Oh Great.............
Old Dec 23, 2008 | 09:35 AM
SharpCrease's Avatar
SharpCrease
Default Oh Great.............
I just purchased a 2002 Vette about 5 days ago and paid to have it fully inspected. The inspection came out good other than a trans pan gasket leaking which I went ahead and had changed along with the filter and fluid. Anyway, I buy the car from the person after the check up and and few days later I get "Service Tire Monito System". It's just my luck something would go wrong a couple of days later. Do you think the inspection should of picked up on this or is it just my luck? By the way, my vette is a coupe/A4 with about 60k.
Old Dec 23, 2008 | 09:38 AM
hawk4077's Avatar
hawk4077
Things break and they don't always warn us before they do.
Old Dec 23, 2008 | 09:41 AM
vettenuts's Avatar
vettenuts
One of the nice things about the C5 is you can pull the actual error codes and be able to pinpoint the issue. The inspection wouldn't have anything to do with this. It may be simply a case of low batteries in 6 or 7 year old sensors and they need to be replaced. Here is how to get the codes and there is a .pdf list of codes at the bottom of the page.
Link to code retrieval
Old Dec 23, 2008 | 09:51 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If the weather in your area is REALLY COLD, the temp of the batteries could be the issue. Yea they are older sensors so the batterys are weak. If the temp increases. the error may just go away. Just one of those things. No inspection could have noted that if it wasnt bad during the inspection.
Look at it this way. Your sensors are a LOT less expensive than the earlier sensors!
Old Dec 23, 2008 | 09:58 AM
SharpCrease
Thanks guys for the quick response. It has been very cold lately and that makes sense about the batteries. How much are the sensors typically? And is this something a novice can do him/herself or should I let the dealership do it?
Old Dec 23, 2008 | 10:24 AM
dougbfresh's Avatar
dougbfresh
Did you actually check the tire pressure???
Old Dec 23, 2008 | 10:31 AM
SharpCrease
Yeah.... They read: Front L 31, R 30; Rear L xxx, R 32.......
Old Dec 23, 2008 | 10:40 AM
SUPERCRUZ's Avatar
SUPERCRUZ
You will have to dismount the tire to service the tire pressure sensors. Not something you can do yourself. You might try the tire sensor re-learn procedure and see if that resolves the issue. Do a search in the Tech section for exactly how to go about doing the procedure. You can do the re-learn procedure yourself. All you need is a strong magnet. Good luck with it.
Old Dec 23, 2008 | 11:26 AM
jrose7004's Avatar
jrose7004
Looks like the LR one needs to be replaced reading XXX.
Old Dec 23, 2008 | 11:56 AM
dougbfresh's Avatar
dougbfresh
Did you take a pressure guage out and actually check the tire pressure????
Old Dec 23, 2008 | 10:47 PM
SharpCrease
Okay will do.......... Great advise. I will wait til it warms up and if that doesn't fix it I'll go to a tire shop thats good. thnx again
Old Dec 23, 2008 | 11:37 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
In the mean time, if you're driving the car, just hit reset each time you drive so your other DIC functions will work.
Old Dec 25, 2008 | 01:59 AM
Armycop's Avatar
Armycop
my '01 coupe has all four pressure sensors out at the moment...it is about 40f in the garage tho. As the batteries weaken, the pressure sensors become more susceptable to the cold. Wait 'till winter's over before you decide on changing out sensors.
Old Dec 25, 2008 | 08:41 PM
skipsville's Avatar
skipsville
From: Mtns of north Georgia - Hey Kids, I'm spending your inheritance!
I had this same problem on my '02 Coupe just last Sunday (12/21) after I disconnected the battery to work on the headlight gear. When I reconnected the battery, I ran a system check - just because. It showed RF xxx, so I checked the pressure with a "real" gauge and the tire was fine. I released air pressure from the RF for five seconds, then added air to get the pressure back to normal - drove down the road about a mile and "voila", the TPM works fine. Just a "gremlin" in the electronics I guess.
Good Luck Sharp Crease.
Old Dec 25, 2008 | 10:54 PM
ALLEGRO's Avatar
ALLEGRO
I say enjoy, even the smaller repairs !
You have a seven-year-old car, that has a LOT of life left in it. Just hang us here on the Forum and ask and learn. We all began without much knowledge, but quickly learned from the more experienced. Solving problems is part of the fun of ownership.
Good Luck
Old Dec 26, 2008 | 12:04 AM
Bell's Avatar
Bell
As mentioned above, make sure the tire actually has air in it. Also, check your vehicle battery (AutoZone will check it for free). If the charge starts getting low (cold weather, old battery), all sorts of electrical gremlins start popping up. Also, pull the codes from DIC to make sure you don't have any related to the RFA module. It's likely you have a "U" code (lack of communication) with the LR sensor. This can be caused by bad or low sensor battery, bad or low vehicle battery, bad generator, bad RFA module, among other things. This can also happen if the previous owner just recently replaced the tires (to sell the car) - somtimes when the tires are removed from the vehicle, the sensors will temporarily lose radio comm with the module and take several ignition cycles to reconnect. Just some thoughts for troubleshooting. Almost any tire installation shop (I use local Goodyear) can replace the sensor batteries or replace the entire sensors for less than the dealership will do it. Sometimes they can get the sensors cheaper than the dealership (sometimes they get them from the dealership), but the labor is usually less than the dealership. Good luck and let us know how it turns out. That's how we all learn from each other.
To Oh Great.............
