valvetrain noise
Old Apr 16, 2009 | 03:00 PM
ZOH SIX's Avatar
ZOH SIX
Default valvetrain noise
Well I installed the cam and dual springs in my Z.went with the torquer 2 and dual valve springs also have lg streets the valvetrain noise is loud.Its louder than my ls2 what can or do I need to do?by the way i did not mess with the heads other than the springs and pushrods same stock rockers also
Old Apr 16, 2009 | 03:14 PM
rmtt's Avatar
rmtt
It's normal. My car had quite a bit more valvetrain noise after my cam/spring swap.
Old Apr 16, 2009 | 03:16 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Cams that are described as having “aggressive ramp rates” will make more noise on valve closing compared to a stock cam. That being said, did you check to make sure your new springs are not going into coil bind with the new cam?
Old Apr 16, 2009 | 04:52 PM
vettenuts's Avatar
vettenuts
Did you measure for pushrod length?
Old Apr 16, 2009 | 05:20 PM
ZOH SIX's Avatar
ZOH SIX
i went off Texas speed advise with the whole set up cam,push rods and springs so I would hope they were right
Old Apr 16, 2009 | 05:54 PM
vettenuts's Avatar
vettenuts
You really should measure for pushrods. Most just put in the 7.400" without measuring, but each car is different. The lifters are fairly forgiving and you may get away with it, but best to measure and be sure of the length required.
Old Apr 16, 2009 | 06:36 PM
rmtt's Avatar
rmtt
When I changed mine, the smaller base circle of the larger cam required a slightly longer pushrod at 7.425.
Old Apr 16, 2009 | 10:38 PM
ZOH SIX's Avatar
ZOH SIX
I better check it then I went with the 7.40's like suggested
Old Apr 16, 2009 | 11:10 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Old Apr 16, 2009 | 11:16 PM
Mike94ZLT1's Avatar
Mike94ZLT1
Mine sounds like a damn sewing machine, but according to Dr. Phil it sounds fine.
Old Apr 17, 2009 | 04:56 PM
vettenuts's Avatar
vettenuts
I finally got to drive mine today after doing H/C late last fall. It is damn noisy and I spent hours setting up the valve train and measuring.
Old Apr 17, 2009 | 05:14 PM
fst85vtt's Avatar
fst85vtt
Im in the same boat!!! its driving me crazy i cant stand it lol I ended up having .050 to long of pushrods changed them out and no change
Im thinking about putting some aftermarket rockers on but it really sounds like lifters to me
Old Apr 17, 2009 | 05:41 PM
ZZOOM06's Avatar
ZZOOM06
When I did the original H/C package for my 346, the valve train got noticeably louder, and yes, I did measure for the correct length pushrods and check for coil bind. Finally went to Yella Terra ultralight roller rockers and things quieted down a bunch. I'm now running the Yella's in my LS3 stroker with a much bigger cam and the valve train is pretty quiet. Actually quieter than my 346 was with the YT's.
HTH
Jimbo
Old Apr 17, 2009 | 05:57 PM
vettenuts's Avatar
vettenuts
HTH
Jimbo
Do you happen to know what lobes the cams were (XE-R, etc.)?
Old Apr 17, 2009 | 06:07 PM
ZZOOM06's Avatar
ZZOOM06
Both cams are XE-R lobes! My friend Pete who spec'd both my combo's uses nothing but XE-R lobes.
Jimbo
Old Apr 17, 2009 | 09:45 PM
ZOH SIX's Avatar
ZOH SIX
i talked to the guys at texas speed today they said 98% of the tqr 2 cam swaps use the 7.40 length push rods.I think I'll measure it and replace the rockers with the yella terra
Old Apr 17, 2009 | 11:09 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I installed EG's Whiplash Cam and installed the recommended 7.40 push rods. Very pleased with the performance and NO NOISE.
Well,,there will always be some noise with a cam as aggressive as the one I'm running but, with respect to the 610 lift, the valve train is very quiet!!!
To valvetrain noise
