug into the ignition switch. Need to know what color wires are on the left side, and what colors are on the right. One should have 4 wires, another should have 5. So far, I wouldn't have to touch the microcontroller and it looks as if all ignition positions can be controlled properly.
Old Sep 12, 2008 | 10:02 AM
  #206
dre99gsx's Avatar
dre99gsx
Anyone? You should be able to peak underneath your dash I assume.
Old Sep 18, 2008 | 02:20 PM
  #207
williocom's Avatar
williocom
any updates on this?
Old Sep 19, 2008 | 10:41 PM
  #208
dre99gsx's Avatar
dre99gsx
Waiting for someone to give me some details from the last 2 posts.. haven't heard from anyone yet.
Old Sep 20, 2008 | 03:03 AM
  #209
nextime's Avatar
nextime
Nope. You need to remove a panel to see anything.
Old Sep 20, 2008 | 03:59 AM
  #210
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Maybe this will help?
Tim
Old Sep 20, 2008 | 07:17 AM
  #211
dougbfresh's Avatar
dougbfresh
So, someone is going to try to engineer this without a car to even try it on and work the bugs out? This ought to be amusing.
Old Sep 21, 2008 | 10:29 AM
  #212
dre99gsx's Avatar
dre99gsx
The unit works on other makes, so most of the unknowns is just wiring. Tim that might help, thanks. I will be releasing a unit for someone at close to my cost. The idea is we will work together to make sure it works. If in the end it doesn't work, they get they're money back without questions. But, someone will have to be comfortable cutting wires and at least soldering. That photo up there showing the wires; obviously the entire thing will need to be removed. I can provide tabs on the wire ends such that you can insert the tabs into the two connectors that plug into that key cylinder. That should allow you get get away from cutting/soldering until we are ready to complete the install (incase you need to revert back to the key cylinder).
Everything else as was spoken here is trivial. I'm going to work on an instruction manual that should help with the installation with every step you would need for a C5.
Old Sep 22, 2008 | 04:29 AM
  #213
tstar's Avatar
tstar
I was an electronics technician in the Air Force for 20 years and very comfortable with soldering and have all the equipment needed. Actually this type of work is a breeze to perform.
My issue is freeing up the cash. If you need a test mule I can do an install and verify or work out any bugs with you over the phone then send everything back to you to finalize the kit so we can get this rolling.
Tim
Old Sep 22, 2008 | 08:10 PM
  #214
dre99gsx's Avatar
dre99gsx
I would be ok with that as well. PM me your information and I'll coordinate something with you soon.
Old Sep 23, 2008 | 02:25 AM
  #215
tstar's Avatar
tstar
PM sent, I'll be installing new Speedhut IPC faceplates soon as well so everything will be apart anyway. Archery season starts Oct. 4 so I have sufficient incentive to get this done ASAP!
Tim
Old Oct 2, 2008 | 06:40 PM
  #216
williocom's Avatar
williocom
just checking on the updates. this would be sweet if it works
Old Oct 2, 2008 | 09:48 PM
  #217
jdmvette's Avatar
jdmvette
Night Owl for life
To C5 Tech gurus: C5 push button start.
Old Oct 3, 2008 | 06:24 PM
  #218
tstar's Avatar
tstar
I have my dash tore apart AND my seats are out so.... like NOW would be a good time!
Tim
Old Oct 4, 2008 | 12:12 AM
  #219
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Radioflyer brings the goods:
A member of the Sam houston corvette club had it done. It's fully funtional, but i haven't managed to squeeze the details out of him.
Old Oct 4, 2008 | 12:39 AM
  #220
donkeykong's Avatar
donkeykong
We need the details!!!
