C5 Tech gurus: C5 push button start.
Old Oct 4, 2008 | 12:46 AM
  #221
NemesisC5's Avatar
NemesisC5
Originally Posted by TheRadioFlyer
Radioflyer brings the goods:
A member of the Sam houston corvette club had it done. It's fully funtional, but i haven't managed to squeeze the details out of him.
Very Clean Install ! !
Old Oct 4, 2008 | 01:26 AM
  #222
jdmvette's Avatar
jdmvette
Night Owl for life
squeeze harder!
Old Oct 4, 2008 | 01:40 AM
  #223
lionelhutz's Avatar
lionelhutz
Hey guys. I know I'm late but hopefully I can add some helpful information.
Around post 134 you were putting up schematics of the door wiring showing the lock and unlock button wiring highlighted with I assume the purpose to open and close the doors.
FYI. My car is a 98 Canadian spec car. I once left the keys in the ignition and locked the doors using the door button. I came back with a clothes hanger and slid it in the door to press the unlock button. The alarm immediately sounded. Using the door panel unlock button will not open the doors on my car without sounding the alarm once it has been locked and closed. And, the door lock button definitely arms the alarm. I didn't have a working fob for a while. during that time, I once tried to open the hatch but it stuck and I left it. The hatch later popped when I was at work and the alarm went off and got the next door neighbor had to come over and close it.
If you look at that diagram, you will see a "Door Latch-Driver" component bottom right. In it, there is a "Door Key Switch". That is the switch that needs to be used to deactivate the alarm (and open the door?0. I will note here that you can turn the key to unlock 2x and the other door opens and if you turn the key to unlock 3 times the hatch will open. I would have to go out to the car and check that if I do the 2 turns if the door unlock is electrically activated on the side I'm using the key on. It's possible it only unlocks the opposite door and uses mechanical means to open the door the key is being used on but I doubt it. Let me know if you want me to check - I will check back here in 12 hrs or so. Worse case would be hit that key switch first 2x then the door unlock button next.
I think you guys have the ignition switch bypassed no problem. Just imitate the resistor and close all the appropriate switch contacts. The column lock bypass or not should not matter. If you get past the ignition security (ie the passkey) then it will unlock when the key is turned to either the acc or ign position. The column lock bypass is a bypass not a defeat. It just simulates what the column lock motor part would do if it was connected.
Peter
Old Oct 4, 2008 | 02:50 AM
  #224
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Originally Posted by jdmvette
squeeze harder!
Yeah, what he said!!!!!!
Tim
Old Oct 4, 2008 | 09:09 AM
  #225
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Okay yall: the conversion was done by American audio concepts in Bellaire, texas. The owners name is. Raghim
Old Oct 7, 2008 | 07:21 PM
  #226
NemesisC5's Avatar
NemesisC5
Can you PM me the contact information? My C5Z actually needs a new ignition switch so now would be a good time for me
Nevermind, Google was my friend!
Old Oct 7, 2008 | 08:57 PM
  #227
dre99gsx's Avatar
dre99gsx
I've been building these for the Supra guys but have yet to ship one out here for the C5 guys for testing. I still need to create the brackets to adapt the button. I should get off my *** and get this done....
Old Oct 7, 2008 | 10:22 PM
  #228
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I volunteer my car as the guinea pig. How do you wire it? you have NO idea how much i'd like to never have to dig for my keys again.
Old Oct 8, 2008 | 12:22 AM
  #229
GreekFire's Avatar
GreekFire
Cruising
Originally Posted by donkeykong
We need the details!!!
Does anyone know the make and model of this headunit? It really fills in the headunit console. Sorry guys I can’t get the image to show up, but it's the picture that Radioflyer has put up of the owner with the push button ignition starter.
Old Oct 8, 2008 | 03:04 AM
  #230
tstar's Avatar
tstar
George, dre99gsx - I already volunteered to guinea pig this but George you go ahead and take this! I'm way too busy now with hunting and the new EL faceplates plus my new seat covers should be arriving soon.......
That bezel has been modified to fit that head unit, a rather time consuming OR expensive operation, search "Double Din Bezel". They did an excellent job though...
Tim
Old Oct 8, 2008 | 08:31 AM
  #231
adam205348's Avatar
adam205348
Tim
Yeah, looking on that audio shops website it looks like they just modified the Headunit slot and kept the HVAC and ashtray slot oem size, which I really like versus moving the HVAC down and filling in the ashtray.
Here is the link for the shop that did the keyless ignition and the headunit install.
http://www.americanaudioconcepts.com/
Here is a link to the Gallery of a Corvette they did and you can see the Headunit installed clearly.
http://www.americanaudioconcepts.com...vycorvette_02/
Old Oct 8, 2008 | 09:07 AM
  #232
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Tim
Mmmm EL face plate. what's it going to say tim?
Old Oct 8, 2008 | 05:39 PM
  #233
NemesisC5's Avatar
NemesisC5
Talked to Raghim today...super nice guy and has it goin on at his shop He laid out the "push-button packages" to me in detail
Old Oct 8, 2008 | 05:51 PM
  #234
dre99gsx's Avatar
dre99gsx
Tim
I have no problem with that. I'll keep you (George) on my list then. I have yet to create wiring instructions for the C5, but they exist for the Supra. It will be fairly similar. I provided a link to it 2 pages back I believe.
Old Oct 8, 2008 | 08:52 PM
  #235
jdmvette's Avatar
jdmvette
Night Owl for life
Old Oct 8, 2008 | 09:45 PM
  #236
NemesisC5's Avatar
NemesisC5
PM sent Bro
Old Oct 8, 2008 | 10:07 PM
  #237
minitech's Avatar
minitech
Why don't you lay out the detail about the cost for us as well as the contact info for Raghim
To C5 Tech gurus: C5 push button start.
Old Oct 9, 2008 | 03:12 AM
  #238
tstar's Avatar
tstar
I'm getting two sets, one Red and mostly stock looking except for the addition of a C5 Jake for the logo. The second set will be a bit wilder with flames and such... I'm doing the initial fittment verification for them right now, awaiting the second set with some fixes.
But as usual I digress from the subject of this Thread!
Tim
Old Oct 9, 2008 | 03:15 AM
  #239
tstar's Avatar
tstar
OK cool! BTW Like myself, George won't need the wirring diagrams, as a matter of fact he can probably write them up for you as he goes like I was going to do...
As if you weren't busy enough huh George?
Tim
Old Oct 9, 2008 | 03:28 AM
  #240
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by minitech
Why don't you lay out the detail about the cost for us...
