intake air temp sensor ?
Old May 24, 2009 | 03:32 AM
turbod da's Avatar
turbod da
Default intake air temp sensor ?
well,i have a problem with my car,
2000 6spd
My check engine light came on,
says intake temp sensor input high.
so i replaced with a new one ,and still gives my that code.
at the same time,ever since i got that code,the display reads
ACTIVE HANDLING WARMING UP
ive read its normal ,but mine never did that and now
it displays that maybe a minute after i turn the car on everytime.
looks to me maybe both problems might be just one,
meaning there in the same circuit or fuse,
where should i start,what you think ?
TIA !!
Old May 24, 2009 | 02:47 PM
byronhunter's Avatar
byronhunter
If you want to do some troubleshooting, this might help.
Old May 25, 2009 | 01:13 AM
Derald's Avatar
Derald
Default IAT sensor
On my 2000 my check engine light would come on and I bought a bypass switch for about $25.00 and unhooked the IAT and plugged in the 2 wires and the light has yet to come on. This bypass is to increase the air flow. I hope I don't mess up anything, Derald
Old May 25, 2009 | 03:36 AM
DeeGee's Avatar
DeeGee
Check the codes and post up anything current
That will help troubleshoot the problem
Old May 26, 2009 | 08:21 PM
turbod da's Avatar
turbod da
po113
and active handling warming up,
both started coming on at the same time..
Old May 26, 2009 | 09:12 PM
SJPD's Avatar
SJPD
those wires are tiny and sometimes break
I had the exact same problem years ago
I had to fix the wire in the connector
Old May 27, 2009 | 12:35 AM
turbod da's Avatar
turbod da
you mean the wires at the connector plug?
is this related to the active handling too?
Old May 27, 2009 | 12:49 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yes. If the wires are shorted it could effect the 5 vdc reff voltage which effects the speed sensor.
BC
Old May 27, 2009 | 12:55 AM
turbod da's Avatar
turbod da
BC
ok,makes sense,if the active handling and speed sensor
depend on each other.
but my speed sensor still works,
i'll try and see if it has some short.
Old May 27, 2009 | 01:39 AM
DeeGee's Avatar
DeeGee
Gotta go to work but heres the troubleshooting chart for that code
Document ID# 795574
2002 Chevrolet Corvette
DTC P0113
Circuit Description
The intake air temperature (IAT) sensor is a variable resistor. The IAT sensor has a signal circuit and a low reference circuit. The IAT sensor measures the temperature of the air entering the engine. The powertrain control module (PCM) supplies 5 volts to the IAT signal circuit and a ground for the IAT low reference circuit. When the IAT sensor is cold, the sensor resistance is high. When the air temperature increases, the sensor resistance decreases. With high sensor resistance, the PCM detects a high voltage on the IAT signal circuit. With lower sensor resistance, the PCM detects a lower voltage on the IAT signal circuit. If the PCM detects an excessively high IAT signal voltage, indicating a low temperature, DTC P0113 sets.
Conditions for Running the DTC
* DTCs P0101, P0102, P0103, P0116, P0117, P0118, P0125, P0128, P0502, or P0503 are not set.
* The engine run time is more than 120 seconds.
* The vehicle speed sensor indicates that vehicle speed is less than 11 km/h (7 mph).
* The engine coolant temperature is more than 60°C (140°F).
* The mass air flow is less than 15 g/s.
Conditions for Setting the DTC
The IAT sensor signal voltage indicates that the intake air temperature is less than -39°C (-38°F) for more than 5 seconds.
Action Taken When the DTC Sets
* The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
* The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
* The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
* A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
* A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
* Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
* When the vehicle is at ambient temperature the IAT sensor and ECT sensor temperatures should be relatively close to each other. Refer to Temperature vs Resistance .
* If a short to a separate 5-volt source occurs this DTC may set. If this condition exists, a continuity test to all other PCM 5-volt reference circuits will be necessary.
* If an intermittent condition is suspected, refer to Intermittent Conditions .
Test Description
The number below refer to the step number on the diagnostic table.
6.
This step tests for the proper operation of the circuit in the low voltage range. If the fuse in the jumper opens when you perform this test, the signal circuit is shorted to voltage.
DTC P0113
Step
Action
Values
Yes
No
Schematic Reference: Engine Controls Schematics
1
Did you perform the Diagnostic System Check-Engine Controls ?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
2
1. Install a scan tool.
2. Turn ON the ignition, with the engine OFF.
3. Observe the IAT sensor temperature with a scan tool.
Is the IAT sensor temperature less than the specified value?
-38°C (-36°F)
Go to Step 4
Go to Step 3
3
1. Observe the Freeze Frame/Failure Records data for this DTC.
2. Turn OFF the ignition for 30 seconds.
3. Start the engine.
4. Operate the vehicle within the Conditions for running the DTC as specified in the supporting text or as close to the Freeze Frame/Failure Records data that you observed.
Does the DTC reset?
Go to Step 4
Go to Diagnostic Aids
4
1. Turn OFF the ignition.
2. Disconnect the mass air flow (MAF)/intake air temperature (IAT) sensor. Refer to Mass Air Flow (MAF)/Intake Air Temperature (IAT) Sensor Replacement .
3. Connect a DMM between the signal circuit and the low reference circuit of the IAT sensor harness.
4. Turn ON the ignition.
Does the DMM voltage measure more than the specified value?
5 V
Go to Step 5
Go to Step 6
5
Important
The sensor may be damaged if the circuit is shorted to a voltage source.
1. Test the signal circuit for a short to voltage. Refer to Circuit Testing in Wiring Systems.
2. Repair as necessary. Refer to Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 14
6
2. Disconnect the IAT sensor. Refer to Mass Air Flow (MAF)/Intake Air Temperature (IAT) Sensor Replacement .
3. Connect a 3-amp fused jumper wire between the signal circuit of the IAT sensor and the low reference circuit at the IAT sensor. Refer to Using Fused Jumper Wires in Wiring Systems.
4. Turn ON the ignition, with the engine OFF.
5. Observe the IAT sensor temperature with a scan tool.
Is the IAT sensor temperature more than the specified value?
128°C (262°F)
Go to Step 10
Go to Step 7
7
2. Connect a 3-amp fused jumper wire between the signal circuit of the IAT sensor and a known good ground.
3. Turn ON the ignition, with the engine OFF.
4. Observe the IAT sensor temperature with a scan tool.
128°C (262°F)
Go to Step 9
Go to Step 8
8
Test the signal circuit of the IAT sensor for an open circuit or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems
Go to Step 14
Go to Step 11
9
Test the IAT sensor low reference circuit for high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 14
Go to Step 11
10
Important
If a short to a separate voltage source occurs, this DTC may set and damage the IAT sensor. If this is found to be the condition, a continuity test to all other PCM circuits will be necessary to diagnose the specific fault.
Inspect for poor connections at the harness connector of the IAT sensor. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems
Go to Step 14
Go to Step 12
11
1. Inspect for poor connections at the harness connector of the PCM. Refer to Powertrain Control Module (PCM) Replacement .
2. Repair the connections as necessary. Refer to Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 14
Go to Step 13
12
Replace the IAT sensor. Refer to Mass Air Flow (MAF)/Intake Air Temperature (IAT) Sensor Replacement .
Did you complete the replacement?
Go to Step 14
13
Replace the PCM. Refer to Powertrain Control Module (PCM) Replacement .
Go to Step 14
14
1. Use the scan tool to clear the DTCs.
4. Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC run and pass?
Go to Step 15
15
With a scan tool, observe the stored information, Capture Info.
Does the scan tool display any DTCs that you have not diagnosed?
Go to Diagnostic Trouble Code (DTC) List
System OK
Document ID# 795574
Old May 27, 2009 | 10:01 AM
SJPD's Avatar
SJPD
yes and yes
it seemed strange to me too.
Old May 28, 2009 | 04:10 PM
chucks00's Avatar
chucks00
Cruise-In III & VI Veteran
I had the same issue. Codes p0113 and p1111 plus the active handling issue. replaced the IAT and still not fixed. Replace the IAT Connector and it was fixed.
Ordered from http://www.bmotorsports.com/shop/ Total was under 9 bucks and just had to splice it in the harness.
1 x GM Delphi / Packard IAT / MAT / ACT Sensor Connector Pigtail # 12102620 $6.99
Old May 29, 2009 | 02:48 AM
turbod da's Avatar
turbod da
thanks,ordered it,thanks for the help everyone!
Old May 29, 2009 | 09:49 AM
chucks00's Avatar
chucks00
Hope your lucky like me and it solves your problem. Post when it's fixed.
Old May 29, 2009 | 06:13 PM
turbod da's Avatar
turbod da
Hope you lucky like me and it solves your problem. Post when it's fixed.
will do
Old May 29, 2009 | 07:55 PM
SJPD's Avatar
SJPD
I was able to repair it w/o changing the connector
just rebuilt it
Old Jun 4, 2009 | 03:25 AM
turbod da's Avatar
turbod da
okay,arived installed it,drove about 90 miles today
no problem,active handling fixed also....thanks everyone
still cant believe what a little wire causes
To intake air temp sensor ?
Old Jul 9, 2009 | 09:21 PM
C5Luv'R's Avatar
C5Luv'R
Can I just say...I LOVE this forum. I had the same issue as turbod da about a month ago, whereas my car set the CEL and had the "Active Handling Warming Up" message displayed on the DIC. A few days before the CEL and message came on, I noticed the car idled a little rough when hot.
My issue turned out to be a broken wire INSIDE the Delphi Metri-Pack 150 connector for the Inlet Air Temp (IAT) sensor. Attached is a picture of the damaged wire. You can see it broke inside the wire sheathing. Very weird...my guess it was caused by fatigue?
I ordered the connector from Bellanger (two color wires). It is a Delphi-Packard Metropak GT150.
But then remembered that Terminal Supply in Troy Michigan (http://terminalsupplyco.com/default.aspx) sells many automotive connectors. Terminal Supply is only a few miles from my house, so I stopped by on my way to work. Sure enough, they sell pre-made pigtails for this connector with two black wires for $6. It is part number PT-1510
I installed it on my car, leaving a longer loop of wire. Hopefully this will stop the wire fatigue issue that I suspect caused my failure. I will revive this post if I have an issue with it again!
Old Jan 29, 2010 | 10:28 AM
gcolella's Avatar
gcolella
Default Iat wires please help
I was just finished installing my long tube headers when I pulled out the IAT wires right out of the plug. Can someone please show me a picture of there's or tell me which color wire goes to which side of the plug. One wire is purple one is tan .
Old Jan 29, 2010 | 10:41 AM
lucky131969's Avatar
lucky131969
Ahhhh....post #2......
