Our Noisy Valvetrains
Old Nov 14, 2008 | 09:00 PM
Targa98's Avatar
Targa98
Default Our Noisy Valvetrains
Just did H/C swap to ported 5.3 heads and a 222/228 .567/.567 113 with patriot's extreme valve springs. I am getting a lot of valvetrain noise. The typical sewing machine sound. I was wondering how to quiet this down. I have a lot of preload on my lifters, a good 1 3/4 turns which I figure should equate to about .080 - .085 preload.
Old Nov 14, 2008 | 09:15 PM
z06 hellcat's Avatar
z06 hellcat
welcome to the club!
Old Nov 14, 2008 | 09:21 PM
dixonk's Avatar
dixonk
St. Jude Donor '09
We can only dream of a solution to that annoying problem....sigh.
Old Nov 14, 2008 | 09:30 PM
user_name's Avatar
user_name
I guess you have adjustable rockers? Run the car with the valve covers off and try different preloads. You may need a longer pushrod. These motors do make noise though with aftermarket cams.
Old Nov 14, 2008 | 09:47 PM
Targa98's Avatar
Targa98
no, stock rockers, pusrods, and lifters. Only the spring are aftermarket. I'm trying to figure out why the hell our motors get so noisy. There MUST be something wrong somewhere.
Old Nov 14, 2008 | 09:55 PM
user_name's Avatar
user_name
The rockers are non-adjustable. Tq to 22 lb-ft. If you feel like messing with it for a very long time you can shim the rockers over and over until it gets pretty damn quiet. I did that in the past with some comp-R rockers, and the valvetrain was super quiet!
Old Nov 14, 2008 | 10:30 PM
Targa98's Avatar
Targa98
Really? Well, that sounds like a geometry issue then... I will look into that thanks. Any other speculations?
Old Nov 14, 2008 | 10:37 PM
Jettech's Avatar
Jettech
If you are using XER lobes, you can not escape some noise.
Old Nov 14, 2008 | 10:39 PM
SUPERCRUZ's Avatar
SUPERCRUZ
I am going to throw this out there to you. Take it for what it is worth. I am running a cam in the upper 230s with over .600 lift on 113LSA and TF 215s. When I picked the car up from ECS this past March I was pretty suprised at how much valvetrain noise it made especially right at 2200RPM. All the sources I spoke said it was normal. I put about 2500 miles on this setup. This Fall, I decided to add a bottle of ZMax micro lubricant to my normal annual oil change. All I can say is that after a couple hundred miles the noise is significantly improved. I still have some slight sewing machine noise but the noise at 2200RPM is gone. You might give this a shot. Good luck with it.
Old Nov 15, 2008 | 07:49 AM
vettenuts's Avatar
vettenuts
What ramp rate is the cam you are using? I just went from a Crane cam with a slower ramp rate to an XER Comp and the noise increase was dramatic. My valve train geometry is perfect and I am using YT roller rockers.
If you didn't check your geometry and measure for pushrod length, you should really do this as part of the installation. According to my calcs, 1-3/4 turns on a M8-1.25 bolts accounting for rocker ratio is 0.137" pre-load so you are almost bottomed in the lifter. I would definitely measure.
Old Nov 15, 2008 | 09:06 AM
vsocks1's Avatar
vsocks1
I have read all kinds of different numbers on recommended pre-load. What did you go with on your set up?
Old Nov 15, 2008 | 10:03 AM
vettenuts's Avatar
vettenuts
I am using Morels. My target was 0.050". I ended up with 0.054" as measured with a dial indicator.
Old Nov 15, 2008 | 11:20 AM
lucky131969's Avatar
lucky131969
What did you gain going with adjustable rockers? Increase in horsepower? No valve float at high RPM?
Old Nov 15, 2008 | 11:45 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Bob isn't using adjustable rockers - they are Yella Terra roller-tipped rockers. He shimmed the base to obtain the correct geometry.
The fact that his setup now exhibits valve train noise should serve notice to all the folks out there that claim "if you have a noisy valve train it must be user error". It’s simple physics; higher ramp rates are going to accelerate and decelerate parts in a way that is impossible to completely suppress audible artifacts.
Old Nov 15, 2008 | 12:14 PM
AU N EGL's Avatar
AU N EGL
SBC make normal valve train noise. then when you add XER lob cam and YTs the noise goes up. That is just the way it is.
Better oiling will cut some of that noise down. I run a 3 qt accusump with a simular cam. Yes there is noise, but not too bad
Old Nov 15, 2008 | 03:29 PM
Corvette Don's Avatar
Corvette Don
Mine has it pretty bad also, roller rockers will help out some.
Old Nov 15, 2008 | 08:20 PM
vettenuts's Avatar
vettenuts
As stated, they are not adjustable, but what I did gain was a wipe pattern that is only 0.045" wide centered on the valve stem. You won't get that with stock rockers.
To Our Noisy Valvetrains
Old Nov 15, 2008 | 08:23 PM
vettenuts's Avatar
vettenuts
Actually, I think one of the worst offenders for noise is the FAST intake. Once installed its almost like a megaphone on the lifters as there is very little noise attenuation with it.
Old Nov 15, 2008 | 10:46 PM
Targa98's Avatar
Targa98
O WOW, I was under the impression that each turn was about .048 to .050. I will be checking pushrod length tomorrow. I will also be investing in a melling oil pump and cloyes timing set. Then rockers. Man, I wonder what the hell causes the noise. It seems there MUST be a gap somewhere.....
Also, I am using a lunati voodoo cam. part #60511
Old Nov 16, 2008 | 09:01 AM
Corvette Don
It is if you are using a comp pushrod length checker.
